Old 06-10-2012, 11:56 PM   #29
Jayp
Drives: Scion FR-S
Originally Posted by feldy View Post
Soooo I went out to make my video.. and what do you know I was able to launch it.
Whats happening is if you put your foot slammed into the brake 100 percent. It wont do it. If you do say 90 percent it will. Glad I went to make the video only to make my self look like a fool.
did some more testing while I was at it. We were having issues getting the car to down shift into first.
First goes to about 36 38 mph
2nd goes to about 63 65 mph.
It will not let you downshift into first till 33 mph. These are good to know things.
Glad everything is working . Thanks for the additional info though. Hopefully I'll be able to do to some tests myself once this break in is done
Jayp is offline   Reply With Quote
Old 06-11-2012, 01:16 AM   #30
Jordo!
Enjoy it, destroy it.
Jordo!'s Avatar
Drives: Datsun Racing Hen
On the 370Z, which does the same thing, you can pull the brake light fuse and that negates the problem.
Jordo! is offline   Reply With Quote
Old 06-12-2012, 12:12 AM   #31
Max Schnell
Drives: Lexus GS350 F-sport
So what can you launch it at now? I am curious because it may make the difference between only considering manual or possibly considering an auto.
Max Schnell is offline   Reply With Quote
Old 06-12-2012, 12:16 AM   #32
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Yep I was able to sit still and smoke the rear tires also.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 06-12-2012, 12:38 PM   #33
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Have you tried a 0-60 run?
SUB-FT86 is offline   Reply With Quote
Old 06-12-2012, 02:26 PM   #34
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
Hah! I wish I knew this last sunday where I autocrossed my AT. I pretty much launched from idle RPM ;p I will have to try this one out
mechaghost is offline   Reply With Quote
Old 06-12-2012, 04:04 PM   #35
feldy
feldy's Avatar
No I don't care not a single ounce about 0 to 60 times. I autocross not drag race. I just need to get off the line quicker to the next corner or gate. If anyone bought this car to drag race you should have read the reviews first.
The Following 2 Users Say Thank You to feldy For This Useful Post:
BRZranger (06-13-2012), rs999 (08-10-2014)
Old 06-13-2012, 07:59 AM   #36
UncleFester
Originally Posted by Jayp View Post
I can also confirm that the AT can go past 2k at launch.
My AT also goes beyond 2k at launch. The problem you are describing comes from the electric brake assist that is supposed to occur during a panic stop situation.
I just hold the brake a little more than halfway and when it breaks around 4k that is my launch.
Overall, I am very pleased with the trans, it is the best OEM automatic I have ever driven. I think it will do just fine for DD, club racing, and autocross.
UncleFester is offline   Reply With Quote
The Following 2 Users Say Thank You to UncleFester For This Useful Post:
ToxicSneakers (06-18-2012), whataboutbob (07-12-2013)
Old 06-14-2012, 12:36 AM   #37
Max Schnell
In autocross you are starting from a stand still correct? I think timer starts when you pass the laser at the line? A faster initial launch will help decrease your total time I would think. 0-60 foot time is what I am curious about.
Old 06-18-2012, 02:45 PM   #38
vividracing
vividracing's Avatar
Ha, All the GT-R owners are crying right now.
vividracing is offline   Reply With Quote
The Following User Says Thank You to vividracing For This Useful Post:
MatthewFRS (09-05-2016)
Old 06-21-2012, 04:39 AM   #39
ravnos04
Drives: 2010 PB Evo X
on your cars in 'manual' mode is there a neutral gear? And yes i'm sure there will be a 'launch control' function added once you can tap into the ECU fairly soon.
these platforms are all the hype and lots of companies/independent people will be messing around.
ravnos04 is offline   Reply With Quote
Old 07-25-2012, 11:40 PM   #40
Synack
Boosted
Synack's Avatar
Drives: Sideways
YES even in manual. It was so annoying to have to pull a frickin fuse to do a standstill burnout
My tires still found a way to end up wired and shredded and destroyed though
Currently have 4 shredded ones on the porch as a table and 3 Nismo rims that got F'd up whilst drifting and other nonsense. NOT cheap wheels. Wholesale was ~$900 a wheel.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 07-11-2013, 04:50 PM   #41
VictorKassil
[||•(==(86)==)•||]
VictorKassil's Avatar
Drives: WRB Subaru BRZ Series.Blue
Send a message via Yahoo to VictorKassil
Try revving in neutral and then shifting into drive at your desired rpm.
"Guys, I'm bringing the party to you!"
-Tony Stark
______________________________________
VictorKassil is offline   Reply With Quote
Old 07-11-2013, 04:50 PM   #42
OrbitalEllipses
Drives: Attitude
Fr-s launch RPM F3dzo Scion FR-S / Toyota 86 GT86 General Forum 14 04-21-2016 07:11 PM
86 Pre-Launch Brochure newft86 AUSTRALIA 17 05-21-2012 02:51 AM
Launch Control on Auto? devinclfalcons Engine, Exhaust, Transmission 28 03-01-2012 07:14 PM
UK Launch. FT-86 is called GT 86 mrxandthexfactor Scion FR-S / Toyota 86 GT86 General Forum 1 11-26-2011 11:08 PM
Edmunds target launch 1660 Scion FR-S / Toyota 86 GT86 General Forum 49 08-18-2011 04:56 PM
