Old 01-22-2016, 06:17 PM   #1
jmh128
Drives: 2016 BRZ Hyper Blue
Dashboard gauge lights
Question: Am a new 2016 BRZ owner. On every other car I've owned, when driving during the day, the dashboard gauge lights become lit (usually white) and can be adjusted in their intensity.
On the BRZ, this does not happen…..no dashboard gauge lights until I turn on the headlights or parking lights. It's a bit annoying when it's too light outside to turn on the headlights yet but dark enough where the gauge lights are hard to discern.
So…is this normal for this car?
jmh128 is offline   Reply With Quote
Old 01-22-2016, 06:27 PM   #2
acetothermus
Drives: Flying in a Blue Dream
Sounds like someone turned the brightness down. There is a dial (like a scroll wheel on a mouse) on the dash right next to the head light levelling dial. Check to see if it's turned all the way down.
edit: looks like this...
acetothermus is offline   Reply With Quote
Old 01-22-2016, 08:45 PM   #3
jmh128
Thanks acetothermus. Yes I'm familiar with the brightness scroll. I always leave it in the maximum brightness position and at night, the red lights are very bright, as I prefer. But they don't have any effect on the gauges during the day. And I don't see anything in the manual about adjusting the lights during the day.
Old 01-22-2016, 09:08 PM   #4
dinoniel
Theres no backlight on the dash during the day for the dials. Probably a cost saving decision as opposed to the lit and fully digital gauges we see on more expensive cars.
Side note: If you have the dimmer wheel turned all the way up (past the final "click") then your navigation screen won't go into night mode during the nighttime.
dinoniel is offline   Reply With Quote
Old 01-22-2016, 09:08 PM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
During the day they are off and will never be on the car is built this way. If you set your headlight switch up 1 position it turns on your marker lights and tail lights but the headlights stay off. This also turn the dash lights on. Position 2 turns the headlights on in addition to all the other lights.
I tend to just turn the marker lights on and leave my headlights off at dawn and dusk, mainly because my 55W HID's are way to bright and I rather not be the **** blinding people.
Old 01-22-2016, 09:59 PM   #6
jmh128
Thanks dinoiel. Just the information I was looking for. I'm just glad there was nothing wrong with the car.
Old 01-22-2016, 11:33 PM   #7
ryoma
ryoma's Avatar
the BRZ lights up the needles still with the lights off. what else do you need lit up? you also have a digital speedometer. I never even look at the analog speedo lol. I rarely even look at the RPM needle. but you should be able to tell when to shift with the sound of the car and by just making out how far up the needle is. there is really no need for the whole cluster to light up during the day
Old 01-23-2016, 08:21 AM   #8
Ashikabi
Ashikabi's Avatar
You could rewire the switch if it bothers you that much
Old 01-23-2016, 10:24 AM   #9
jmh128
Hah! Thanks for the suggestion but am not about to mess with the wiring. Mainly, just wanted to know if it was normal that the gauges didn't light in daytime.
Thanks to all!
Crazy dashboard lights won't go out babydriver Issues | Warranty | Recalls / TSB 29 12-15-2015 06:47 AM
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 12:48 PM
Replacing Gauge Cluster Lights Zan Southwest 2 04-15-2015 10:09 AM
changing the dashboard lights? JoonPrime Cosmetic Modification (Interior/Exterior/Lighting) 2 10-01-2014 03:11 PM
Gauge Lights Change Color In Traction Off Mode dkrou351 Cosmetic Modification (Interior/Exterior/Lighting) 12 04-18-2013 08:49 PM
