Old 12-14-2015, 07:55 AM   #1
babydriver
Hit the road and I'm gone
babydriver's Avatar
Crazy dashboard lights won't go out
There didn't seem to be an appropriate place to post this question in the sub forums, so I will place it here.
This morning I was leaving for work. About 1 minute after I started the car it threw a CEL code. About 2 minutes later, the traction control light came on and stayed on. I tried the on/off switch several times for this feature; no dice, it stayed on. When I set the cruise control, it didn't come on, but the light did. I turned off cruise but the light stayed on also.
I tried restarting the car, but the same lights came on and stayed on. None of the other dashboard warning lights are on. None of these systems would appear to be connected to each other.
Before I take this to the dealer for warranty work, is there some simple issue that I can fix myself?
Thanks.
Slip, slidin' away.
Old 12-14-2015, 08:11 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Thanks.
If you have a cam issue (among other things) they will both come on as your traction control may not work properly due to an issue the engine is having. I would take it to the dealer if the codes don't go away on their own by the end of the day
Old 12-14-2015, 08:13 AM   #3
Cole
Not a troll
Cole's Avatar
Cruise won't work if you have a CEL. But, I do believe the Slip light coming on is a bad thing.
Old 12-14-2015, 08:19 AM   #4
That is the famous "limp mode" that you have probably heard of. It usually appears for the more important CEL issues. The only way to deal with it is to read the code and correct the issue. If you do not have the equipment to read the code then the dealer is the only answer. Don't drove it too long before getting it dealt with though.
Old 12-14-2015, 08:21 AM   #5
Ashikabi
Ashikabi's Avatar
I had this same problem when I wrecked my car. That was a year ago so my memory is kinda foggy, pretty sure it was my ABS sensor that ended up fixing it. Make sure it's not damaged and not loose
Old 12-14-2015, 08:26 AM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Yeah it could also just be a wheel speed sensor
Old 12-14-2015, 08:35 AM   #7
Ashikabi
Ashikabi's Avatar
Shit, maybe that was it, ABS was the only sensor I could think of on the wheel but I think you're right.
Old 12-14-2015, 08:38 AM   #8
Depending on the CEL code of course it could be any sensor in the car. Limp mode is not restricted to brake or control sensors.
Old 12-14-2015, 08:40 AM   #9
Ashikabi
Ashikabi's Avatar
Check all sensors on the car.
Old 12-14-2015, 08:47 AM   #10
You have any idea how many that is or where they all are??????
And how do you "check" them?
Just reading the code will tell exactly what the problem is without messing around guessing.
Old 12-14-2015, 08:54 AM   #11
Ashikabi
Ashikabi's Avatar
Obviously I'm joking. I thought about googling exactly how many sensors there are just too spite you but I'm too lazy.
OP, since you have the exact problem I did including the traction lights, I would lean toward a wheel or brake sensor since those seen lie they would have the most impact on traction control. I expect the CEL and cruise are a byproduct of the limp mode. A scan should point you in the right direction though
Old 12-14-2015, 08:59 AM   #12
The traction control light comes on regardless of the CEL. It is part of the limp mode indicator. Could be a cam sensor or even a MAP issue.
Old 12-14-2015, 09:02 AM   #13
Ashikabi
Ashikabi's Avatar
So traction control doesn't work if your cam is out if position? That just sounds irresponsible
Old 12-14-2015, 09:17 AM   #14
Actually you can't turn it off and the ECU restricts revs among other things when in limp mode. The car pretty much shuts down to the basics so that you can not push it too hard and make things worse. That is why it is called "limp mode".
I actually wish that some of my old cars had such a thing as it would have saved me thousands of dollars if the car had just said "I don't feel good and don't want to do that right now".
changing the dashboard lights? JoonPrime Cosmetic Modification (Interior/Exterior/Lighting) 2 10-01-2014 03:11 PM
WTB: Dashboard markkisl Want-To-Buy Requests 0 09-12-2014 11:29 PM
Dashboard Camera? DarrenDriven Electronics | Audio | NAV | Infotainment 26 03-09-2014 04:28 PM
FT : my BRZ dashboard for your FR-S dashboard wrb Interior Parts (Incl. Lighting) 2 09-25-2013 04:04 AM
Dashboard Decals! PelzerC Cosmetic Modification (Interior/Exterior/Lighting) 2 05-13-2013 11:31 PM
