Old 01-05-2016, 01:23 AM   #743
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
http://www.ft86club.com/forums/showt...t=52992&page=6
Toyota86.ir is offline   Reply With Quote
Old 01-21-2016, 09:42 PM   #744
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
Jackson Racing C38 Supercharger System Now Available!
We are happy to announce we now offer a C38 version of our FR-S/BRZ supercharger system now. And it is CARB legal. Pick your poison.
Jackson Racing is offline   Reply With Quote
The Following 8 Users Say Thank You to Jackson Racing For This Useful Post:
*LongFella (01-21-2016), aslanteye (01-21-2016), BigFatFlip (01-22-2016), Bykov (01-22-2016), CSG Mike (01-21-2016), dj2020 (01-21-2016), Jmonty (01-21-2016), Rapiddan45 (01-21-2016)
Old 01-21-2016, 10:41 PM   #745
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Can't wait for mine.......
Jmonty is offline   Reply With Quote
Old 01-21-2016, 10:47 PM   #746
Hicklinc
Drives: N/a
Curious when are you going to have the dyno numbers
Sent from my SM-N910T using Tapatalk
Hicklinc is offline   Reply With Quote
The Following User Says Thank You to Hicklinc For This Useful Post:
Alltezza (01-21-2016)
Old 01-21-2016, 11:20 PM   #747
aslanteye
aslanteye's Avatar
Drives: 2014 base frs
So what is the route I should go if I wanna upgrade my kit?
aslanteye is offline   Reply With Quote
Old 01-21-2016, 11:22 PM   #748
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Oh my god I just jizzed, I gotta see some dyno numbers now!!!!!! I MUST HAVE THIS!!
Alltezza is offline   Reply With Quote
Old 01-22-2016, 01:29 PM   #749
Jackson Racing
Drives: JR FR-S,
Our CARB systems produce the same power, C30 or C38.
Old 01-22-2016, 01:37 PM   #750
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Wat
Sent from my MotoE2(4G-LTE) using Tapatalk
ScionOfHorus is offline   Reply With Quote
Old 01-22-2016, 02:15 PM   #751
aslanteye
aslanteye's Avatar
That makes sense it just gives us the room to make a ton more power by getting a different tune compared to the c30. And for people who don't necessarily want to swap out parts for carb its as simple as swapping maps
Old 01-22-2016, 02:51 PM   #752
Lord09
Drives: 2015 BRZ
Same power as in peak numbers? Or are the curves ~exactly the same?
Lord09 is offline   Reply With Quote
Old 01-22-2016, 03:45 PM   #753
sw20kosh
Drives: 2013 Black FR-S
It is not a tune issue. It is a octane and knock threshold issue. All these supercharger kits are limited by knock on pump gas and thus can only achieve a certain power level before having to pull timing.
The c38 allows you to achieve higher boost and power on higher octane than the c30 does.
If someone is sure they are staying on pump gas, the c38 will not be any better than a c30.
The Following 3 Users Say Thank You to sw20kosh For This Useful Post:
CSG Mike (01-22-2016), funwheeldrive (01-27-2016)
Old 01-22-2016, 03:50 PM   #754
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
The simple answer is: CARB exemption. If it meets that, then the specifications are fairly specific to meet those requirements. No tune/map is going to suddenly turn this kit to power level over 9000. Of course, if you want to do that, then the steps needed to make that power are similar to how you would improve power output with the C30 unit. For example, increasing boost pressure somehow correlates to improved power output...
CounterSpace Garage is offline   Reply With Quote
Old 01-27-2016, 12:32 PM   #755
Aaronimoe
What supporting mods would you recommend, if any, for someone who never plans to track their car?
The C38 kit with intercooler seems like it would be enough as is!
Edit:
Also, are most people receiving E-tunes with ECUtek? or are yall going to tuners with dynos?
What features do you get with Ecu-tek? can you read AFR's and such?
Aaronimoe is offline   Reply With Quote
Old 01-27-2016, 03:26 PM   #756
Jackson Racing
Drives: JR FR-S,
Edit:
No supporting modifications are needed with our Factory Tuned C30 or C38 systems. Everything required for the system to run perfect on a stock car is included.
The Factory Tuned systems include EcuTek ProECU Programming Kit and our Jackson Racing Flash Drive with CARB Calibration. The Factory Tuned system is our more common system choice.
EcuTek allows you to datalog many parameters of the system, but requires a laptop to be hooked up to datalog.
jackson racing, jrsc, rotrex, supercharger, track
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 03:28 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
