Old 11-19-2015, 04:43 PM   #197
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I'm actually headed to the shop in about an hour and a half to go pick it up. I have an appointment at work first, though.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
The Following User Says Thank You to slicktop For This Useful Post:
MisterSheep (01-20-2016)
Old 11-19-2015, 04:45 PM   #198
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
so who will be rewiring a new harness for you? just for reference.
Old 11-19-2015, 04:49 PM   #199
slicktop
Trust Automotive in Chesapeake, VA. They've put together pretty much the entire car. Props. Anyone looking for a no BS build, contact them.
-slicktop
2013 Scion FRS
NyC Zn6 (11-19-2015)
Old 11-21-2015, 07:12 AM   #200
slicktop
The car is back home and it's running very well. The video I had, had too much edited out so I'll have to make another one without me talking or giggling like a man-child.
-slicktop
2013 Scion FRS
Old 01-20-2016, 04:55 PM   #201
JTOFJPN
You're like the...
JTOFJPN's Avatar
Drives: '13 6MT FRS / '14 Ram 1500 Sport
Vids vids vids.
Also, would the Adapter+350Z transmission line up the same as a V160 you figure?
2013 Whiteout 6MT FR-S
2014 Ram 1500 Sport
JTOFJPN Build Thread
JTOFJPN is offline   Reply With Quote
The Following User Says Thank You to JTOFJPN For This Useful Post:
Old 01-20-2016, 05:06 PM   #202
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
subbed
Instagram: trevor.parque
slicktop (01-20-2016)
Old 01-20-2016, 08:18 PM   #203
Ross
Drives: 85 corolla gts
You should be able to get the cd009 trans to fit. It is a tight fit with the v160 and the cd009 is a bit bigger. Some sheet metal adjustment may be require. As well the shifter set up will require a modification to make it short enough. It will be very tight. Next up is the Emtron KV8 install. I do not know who is more excited for that, slicktop or me.
Ross is offline   Reply With Quote
The Following User Says Thank You to Ross For This Useful Post:
Old 01-20-2016, 11:37 PM   #204
slicktop
Originally Posted by JTOFJPN View Post
Vids vids vids.
Ross is definitely the one to pay attention to. He's one of very few with extensive knowledge and experience with the 2JZ/FT86 swap.
Additionally, yes, the car is getting an Emtron KV8 instead of the Motec M150. Should be a good fit to my needs at a lesser cost than the Motec. Hope to have the car back out a few weeks from now as we're about to have a blizzard come through the Mid Atlantic.
Vids will come soon after. I've been in contact with some video/photographers to do some professional work. Additionally, I'll be attending Hot Import Nights in Atlanta this year (provided work doesn't get in the way!) so there will be plenty of coverage of the car this year.
-slicktop
2013 Scion FRS
Old 01-21-2016, 10:38 AM   #205
JTOFJPN
You're like the...
JTOFJPN's Avatar
Thank you for the info Ross, what transmission fits the best in your opinion?
2014 Ram 1500 Sport
Old 01-21-2016, 10:48 AM   #206
Ross
We only used the v160 on slicktops car. I just happened to have a v160 and a cd009 sitting on the floor, one from a supra build and the other from a g35 build we are doing. So I took some measurements. I feel the v160 fits well but they are becoming to expensive for what they are sense Toyota has stopped production of them. I would like to get my hands on an ar5 to look over the shifter assembly. See what would need to be done to make that work. As those are relatively cheap and just swap a bell housing to mate to the engine.
Old 01-21-2016, 11:17 AM   #207
JTOFJPN
You're like the...
JTOFJPN's Avatar
I think Omar used a R154 in his as per the IS300 rear end he put in, can you comment on the shifter location for those - in comparison?
I have started my pricing list (see att), it pains me here in Canada with the 1.49CAD->USD exchange right now, but I'm looking to be ready for a swap whenever all your shale oil companies go bankrupt lol.
2014 Ram 1500 Sport
Stigasaur (01-26-2016)
Old 01-26-2016, 12:21 AM   #208
nickg
Drives: 2014 Whiteout FR-S Manual
Have you ever weighed it?
Sent from my XT1575 using Tapatalk
nickg is offline   Reply With Quote
Old 01-26-2016, 09:09 AM   #209
slicktop
I haven't, but I estimate it being about 3,000lbs.
-slicktop
2013 Scion FRS
Old 02-03-2016, 01:46 PM   #210
slicktop
Emtron EMS just came in last night. Looking forward to the new EMS setup. If it all works out, it'll open up a lot of swaps as a direct competitor to MoTeC in regards to CAN functionality at a much less expensive option.
-slicktop
2013 Scion FRS
2jz, 2jz brz gt86 frs swap, 2jz frs, 2jz frs swap, 2jz swap
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
Mr and Mrs FR-S Build jaydee_do_work Member's Car Journals 2 12-04-2013 10:51 AM
86 BUILD, AUS JS86JS Member's Car Journals 9 05-31-2013 09:59 AM
My build... well some of it cruzinbill Electronics | Audio | NAV | Infotainment 41 04-01-2013 05:02 PM
STX build Evil86 Tracking / Autocross / HPDE / Drifting 2 01-08-2013 04:40 PM
