Old 01-19-2016, 11:44 PM   #15
stevemp5
Drives: scion fr-s
Originally Posted by kevinchavarria View Post
Did yours look similar like the picture above?
same thing, even worst
stevemp5 is offline   Reply With Quote
Old 01-19-2016, 11:44 PM   #16
kevinchavarria
Drives: Scion FR-S
Do you know what caused it? And has it came back since you cleaned it out?
kevinchavarria is offline   Reply With Quote
Old 01-19-2016, 11:56 PM   #17
stevemp5
Drives: scion fr-s
here we call that winter loll but for you in texas I remove all that shit with metal polish and scotch brite
The Following 2 Users Say Thank You to stevemp5 For This Useful Post:
flippy (01-21-2016), Tcoat (03-21-2016)
Old 01-20-2016, 11:12 AM   #18
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
That is galvanic corrosion. It happens when you take 2 dissimilar metals, put them in contact with each other, and introduce an electrolyte.
In your case, it is the stainless steel cam solenoid covers acting as an anode for the aluminium engine block. From your other pictures, all the other steel/stainless steel fixtures are suffering the same fate.
The stainless cam solenoid covers have got the kind of galvanic corrosion I usually see on outboards recovered from the bottom of the ocean.
The frame should be completely fine... As long as the paint and anti-rust coating on the bottom hasn't been seriously compromised.
But wow... Just wow.
I'm trying to think how that much corrosion could have happened in such a short time though. What was the environment / history of the car? Lots of salt, lots of water... Winter? Ocean climate? Left abandoned along a seawall in the direct spray for 6 straight months?
I've seen that kind of galvanic corrosion on neglected outboard motors, which are left literally hanging in the ocean for months, or on cars that have spent their entire life driving winters in the rust belt... But never on a car that new.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following 2 Users Say Thank You to Spartarus For This Useful Post:
FRS Justin (01-20-2016), new2subaru (01-20-2016)
Old 01-20-2016, 11:31 AM   #19
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
OR you can get these
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 01-20-2016, 11:32 AM   #20
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
Any chance you've had a leaky battery? We had a battery get a pinhole crack near the top once on a wrx and shot acid clear across the engine bay, everything had little spatters of rust on it.
Gear_One_Performance is offline   Reply With Quote
The Following 3 Users Say Thank You to Gear_One_Performance For This Useful Post:
flippy (01-21-2016), new2subaru (01-20-2016), Spartarus (01-20-2016)
Old 01-20-2016, 01:07 PM   #21
kevinchavarria
Drives: Scion FR-S
Actually, I need to check that out. Never thought to check that, I will keep you guys updated. Appreciate all the comments!
Old 01-20-2016, 05:31 PM   #22
FRS Justin
Drives: 2013 Asphalt FRS
It was purchased in Texas, but from what I remember it was first driven in the Oklahoma area.
Looks like it was drove on the beach in Texas and saltwater did its thing.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 01-20-2016, 05:32 PM   #23
kevinchavarria
Drives: Scion FR-S
Will it cause any damage in the long run?
Old 01-20-2016, 06:13 PM   #24
Oh, I don't think so.
Like mentioned, just clean it up and give it a shot of anti-rust stuff every now and then.
Old 01-20-2016, 06:24 PM   #25
FRS Justin
No its just cosmetic, just clean it up and your good to go
710whp
Old 01-20-2016, 06:50 PM   #26
kevinchavarria
Drives: Scion FR-S
😅 I was sweating about it. Haha.
The Following User Says Thank You to kevinchavarria For This Useful Post:
Old 01-20-2016, 06:57 PM   #27
FRS Justin
If you have warranty take it to the dealer maybe you can get some free stuff.
710whp
Old 03-21-2016, 02:42 PM   #28
wolfer
Drives: 2016 Scion FR-S
I live on the Oregon coast. I have a boat and commercial fishermen here swear by a couple of products. One is Corrosion Block and another is Corrosion X It is not cheap but will stop corrosion immediately and will protect your alluminum and electrical connections from getting corrosion. You can buy corrosion block at Napa in a spray can or you can find it on the coast or on line at places like West Marine. You just spray it over the whole engine compartment and it will dry with no residue. You can buy it in the larger size for about 35 dollars and get your own sprayer or buy the spray cans from Napa for under 20 dollars. It is very very good for electrical contacts. and will not rust or corrode after application you might want to spray it every two or 3 years. Best products there are for rust or corrosion. also if you live near the beach or salt water environment you can spray the whole car down with salt away or salt terminator. I run it thru my outboard motor to keep salt crystals from clogging my water jackets then spray the whole boat down and the salt disappears and paint looks like new again. You can use it on cars too. Just use a hose end sprayer for weeds.
wolfer is offline   Reply With Quote
The Following User Says Thank You to wolfer For This Useful Post:
nos145 (05-16-2020)
EcuTek Need Some Answers Tboxer Software Tuning 2 11-18-2014 12:12 AM
I need some answers.. All is welcome! TheSlickOne17 Engine, Exhaust, Transmission 12 06-27-2013 10:56 AM
Answers Razz Scion FR-S / Toyota 86 GT86 General Forum 2 02-18-2013 05:44 PM
Rust? even with rust proofing? Chinadian Issues | Warranty | Recalls / TSB 8 01-26-2013 04:15 PM
We need a questions and answers forum.. Exhaust Off-Topic Lounge [WARNING: NO POLITICS] 11 04-17-2012 01:22 AM
