Old 01-20-2016, 10:43 AM   #15
j0hnnybk01
Drives: Firestorm FR-S
Okay so i got a new 02 and still got the same thing going on . next is a maf going to return the 02 . I am really hoping its the MAF
j0hnnybk01 is offline   Reply With Quote
Old 01-20-2016, 02:10 PM   #16
j0hnnybk01
okay so i started the car by unplugging the 02 sensor then plugged it back in . let it run until it just shut off . my codes are now
p0102 Mass or Volume Air Flow Circuit Low Input
p0462 Fuel Level Sensor "A" Circuit Low
p0113 Intake Air Temperature Circuit Low Input
p0031 Oxygen Sensor Heater Control Circuit High (Bank 1 Sensor 2)
Old 01-20-2016, 03:39 PM   #17
j0hnnybk01
Borrowed maf from another frs and still have the same issue.
Old 01-20-2016, 10:48 PM   #18
steve99
Drives: FT86
were those new codes or ones that may have been stored in ecu.
remove battery and press brake pedal to reset ecu
then check for codes again they might have been old ones
The intake air temp sensor is in maf sensor i believe.
fuel circuit is weird.
check maf connections.
check battery/alternator volts
check earth connection
check any other wiring you altered or moved
check for air leaks, especially catch cans and pcv valves blow off valves ..
Old 01-21-2016, 12:01 AM   #19
j0hnnybk01
those are the new codes . maf connections are good . grounds have not been removed . changed my pcv valve back to stock because i put a sti one on and still the same . I'm thinking its the throttle body . i poked it to see if i needed to clean it and now i think it is off. it says 0% when its not closed all the way and 95% wot . whines/ buzzes really loud when the key is on the ON position . i have tried to reset it by unplugging the battery for 30 min and plug it back in but still the same . i will be trying a throttle body next . $100 on ebay for a used one . that is the only thing i can think of . the car is putting out a lot of fuel when i try to start it and my oil is starting to smell like fuel because of it .
Old 01-21-2016, 03:05 PM   #20
j0hnnybk01
well i tried my best but can not figure it out . so its at my brothers shop maybe they can figure it out
Old 01-21-2016, 03:45 PM   #21
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
"The bank 1 sensor 2 circuit" is the rear o2 sensor control circuit. It runs in parallel to the front heater circuit, off the same relay.. Damage to 1 will affect the other. You may have been searching the wrong sensor for wiring damage.
The IAT is in the MAF, so the 2 MAF-associated codes indicate a MAF problem as well.
The fuel code is strange, until you realize that the VSV runs in paralell to the rear o2 sensor as well. Damage to the wiring will/can affect the vacuum switching valve. (EVAP purge) which will screw with the fuel sensor.
The positive wire for that circuit also supplies the MAF, the throttle body motor, oil and coolant temp, fuel pressure, knock 1 and 2, with positive current.. If you unplug the rear o2, your problems may vanish.
Or, if the bad wiring has caused damage, you will have a lot of things to replace.
But, a short in the rear o2 heater circuit would explain all of your problems, all of your codes, and the strange noise from the throttle body.
It's the red and yellow wire in the rear o2 bundle. It becomes black and yellow at the engine, and then coterminates with a yellow and black wire that supplies current to all of the other sensors and systems I mentioned.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following 2 Users Say Thank You to Spartarus For This Useful Post:
j0hnnybk01 (01-21-2016), steve99 (01-21-2016)
Old 01-21-2016, 09:36 PM   #22
j0hnnybk01
I have to say you are one hell of a guy helping me diagnose this problem ! i never had this much help on a forum before . i will try that when i go up to the shop tomorrow morning . hoping it wont be a fried ecu or need a new harness .
The Following User Says Thank You to j0hnnybk01 For This Useful Post:
Spartarus (01-21-2016)
Old 08-28-2017, 12:13 PM   #23
Kris86
Kris86's Avatar
Drives: RHD Gt86
did you ever get this issue sorted?
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Gutting primary cat? jordanrw260 Engine, Exhaust, Transmission 6 07-30-2018 11:24 PM
Accidentally unplugged a pressurized air hose on radiator? G-awesome Issues | Warranty | Recalls / TSB 4 08-28-2015 01:43 PM
WTB Primary o2 sensor Frs300 Want-To-Buy Requests 0 08-22-2015 04:45 PM
1.75 primary too big for fa20? dipsticktuning86 Engine, Exhaust, Transmission 2 10-31-2013 07:31 AM
