Old 08-28-2015, 12:04 PM   #1
G-awesome
Drives: 2015 Firestorm Scion FRS
Accidentally unplugged a pressurized air hose on radiator?
So I was replacing bolts in the engine bay yesterday with the z-spec dress up kit and I accidentally unbolted a pressurized hose coming out from the radiator to the engine (see pic below). I was able to bolt the sucker back on but it slowly leaked pressurized air (or gas?) out until it slowed down and stopped. Anyone know what I did and if I mucked something up with the ac system?
I'm not a expert with the workings of radiator/ac system. The car drove fine this morning with no CEL but I was testing the ac system on the way to work and it seems like the ac doesn't really blow cold air anymore? Not sure if I let out some gas coolant to chill the air on the ac system.
G-awesome is offline   Reply With Quote
Old 08-28-2015, 12:13 PM   #2
SkiRideDrive
SkiRideDrive's Avatar
Drives: 2015 FRS
Pretty sure that is an ac line and you will need a recharge.
2015 FRS Ultramarine.
SkiRideDrive is offline   Reply With Quote
Old 08-28-2015, 12:14 PM   #3
SkiRideDrive
Drives: 2015 FRS
I would also check to see if you blew any seal/o-ring/gasket when you released the pressurized system through that point without purging it first.
Old 08-28-2015, 12:28 PM   #4
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
That is the line coming from the ac condenser to the compressor. You let the refrigerant out of the system. Do not run the air conditioner until you get it checked out and recharged.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 08-28-2015, 12:43 PM   #5
G-awesome
Perfect. Pretty sure I blew the seal as well....Thanks for the help and advice! I'll get it checked out this weekend! Me and my damn curious monkey ways....
FS: Mishimoto silicone radiator hose kit for BRZ/FRS ($155) dcfr Canada Classifieds 0 08-12-2015 10:48 AM
Perrin Radiator Hose Oburn Engine, Exhaust, Transmission 8 06-19-2014 05:13 PM
NPA: Mishimoto FR-S/BRZ Silicone Radiator Hose Kit 86_Insider Engine, Exhaust, Transmission 0 08-19-2013 09:43 PM
ZetaPerformance 6PC Radiator Hose Kit Installed Lverasky Engine, Exhaust, Transmission 9 04-19-2013 12:04 PM
Fuku Works Radiator Hose Kit Mach V Dan Engine, Exhaust, Bolt-Ons 4 09-12-2012 11:22 AM
