Old 01-20-2016, 01:04 AM   #15
yip
Drives: 1997 Chevy S10
I just installed coilovers and RE71R's and I noticed immediately that the steering felt much lighter.
yip is offline   Reply With Quote
Old 01-20-2016, 01:37 AM   #16
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
To @BDotG: Do you have adjustable caster/camber plates installed? If so, what are your alignment numbers for front caster, camber, and toe, and rear camber and toe? A 1.8" drop is not insignificant, so have you made any effort to correct the roll center - this can definitely affect steering feel.
This post is old, so if you've already solved the issue, please let us know what you did to fix it.
Last edited by RJasonKlein; 01-20-2016 at 01:38 AM. Reason: Corrected a typographical error.
RJasonKlein is offline   Reply With Quote
Old 01-20-2016, 06:17 AM   #17
Tor
Tor's Avatar
Drives: Toyota GT86
What exactly you do you mean it "feels light"? Can you describe a situation, your actions and the response of the car in details?
Tor is offline   Reply With Quote
Old 01-20-2016, 10:18 AM   #18
twag4
Drives: frs
I'm telling you, install the anti dive/caster correction kit from whiteline. Then enjoy a little heavier steering wheel, and improved correction to center- plus improved feel and feedback. You will not be disappointed. This car loses caster when lowered. That adds to the vagueness.
twag4 is offline   Reply With Quote
Old 01-20-2016, 10:24 AM   #19
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
little off topic but when I go back to stock height for winters do you think the white line roll center kit will have much of a negative impact? Or are we talking about different parts lol
Old 01-20-2016, 11:51 AM   #20
ZHoward
ZHoward's Avatar
Drives: 2013 brz limited
yes, after install kw v3 i feel much lighter
ZHoward is offline   Reply With Quote
Old 01-20-2016, 11:52 AM   #21
BDotG
BDotG's Avatar
Drives: Asphalt 2013 FR-S
I think ultimately I realized it was a combo and slightly stretched tires & wide wheels spacers (surprised it took me that long to figure that out).
I have since moved to some meaty ass tires on wider rims and the set up feels perfect.
Just had a performance alignment done and current at -1.1 camber front and -1.5 rear. Car feels planted.
BDotG is offline   Reply With Quote
Old 01-20-2016, 11:53 AM   #22
BDotG
BDotG's Avatar
I am wondering if any of this could be attributed to less weight on the steering. My coilovers were definitely lighter than my stock struts with springs.
Old 01-20-2016, 11:53 AM   #23
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Why more camber in the rear? ?
Old 01-20-2016, 01:20 PM   #24
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Again, what are the caster numbers?
The top hats that came with the coilovers could be changing the caster which would make the steering light. I've seen quite a few setups where the top hats are basically the same part, bolts go in one hole or the other or they're mirror images, if installed incorrectly they could reduce caster giving a lighter steering response, slow return to center, and general vagueness as now the power steering is too strong for the system.
If the caster number isn't on your alignment sheet then they cut corners.
Well that is the OE specs for the rear and about what camber bolts get you in the front, for most people tire wear takes priority over maximum grip.
ineedyourdiddly
Old 01-20-2016, 01:23 PM   #25
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Ahh makes sense. I am planning on running -2.5 and -1.5 this spring
Old 01-20-2016, 03:28 PM   #26
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
How is the camber set at the top mount and the hub?
You may be observing reduced steering effort due to a reduction in absolute scrub radius.
I followed Racecomp Engineering's recommendation and have my dampers mounted so the front strut is as vertical as possible by maxing out negative camber at the hub for improved SAI.
If the kingpin axis intersection point is outboard of the center of the contact patch it is negative, if inside the contact patch it is positive. The term scrub radius derives from the fact that either in the positive or negative mode, the tire does not turn on its centerline (it scrubs the road in a turn) and due to the increased friction, more effort is needed to turn the wheel.
The greater the scrub radius (positive or negative), the greater the steering effort and the more road shock and pivot binding that takes place.
https://en.wikipedia.org/wiki/Scrub_radius
Good bit of info here on caster, SAI, and camber:
http://www.ft86club.com/forums/showthread.php?t=48107
@CSG Mike or @Racecomp Engineering can shed some more light on this.
JDKane527 is offline   Reply With Quote
Old 01-20-2016, 03:39 PM   #27
CSG Mike
CSG Mike's Avatar
Teflon thrust washer + spherical top + camber reduction via camber plate = formula for lighter steering.
Sounds about right
Old 01-20-2016, 06:22 PM   #28
twag4
Drives: frs
Not the roll center correction kit, I have it too. And yes the car would need realigned with either kit when ride height is changed. Even without either kit it needs realigned when ride height is adjusted that much. The anti dive/ caster correction kit is the front control arm bushing in the front location of the arm that has an offset hole that adds caster to the front wheels. The roll center correction kit brings the roll center closer to ground level. Some argue that it isn't necessary, but I can testify that the sum of all of the above parts, plus energy suspension rear bushings in all locations that don't already have pillow ball/cross axis bushings, is an even more amazing and responsive car.
coilovers, light, steering
ABS and Slip Light on after steering wheel re-install Yamajee Issues | Warranty | Recalls / TSB 11 03-29-2017 12:56 PM
Best Steering Wheel Column for Feel - Rake and Reach brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-21-2015 09:24 PM
OEM Steering Wheel Reinstall...Light Still On? dizzario Electronics | Audio | NAV | Infotainment 13 06-22-2014 09:23 PM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 04:52 PM
Steering Wheel Feel ap5512 BRZ First-Gen (2012+) — General Topics 8 12-08-2011 11:16 AM
