Old 06-12-2014, 12:16 AM   #1
dizzario
Drives: FRS
OEM Steering Wheel Reinstall...Light Still On?
I've never been savvy on all the electrical jazz, but I'm wondering if the airbag light will just go way once I drive the car for a bit. I'm positive I reinstalled it correctly:
Orange to orange, black to black, cruise control, airbag. Only 4 'plug-ins'.
It's going to be garaged for the rest of the month but any responses are appreciated.
-D.
dizzario is offline   Reply With Quote
Old 06-12-2014, 08:07 PM   #2
dizzario
Drives: FRS
...anyone? I'm sick of feeling like I'll be decapitated...
Old 06-13-2014, 01:06 PM   #3
dizzario
Drives: FRS
Duuuuuuuude I know one of you 98 viewers thus far has had to put your OEM stuff back on...
Old 06-13-2014, 01:27 PM   #4
xxscaxx
Drives: 2013 SWP BRZ
No experience taking this wheel out but after disconnecting the steering wheel/airbag on my 05 sti a bunch of times the light always shut off after a few seconds of it being on. Did you try to d/c the battery?
xxscaxx is offline   Reply With Quote
Old 06-13-2014, 03:36 PM   #5
jonzhuxD
Drives: Ultramarine FR-S
I've taken my wheel out twice so far, both times to get access to the turn signal stalk (foglights and auto headlights) and had my airbag out 4-5 times (steering wheel badge and the turn signal stalk) and each time I have had no issue with the airbag light.
Just two days ago I had it out and after plugging back the connections, started up my car and drove down the street before pushing the bag back in (didn't want to piss off neighbors by blowing the horn at midnight) and the light was off. Not sure where your issue lies.
I know the above wasn't very useful but I wanted to give you a little feedback from my experience
jonzhuxD is offline   Reply With Quote
Old 06-13-2014, 08:26 PM   #6
dizzario
Drives: FRS
Yeah I just replaced my aftermarket wheel with the OEM one. Same things had to be done as far as what's removed, so this info is useful. I made sure the clockspring wasn't turned as well...
Old 06-13-2014, 10:18 PM   #7
dizzario
Drives: FRS
Well, the battery was disconnected while I did the install. Are you suggesting that I disconnect it again and see? I'll have to give that a shot...
Old 06-15-2014, 10:18 AM   #8
jonzhuxD
Keep us updated!
Old 06-15-2014, 10:33 PM   #9
dizzario
Drives: FRS
Keep us updated!
Well all I've done is disconnected the battery and reconnected it again. No luck. I'll most likely end up taking it off and putting it on again...FML.
Old 06-22-2014, 03:30 AM   #10
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I've removed my steering wheel and airbag twice (steering wheel swap on the first and light switch stalk swap on the second), both times I left the battery connected. I didn't get the airbag light after I just made sure not to switch the key to position 1 or 2 with the airbag disconnected.
I didn't disconnect the battery because I could just clear the airbag light with techstream if it did come on.
HRTROB is offline   Reply With Quote
Old 06-22-2014, 09:39 AM   #11
iketiak
iketiak's Avatar
Drives: 2013 Toyota 86/Scion FRS
Is it only the airbag light or the Tract control and VSC light are also on? If all those lights are on the clock spring may have been damaged and needs to be replaced. A single airbag light may be something different, see if you can get a OBDII code reader to find out what code it is.
iketiak is offline   Reply With Quote
Old 06-22-2014, 11:01 AM   #12
dizzario
Drives: FRS
I'm gonna have to dig out my scan tool. It's the airbag light only and at this point I might just reinstall my aftermarket wheel haha.
Old 06-22-2014, 11:23 AM   #13
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
I've switched out the OEM wheel for another OEM wheel about 5 times (alcantara and misalignment). I always unplugged the battery beforehand. I have not had the airbag light come on.
I would suggest using the techstream or other Subaru specific tool to get/clear the code. You regular obd II scanner prob won't cut it unfortunately.
robot is offline   Reply With Quote
Old 06-22-2014, 09:23 PM   #14
troek
troek's Avatar
Drives: 2012 Toyota 86
did you check all your fuses? thats always a good place to check whenever you have an odd electrical issue.
WTB: Stock steering wheel (wheel not airbag) mobybrz Interior Parts (Incl. Lighting) 2 09-11-2014 02:23 PM
scion frs steering wheel air bag and steering wheel Jhon19lopez Interior Parts (Incl. Lighting) 7 01-04-2014 06:04 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-20-2013 11:45 PM
Steering has become lazy/light after 1200km scottrichardson Scion FR-S / Toyota 86 GT86 General Forum 57 09-18-2013 01:38 PM
light steering angle improvement alexmotrix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 03-17-2013 02:38 AM
