Old 01-20-2016, 12:26 AM   #1
wise345
Slow I am, boost I must..
wise345's Avatar
Drives: Whiteout 2013 FRS
Advice for when the CEL comes on…
Installed P&L EL Headers and no CEL yet but if it does come on should i get a tune then or wait a year or so until i go FI and i'll need a tune regardless? I am considering HKS V3, PTuning, or SBD for FI if it makes a difference.
Running with a CEL won't hurt anything correct? Im not worried about peak gains from the header since boost is on the way…
What do the FT86 experts think is my best route for when that light comes on?:thumb up:
(Mods i placed this thread where i think is best considering it fit in three categories so feel free to move it if needed )
wise345 is offline   Reply With Quote
Old 01-20-2016, 01:30 AM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Since you're going FI soon with a tune anyway I would say just wait, or if it the light comes on and starts to annoy you do the O2 spacer trick and see if that helps. Unless of course there's a state inspection in the near future between going FI and getting a tune, otherwise you'll fail inspection most likely without that tune.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
wise345 (01-20-2016)
Old 01-20-2016, 01:43 AM   #3
steve99
Drives: FT86
most turbo kits are require their own specific header/manifold, meaning your new headers wont fit with most turbo kits.
generally headers can be used with Superchargers.
if your going with the SBD kit you might consider the openflash tablet for tune as oft does free tunes for the sbd turbo kits and they do tunes included for headers E85 ect on naturally aspirated cars.
the P0420 cel code will disable your cruise control when its active and having cel light on may mask more serious issues.
you can reset cel with battery removal, or an obd scanner.
Or you can try a 02 spacer in second 02 sensor to try to fool ecu that cat is still their
The Following 2 Users Say Thank You to steve99 For This Useful Post:
FRSBRZGT86FAN (01-20-2016), wise345 (01-20-2016)
Old 01-20-2016, 08:55 AM   #4
wise345
wise345's Avatar
That's another reason I'm not sure about getting one before FI because if I went HKS there flash editor is a far better way to go tuning wise
Old 01-20-2016, 09:48 AM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I would go ECU TEK if I were you. I use it to tune my car, works great and in my opinion its easier to get a good FI tune with it. I am sure OFT works fine too but there much be a reason almost all FI kits come with a ECU Tek tune
Old 01-20-2016, 09:54 AM   #6
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Not sure what CEL you are expecting, but for some CELs, the VSC & TC will be disabled.
justatroll is offline   Reply With Quote
The Following User Says Thank You to justatroll For This Useful Post:
Old 01-20-2016, 10:06 AM   #7
-Phil
Drives: Rb25 neo brz
A tune is always worth doing whether it be before or after F/I i'd recommend EcuTek so you can take advantage of features that racerom provides
-Phil is offline   Reply With Quote
The Following 2 Users Say Thank You to -Phil For This Useful Post:
go_a_way1 (01-20-2016), wise345 (01-20-2016)
Old 01-20-2016, 10:14 AM   #8
wise345
wise345's Avatar
Sounds like fun
Old 01-20-2016, 10:19 AM   #9
wise345
wise345's Avatar
Racerom is the maps controlled by the cruise control stalk that has the launch control plus E85 maps right?
Old 01-20-2016, 10:26 AM   #10
-Phil
Correct Here is a very detailed write up of most of the features
http://www.ecutek.com/downloads/mark...Fact_Sheet.pdf
The Following User Says Thank You to -Phil For This Useful Post:
Old 01-20-2016, 10:48 AM   #11
wise345
wise345's Avatar
What gains can I expect with an exited tune and a full exhaust apart from over pipe?
Old 01-20-2016, 10:54 AM   #12
-Phil
A full Exhaust with header you'll see around 15 WHP the main difference is the change in the tq dip
Old 01-20-2016, 10:55 AM   #13
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
quick question if cruise control is removed due to aftermarket steering wheel how would one change maps?
Old 01-20-2016, 11:06 AM   #14
-Phil
For switching out maps you hold it towards you rather then just blipping it towards you when you want to set it on cruise
need advice Blue14inTracy Engine, Exhaust, Transmission 13 03-27-2014 08:39 PM
New guy needs advice Apexer Tracking / Autocross / HPDE / Drifting 28 05-04-2013 03:53 PM
Need advice Ikmv Scion FR-S / Toyota 86 GT86 General Forum 7 08-23-2012 12:17 AM
Need advice.. Help.. tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 9 08-13-2012 08:57 PM
Need advice FRSMAK86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-06-2012 05:39 PM
