Old 03-27-2015, 09:26 AM   #15
was385
Drives: MT WRB BRZ Limited, 2007 911s
Originally Posted by jfg5067 View Post
Except looking back, I did my wheels and tires first, and hadn't noticed a difference but had been driving highway only... then did the fluids change and have been driving local+highway... only noticing it greatly now... I am currently on 17x8 Enkei RP03 wrapped in 245**-40-17 Dunlop ZIIs... not LRR, but lighter combo than oem setup.
Comping form someone on essentially the exact same wheel/tire setup (RPF1), that is probably 99% of your fuel mileage difference.
was385 is offline   Reply With Quote
Old 01-18-2016, 09:24 AM   #16
bjreynolds202
Drives: WRB 2013 Subaru BRZ Limited
I'm stock aside from a drop in air filter and averaged 32mpg with my manual. Swapped to motul 300 and now im averaging 28. Found it curious. Have to look further into it as tires are at correct psi, air filter is clean, and driving habits are relatively the same.
bjreynolds202 is offline   Reply With Quote
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Have you changed your tranny fluid of your AUTO BRZ/FRS ScionFR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-14-2017 01:14 AM
Trans/diff fluid recommendations: Motul Gear 300, Extra-S, or.. B-R-Z Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 07-03-2014 08:06 PM
Replacing Trans & Diff Fluid, Hot vs Cold BRZNutt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 12-22-2013 09:04 PM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 03:11 PM
