Old 01-16-2016, 03:41 AM   #29
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Originally Posted by Ketchum88 View Post
Sorry I have just been trying to find a retainer for automatics and have read many threads. I guess I got this one mixed up with another one where someone said that was what you needed to buy.
I understand the thread pitch is 10x1.25 but does it matter which knob I buy because one will say it is for manual short shifters and another will say it is for automatics but they have the same thread pitch.
Thanks
I see!
There are knobs with and without the manual shift pattern, and there are knobs with a retainer for automatic (Perrin etc).
If you buy one without a boot retainer, like I did, you need to get creative.
There should be a market for separate boot retainers for the automatic, so I expect someone will come up with something. Or maybe someone have by now, IDK.
Old 01-25-2016, 06:41 PM   #30
Ketchum88
Ketchum88's Avatar
Drives: 2013 FR-S Hot Lava
I can confirm that the method of lifting up the entire shift boot trim and then screwing on the retainer makes for simple installation with no need to modify the 10x1.25 retainer sold by sickspeed.
Now I can simply order any manual shift knob I want and swap them out easily.
Ketchum88 is offline   Reply With Quote
The Following 2 Users Say Thank You to Ketchum88 For This Useful Post:
ringo16 (01-25-2016), Sarlacc (01-25-2016)
Old 01-25-2016, 08:23 PM   #31
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Awesome!
Like the color, too. Looks like a good match for a hot lava :-)
The Following User Says Thank You to Sarlacc For This Useful Post:
Ketchum88 (01-25-2016)
Old 01-25-2016, 09:45 PM   #32
Ketchum88
Ketchum88's Avatar
Originally Posted by Sarlacc View Post
Awesome!
I will probably end up buying a few more since they are so cheap, just bought orange because it was the cheapest one
Old 01-25-2016, 11:15 PM   #33
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
I started with two. The one I didn't pick for my 86 I put in my old Nissan truck.
I would like to see some of the new glow-in-the-dark knobs though!
Old 02-07-2016, 03:20 AM   #34
timmydatooth
Drives: Scion Frs
Hey man that looks awesome! Can I get the link for that shift boot retainer? And you said you didn't have to cut it in half or anything right? Does it hold it up nicely like it doesn't slide down or anything?
timmydatooth is offline   Reply With Quote
Old 02-08-2016, 02:36 PM   #35
timmydatooth
Drives: Scion Frs
Can someone get me the link to the correct sickspeed shift boot retainer? I see them on ebay but idk which one is the correct one. Thanks.
Old 02-08-2016, 03:36 PM   #36
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
The one I cut in half to allow the boot to slip over it is probably the same one @Ketchum88 used. As I understand it he took the whole boot assembly apart and screwed the retainer on from underneath.
It will not fit without doing one or the other. Cutting it is probably the fastest way, and allows for easy removal and return to stock.
I don't have a link. It must have 10x1.25 thread, should be easy to find.
Old 02-08-2016, 10:04 PM   #37
Ketchum88
Ketchum88's Avatar
Shift boot retainer
eBay link
This is all you need, I just popped the bezel off and screwed it onto the rod then put the boot overtop of it so it cannot fall down due to its shape.
The Following User Says Thank You to Ketchum88 For This Useful Post:
timmydatooth (02-09-2016)
Old 02-09-2016, 10:26 AM   #38
timmydatooth
Drives: Scion Frs
Shift boot retainer
eBay link
Does it screw onto the rod or just fall down to the bottom? And if you do screw it on is there enough thread left on the rod to screw the shift knob on? Also is the rod exposed at all or does it sit flush on the retainer? Sorry for the questions lol thanks
Old 02-09-2016, 08:44 PM   #39
Ketchum88
Ketchum88's Avatar
The retainer is the same thread pitch as the rod, it will screw all the way down to where a reverse lockout would be if we were a manual. The shift knobs will screw down on top of the retainer and sit flush with it so no metal is showing. Nothing rattles, it is a quick 40 dollar way to spice up your interior if you are rolling with an automatic.
Old 07-11-2017, 04:09 AM   #40
Gixxerkid6hunid
Drives: 2017 BRZ limited
shift boot retainer
[IMG]http://i6.photobucket.com/albums/y20...pspyfkuvto.jpg[/IMG]
super late response to this, but to anyone who may search upon this post like i recently did, the 10 x 1.25 shift knob will fit. however the boot (leather cover) will dangle sort of awkwardly, some may not care, but i went ahead and got that shift boot retainer, and am currently in the process of modifying it to fit into the shift boot. it takes a lot of grinding, but so far it seems possible. it just depends on how much you really care to modify your shift knob. cause to get it to look RIGHT, it takes a lot of work for something so simple.
Last edited by Gixxerkid6hunid; 07-11-2017 at 04:12 AM. Reason: image did not work
Gixxerkid6hunid is offline   Reply With Quote
Old 07-11-2017, 10:26 AM   #41
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Your image doesn't work.
Take a look at post #8 in this thread.
Raceseng | Automatic Shift Knob Adapter Raceseng Cosmetic Modification (Interior/Exterior/Lighting) 7 05-11-2015 03:08 PM
Mt shift knob for automatic Frs rhood168 Cosmetic Modification (Interior/Exterior/Lighting) 59 12-22-2014 04:05 AM
FS: Perrin Fatty Automatic shift knob Laika Interior Parts (Incl. Lighting) 12 01-31-2014 12:18 PM
FS : Perrin Fat Automatic Shift Knob Brandon86 Canada Classifieds 3 06-09-2013 07:28 PM
Perrin Automatic Shift Knob - LA dlux Interior Parts (Incl. Lighting) 1 04-24-2013 06:59 AM
