Old 01-15-2016, 10:09 PM   #1
azynneo
Disconnected battery with tune, throttle response weakened.
I disconnected the battery to install some aftermarket tails and relay switch. I reconnected the negatice back onto the battery and now i feel like my car is gonna stall everytime i throttle. Any idea of whats going on? Im getting a much less throttle response.
azynneo is offline   Reply With Quote
Old 01-15-2016, 10:24 PM   #2
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
From @steve99's guide:
My Throttle Pedal has dead spot - car sluggish after Flashing Tune
To minimize any issues and speed up learning after a Flash or Reset
Turn ignition fully off after a flash or reset
Turn ignition fully ON, do not start car, do not touch throttle, leave for 20 sec this will allow ECU to perform its diagnostics and calibrations on cam position and throttle position sensors
Turn off ignition
Turn on ignition leave for 20 sec then start car do not touch throttle
Let car idle for at least a minute and wait till it settles at the normal idle of about 750 RPM, again do not touch throttle.
After normal idle is achieved then drive car.
jawn is offline   Reply With Quote
Old 01-15-2016, 10:51 PM   #3
azynneo
I idle at 850 im boosted
Old 01-15-2016, 10:51 PM   #4
azynneo
I idle at 850
Old 01-15-2016, 10:58 PM   #5
jawn
jawn's Avatar
Originally Posted by azynneo View Post
I idle at 850
Instructions remain the same. Wait for the idle to come down from the cold start logic.
Old 01-15-2016, 11:16 PM   #6
azynneo
think it worked, my throttle feels less dead (but still not the same but it's improving/learning)
thanks!
Old 01-15-2016, 11:22 PM   #7
jawn
jawn's Avatar
thanks!
Yeah, it'll still probably take like a tank of gas to get back to 100%.
The Following User Says Thank You to jawn For This Useful Post:
azynneo (01-15-2016)
Old 01-15-2016, 11:23 PM   #8
azynneo
Been on e85 for 3-4 weeks straight, was hoping it wasn't the fuel injectors.
The Following User Says Thank You to azynneo For This Useful Post:
jawn (01-15-2016)
Old 01-16-2016, 06:57 AM   #9
steve99
Drives: FT86
yep its normal after any flash or ecu reset, it will go back to normal after a couple of drive cycles.
above proceedure should minimise issue next time you reset or reflash
Improve throttle response ChrisD BRZ First-Gen (2012+) — General Topics 80 10-05-2020 07:50 PM
Throttle Response CamryDS Northern California 27 03-31-2015 03:35 AM
Throttle response delay jay07631 Engine, Exhaust, Transmission 12 07-09-2013 09:41 PM
battery disconnected/reconnected -- runs like shtako jonbonazza Issues | Warranty | Recalls / TSB 2 06-19-2013 10:56 AM
How's the throttle response? SFTiofoso Scion FR-S / Toyota 86 GT86 General Forum 9 08-14-2012 11:50 AM
