#57 |
Drives: GT86
Oh and also the hydraulic hand brake and 1.5 way LSD turned up yesterday
next drift day is booked for March so at least we've got a couple of months to get everything installed![]()
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits |
| The Following User Says Thank You to ChrisD For This Useful Post: | CxG (06-26-2016) |
#58 |
Drives: GT86
Engine isn't back yet, but we mounted the hydraulic hand brake (with a little bit of cutting to some of the transmission tunnel and gear shifter surround plastics, but not much). Just got to hook it up to the brake lines now
![]() It was a tight fit but its pretty much perfect, just in the right place and just a few mm from catching on the seat or the centre console etc. As you can see though, we did have to cut a little notch out of the gear stick surround but its only on the lower half so its not very noticeable
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits Last edited by ChrisD; 01-10-2016 at 12:32 PM. |
#59 |
Drives: '14 GT86 project, '13 GT86 DD
Who's building your engine Chris?
#60 | |
Drives: GT86
#61 |
Drives: GT86
I knew a guy who was a development engineer on the Audi R8 and RS engines and then worked at a tuning company building engines for British Superbikes and various high power cars. He's now starting his own company and he's doing this engine for me for a pretty good price while he's still getting everything set up for the new business. So far he's been really helpful, seems to know his stuff, and like I said its a decent price. Obviously the proof will be in the pudding, will see if we have any problems once it is back in the car, but so far so good.
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits Last edited by ChrisD; 01-12-2016 at 01:12 PM. |
#62 |
Drives: GT86
I should have said development engineer not design engineer, my bad. He seems to know his stuff... but what you say is quite worrying
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits Last edited by ChrisD; 01-12-2016 at 08:24 PM. |
#63 |
Drives: Subaru BRZ Limited
I gotta hand it to you @ChrisD. I saw this title, then read the first post and thought, oh great another "build thread" that is more of a dream list. But you man, are doin it. Way to go! building, tracking, wrecking, fixing and building. nice work!
| The Following User Says Thank You to JoeC For This Useful Post: | ChrisD (01-12-2016) |
#64 | |
Drives: GT86
and yeah I hate it when people have all these unrealistic plans, but once I've got an idea I tend to end up doing it lol which doesn't always work out too well... but having a lot of fun with this car so far
#65 |
Hey Chris,
How do you intend to plumb the handbrake in? The 86 has a diagonally split system which uses the brakes to effectively give you all your driver aids. To use the single rear line and retain all the ABS/TC functionality you'll need to add a second pair of calipers. If you're removing the ABS, then just ignore me and I'll go away..
#66 | |
Drives: GT86
#67 |
Could you use a pair of VW additional calipers as these have the cable actuated on the caliper. So, you'll leave the stock caliper/abs alone and add a mech handbrake and hydraulic handbrake to the additional VW calipers??
#68 |
Drives: GT86
Funnily enough that's actually what my friend just suggested as he's got rid of the drums on his VW and replaced with just one calliper that does both normal brake line and cable operated for hand brake too. We'd still have to get some kind of custom mounting bracket made for it, but its looking like the best solution so far.
#69 |
Drives: GT86
![]() Had a few minor issues getting the engine back in, ended up putting the exhaust manifold & turbo on and taking them off again 3 times... buts its almost there now. Just got to stick the air intake back on to the turbo and route a few hoses to the catch can, then we can fire her up and see what leaks..
#70 |
Looking forward to reading your reports once you get it up and running on big boost. Do you wanna buy my brand new AVO stage 4 kit Chris??
I've had these engines in and out now a few times and have always found it best to remove the manifold if coming out from the top. Keep the engine on the hoist, hanging loosely a few mm off the mounts, then you can work all the studs of the manifold/heads/overpipe together. Still, probably too late to give you this advice now!!
| FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices | FullBlown | Forced Induction | 588 | 12-02-2015 02:41 PM |
| P&L Motorsports BRZ / FR-S Stage 1 Turbo Kit | P&L Motorsports | Forced Induction | 234 | 09-24-2015 04:45 PM |
| For sale: Avo Stage 1 turbo kit | h4nh | Engine, Exhaust, Bolt-Ons | 4 | 09-26-2014 02:36 PM |
| Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 | Astroboy | Forced Induction | 4 | 03-01-2014 07:29 PM |
| P&L Motorsports BRZ / FR-S Stage 1 Turbo Kit | P&L Motorsports | Engine, Exhaust, Bolt-Ons | 56 | 09-22-2012 03:28 PM |
