Old 08-21-2014, 11:20 AM   #29
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
My 2013 frs has the heated mirrors, they come on automatically when I put on the rear window defrost.
Triumphrider is offline   Reply With Quote
Old 10-17-2014, 10:15 AM   #30
arvidj
Drives: '93 MR2 Turbo
A little late to answer this but for those that might be wondering ...
I just took the mirror off the passengers side of my "bought in the United States No Options 2015 FRS" and there is no heated mirror wiring in the mirror head. I did not take the door panel off to see if it was in the door, but I am positive it is not run up to the mirror head ... i.e. certainly not an easy plug-n-play.
Arvid
Red '93 MR2 Turbo, daily driver, 129,000 miles
Red '93 MR2 Turbo, garage queen, 24,683 miles
Red '15 FRS Automatic, TRD Springs, Swaybars, Brake Pads
arvidj is offline   Reply With Quote
The Following User Says Thank You to arvidj For This Useful Post:
CxG (10-22-2015)
Old 10-22-2015, 09:26 AM   #31
CxG
Drives: Pearl White '13 ZN6
So no one has added heated mirrors to the base model FRS?
CxG is offline   Reply With Quote
Old 10-22-2015, 10:00 AM   #32
stevesnj
stevesnj's Avatar
I put snowmobile heated grip pads on my Landcruiser mirrors, it was a pain because the mirror was glued to the frame. I think these mirrors just pop out. Just run the wire, unless it's pre wired inside the door, and tap into the defrost circuit. Works great!
https://www.denniskirk.com/moose/rep...prd/391958.sku
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
CxG (10-23-2015)
Old 12-01-2015, 04:35 PM   #33
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
I'm pretty sure the base model FR-S has heated mirrors. As stated previously, all Canadian model FR-S are confirmed to have them. The reason there is no separate switch is because the wire is relayed into the rear defroster switch. Meaning when you activated the rear defroster you've already activated your heated mirrors.
Worst case scenario just pop one of your mirrors out and check for connecting pins to know for sure. If they are there then you know you've got heated mirrors. Hope this helps.
MokSpeed is offline   Reply With Quote
The Following User Says Thank You to MokSpeed For This Useful Post:
CxG (12-02-2015)
Old 12-02-2015, 12:15 PM   #34
CxG
Thank you
Sent from my D5803 using Tapatalk
Old 01-03-2016, 11:48 PM   #35
Brayden_23
Drives: Asphalt 2015 FRS
US spec FRS base model does NOT have heated mirrors
Brayden_23 is offline   Reply With Quote
Old 01-04-2016, 12:15 AM   #36
I just bought a pair of heated ones from a forum member knowing there is a bunch of stuff missing. I know we need at least wiring from the door to the main harness. There are a bunch of unused plugs up under the dash but I haven't studied enough to confirm that part.
It's not the same circuit as the rear defroster. Wiring diagram shows a separate fused sub-circuit switched with a relay. The BCU sends the control signal for the rear defroster relay. I'm hoping it's the same case with the mirrors.
It'll be a while but I'll keep you updated with progress if you're interested.
CxG (01-04-2016)
Old 01-04-2016, 06:50 AM   #37
CxG
Please do lol I'd greatly appreciate it
The Following User Says Thank You to CxG For This Useful Post:
Silent_Dan (01-04-2016)
Old 01-04-2016, 04:42 PM   #38
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
The output from the rear defroster relay is what triggers the mirror heater relay.
Scenic Driver is offline   Reply With Quote
The Following 2 Users Say Thank You to Scenic Driver For This Useful Post:
CxG (01-05-2016), Ultramaroon (01-04-2016)
Old 01-04-2016, 04:51 PM   #39
suh-weet!
Old 01-23-2016, 11:03 PM   #40
NahumCC
Drives: 2013 FR-S 10 Series
Originally Posted by @Art_Mighty View Post
Could you double check? It was my understanding that the Canadian FR-S had heated mirrors, all weather mats and all-season touring tires standard.
I was researching how the OEM seat heaters worked I discovered that the relay for the Heated mirrors were missing in the US...
This is the wiring diagram to the 2013 BRZ:
This is the Relay/Fuse block in the BRZ's engine compartment for the Heated Mirrors (note: Relay&Fuse Present)
This is the same Relay/Fuse Block in the US spec FR-S (note: Relay missing, Fuse Present)
...if you have that relay, you should have heated mirrors. Look into it and and let us know
So I dug more into this tonight. I'm going to pick up the relay and plug it in. I think its all there but for whatever the reason, they didn't give us the relay in the US.
I looked at the wiring diagrams and within the mirror housing I see 4 wires being called out. A solid pink as you can see is for the mirror heater and then on the next diagram you see there are 3 wires associated with the mirror adjusting function.
That last picture is my drivers mirror which matches the diagrams by having a solid red, solid blue, white, and pink wire. Only reason it wouldn't work is if the yellow/black wire coming from the fuse after the heated mirror relay isn't part of our harness but seeing the pink wire in the mirror assembly makes me think it is.
NahumCC is offline   Reply With Quote
Old 01-23-2016, 11:50 PM   #41
See all those (*1) callouts in the diagram? Those are optional. If the diagram is accurate we need to add those to the base loom. It'd be great if it's all there but color me skeptical.
Old 01-24-2016, 12:59 AM   #42
NahumCC
Well, I just took a peek from above to see what I could. No pictures as it would have been pointless but I can confirm I saw the yellow/black wire leaving from the 7.5 amp fuse going toward the main wiring loom that enters into the cabin .
However I couldn't verify the red/yellow wire going from the rear window defroster relay to the empty mirror relay as there was just to much going on under there where the main bundle is for the wiring harness in the fuse box. I'll take my multimeter to pin 2 of the mirror relay and see if I get any current flowing the next time I have the defroster on.
Here is my two cents thinking. I'd wager its there as I feel Toyota would probably spend there money else where since the quality control for something like this minor detail could be better spent elsewhere and was completed quicker by not having the relay there vs. ensuring a wire wasn't present. It's just really weird they would include the 7.5 amp fuse as nothing else is on that circuit.
must do this
heated seats debs0712 Cosmetic Modification (Interior/Exterior/Lighting) 47 04-08-2018 09:06 PM
anyone else love APR GT3 Mirrors ???? ESBjiujitsu Cosmetic Modification (Interior/Exterior/Lighting) 23 04-10-2016 12:13 PM
Adding heated mirrors to US spec FR-S @Art_Mighty Cosmetic Modification (Interior/Exterior/Lighting) 8 09-18-2012 02:35 PM
Fr-s Power Folding Mirrors? Koolkiid Cosmetic Modification (Interior/Exterior/Lighting) 19 09-15-2012 12:31 AM
Retrofit heated seats to Premium? blalor BRZ First-Gen (2012+) — General Topics 4 05-31-2012 07:50 AM
