Old 08-07-2013, 02:40 PM   #1
altezza280t
altezza280t's Avatar
Drives: Ultramarine FR-S
Heated Convex Mirrors
I've been wanting the rex speed mirrors, but i need the heated function intact so i havent pulled the trigger yet.
i found these: ebay mirrors
anyone have luck or tried them? im not crazy about the LED's but it does say it keeps the heated function.
altezza280t is offline   Reply With Quote
Old 08-07-2013, 03:24 PM   #2
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Too bad you have to deal with blinker arrows in the window...
The Following User Says Thank You to SkAsphalt For This Useful Post:
qitorr (12-04-2013)
Old 08-07-2013, 04:26 PM   #3
greenguy101
VMFIC ORLANDO SCIKOTICS
greenguy101's Avatar
The FR-S has heated mirrors in the USA or just Canada? I am pretty sure mine doesn't have them and I'm in Florida.
"Silence is acceptance so start talking or quit bitching!"
greenguy101 is offline   Reply With Quote
Old 08-07-2013, 05:07 PM   #4
topazsparrow
Drives: slow
I'm in Canada and we have no such thing.
topazsparrow is offline   Reply With Quote
Old 08-07-2013, 09:00 PM   #5
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Could you double check? It was my understanding that the Canadian FR-S had heated mirrors, all weather mats and all-season touring tires standard.
I was researching how the OEM seat heaters worked I discovered that the relay for the Heated mirrors were missing in the US...
This is the wiring diagram to the 2013 BRZ:
This is the Relay/Fuse block in the BRZ's engine compartment for the Heated Mirrors (note: Relay&Fuse Present)
This is the same Relay/Fuse Block in the US spec FR-S (note: Relay missing, Fuse Present)
...if you have that relay, you should have heated mirrors. Look into it and and let us know
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 08-08-2013, 12:45 AM   #6
ParangWala
ParangWala's Avatar
Drives: 2013 SCION FR-S
I am in Toronto and I definitely have heated mirrors and they do work
ParangWala is offline   Reply With Quote
The Following User Says Thank You to ParangWala For This Useful Post:
@Art_Mighty (08-08-2013)
Old 08-08-2013, 02:01 AM   #7
stockysnail
Just the tip
stockysnail's Avatar
Get the Prova branded overlay mirrors from Rallysportdirect. The heated mirror part will still work if you tape it well enough for the heat to transfer through the tape. I haven't seen winter or cold weather with them yet but it supposedly still heats up with the overlays.
Old 10-20-2013, 01:19 AM   #8
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
got those mirrors from Ebay, will try them out tomorrow.
Do I just pop it off like the Rexpeed video instructions, or is there a special technique to remove the heated element prongs first ?
thanks
ucsmfu is offline   Reply With Quote
Old 10-20-2013, 03:33 AM   #9
WillBRZ
WillBRZ's Avatar
Drives: 2013 BRZ Limited 6MT GBS
keep us posted.
2014 infiniti Q50 Daily 1996 Mazda Miata Racecar
SOLD -> Galaxy Blue Silica Subaru BRZ Limited 6MT
SOLD -> 2003.5 Infiniti G35 Sedan Emerald Mist
WillBRZ is offline   Reply With Quote
Old 10-20-2013, 04:09 AM   #10
double0seven
Drives: FRS
Also from Canada and definately have heated mirrors. It turns on when you turn on the rear window defroster. Don't have all season tires though.
double0seven is offline   Reply With Quote
Old 10-20-2013, 02:30 PM   #11
cslntuee
Drives: Subaru BRZ Limited
I checked the Rallysportdirect website.
It wrote" A note of importance. Prova Mirrors are made for the JDM Subaru models which come with Convex mirrors from the factory. USDM Models do not come with Convex mirrors. The supplied pre-applied double sided tape may not be adequate to properly mount the mirrors to your vehicle. Extra double sided tape is recommended(and not included) to take up the gap in-between the Convex Prova mirror and the stock flat mirror. Failure to use proper mounting may result in the mirror becoming disconnected from the vehicle and could result in damage that is not covered under the manufacturer's warranty. "
Is there any mounting issue?
Thanks a lot.
cslntuee is offline   Reply With Quote
Old 10-20-2013, 10:57 PM   #12
stockysnail
Just the tip
Thanks a lot.
I didn't have any issues but I picked up some extra 3m double sided outdoor tape and put an extra layer on it to make sure the middle convex area would make contact with the existing mirror.
The Following User Says Thank You to stockysnail For This Useful Post:
cslntuee (10-21-2013)
Old 10-21-2013, 09:51 PM   #13
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
received them
Only problem, is that I took at look at the Canadian BRZ mirror configuration and it seems like our mirrors are held in by screws, not just the clips like the USA configuration. Is anyone able to confirm this ? or has removed their Canadian side mirrors successfully ?
thanks
Old 10-21-2013, 11:55 PM   #14
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by ucsmfu View Post
received them
thanks
heated CDN FRS mirrors are clips
heated mirrors? gxgn DIY (Do-It-Yourself) Guides 141 11-15-2016 08:27 AM
***Rexpeed Convex Side Mirrors and Carbon Fiber Side Mirror Covers*** FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 249 12-07-2015 01:28 PM
heated mirrors mwlhrh Scion FR-S / Toyota 86 GT86 General Forum 9 08-06-2013 01:55 PM
Custom convex side view mirror bpracer DIY (Do-It-Yourself) Guides 10 01-04-2013 11:15 PM
Adding heated mirrors to US spec FR-S @Art_Mighty Cosmetic Modification (Interior/Exterior/Lighting) 8 09-18-2012 02:35 PM
