#71 |
Drives: '15 BRZ RA
Even if they provide the new intake, intake manifold and ECU the power upgrade won't be so much. Maybe in the range of 8-10 hp. The GRMN 86 has changed internals which can give a higher rpm range (+300 rpm).
| The Following User Says Thank You to nikitopo For This Useful Post: | stevesnj (12-31-2015) |
#72 |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Still like my FRS better. At least with my car, I can mod it to how I want and it wouldn't matter. This GRMN model, I'd be ashamed to mod it because of how exclusive it is.
| The Following User Says Thank You to hmong337 For This Useful Post: | Rampage (01-04-2016) |
#73 |
Found some info and pics on this car from the Toyota site...
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete Last edited by stevesnj; 01-05-2016 at 10:23 AM. |
#74 |
Drives: whiteout, dark tint
| The Following 2 Users Say Thank You to 86kahl For This Useful Post: | calmtigers (12-31-2015), sato (09-06-2020) |
#75 |
Drives: UK Spec GT86
I want one of these so bad (not bad enough to pay £60k and import)
#76 |
Granny Shifter
Drives: 2014 FR-S
I know this sounds messed up, but I can't wait to vulture second hand parts off these once a couple of them get in wrecks.
I wish no harm to the drivers and owners themselves. I just want the parts!
| The Following User Says Thank You to MokSpeed For This Useful Post: | ichitaka05 (01-04-2016) |
#77 |
Since these will never see the US I don't think you are going to get much opportunity to scoop parts. Even if they did you would probably have to be standing right beside it when it was wrecked to get anything.
#78 | ||
Site Moderator
Drives: ichi 86 Project
#79 |
Mentat
Drives: 2013 Scion FRS 6MT
I am sure it will not take long for some of the aftermarket companies to reverse engineer some of the parts.
| The Following User Says Thank You to Muaddib For This Useful Post: | airjonny (01-04-2016) |
#80 |
Drives: Whiteout FRS
I really hopes someone creates an intake and intake manifold similar to this
| The Following User Says Thank You to Bach415 For This Useful Post: | stevesnj (01-05-2016) |
#81 |
I like these parts because of their simplicity of old school thinking while NOT utilizing FI. This seems to be a great starting point and more reliable solution to FI. I like this because like TRD the parts are engineered with help from Toyota. This all could be a setup for like a Stage II TRD performance parts option. The design of the headers are a work of art and will most likely give the best gains. But that intake is intriguing.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#82 |
#83 |
Drives: '15 BRZ RA
Very strange that the GRMN 86 doesn't have a factory oil cooler. Engine is not that different and given the higher rpm range it should also generate high oil temperatures.
Maybe we are too sensitive with our car's oil temperatures ... |
#84 | |
The Fail Boat
Drives: CWP S.B.
But It's really a different engine for GRMN right? O.o Since most of the moving parts in that went though low friction/light weigh treatment already. |
| Toyota 86 14R60 unveiled | mark0006 | Scion FR-S / Toyota 86 GT86 General Forum | 308 | 01-23-2025 11:13 AM |
| What kind of wheels are these on the GRMN 86 Prototype? | switchlanez | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 12-10-2018 08:23 AM |
| GRMN SPORTS FR Concept PLATINUM | PREDATOR786 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 12 | 01-21-2013 10:47 PM |
| GRMN | 70NYD | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 01-23-2011 03:29 AM |
