Old 12-31-2015, 06:32 PM   #15
shdobxr
Drives: 2015
Check out the ptuning header. With a tune and just that I hit 207 today.
shdobxr is offline   Reply With Quote
Old 12-31-2015, 07:03 PM   #16
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The FA20 is barely in B18C territory. Not terribly impressive given the engine is nearly 2 decades newer.
At this engine size though, you dont need anything thatll flow like a fire hydrant. What you need is nice ass piston heads con rods and a billet crank and a semi closed deck; but thats expensive and heavy.
Old 12-31-2015, 07:12 PM   #17
CSG Mike
CSG Mike's Avatar
Tell that to a (also 2.0L) F20C, which flows nearly 25% more than a B18/FA20.
Exhaust gas evacuation is a major hinderance to making power with the FA20. That's why the Ace header makes such a huge power gain; it addresses the weakest point of the engine.
cdrazic93 (12-31-2015), new2subaru (12-31-2015)
Old 12-31-2015, 07:23 PM   #18
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I was literally thinking about the exhaust valves when i was typing that response...god damn it Mike lol.
Old 12-31-2015, 07:37 PM   #19
CSG Mike
CSG Mike's Avatar
Too bad there's barely any space for huge valves...
celek (01-04-2016)
Old 12-31-2015, 08:22 PM   #20
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
If we're going to get into the nit and grit of the headwork, the unit itself is too small. The cams take up alot of the room which leaves little to the imagination for extended valve stems or any kind of over sized valves. Im sure the 2015 differences vs 2013 differences are minute, but I bet the newer cams are slimmer for the extended valve stems.
I just want them to do something about the rocker arms...
The Following User Says Thank You to cdrazic93 For This Useful Post:
CSG Mike (01-01-2016)
Old 01-04-2016, 09:17 AM   #21
celek
Resident Gear Head
celek's Avatar
Originally Posted by jsimon7777 View Post
Plus the tune, timing, and header. Chase NA power if you want to burn money. A cheap turbo kit will produce more power everywhere, all for less money.
Cheap
Reliable
Fast
Pick 2 , Don't think you will get 400+ WHP reliably with a turbo cheap.
You will still need to build because everyone is greedy. #justonemorepsi
celek is offline   Reply With Quote
The Following 4 Users Say Thank You to celek For This Useful Post:
civicdrivr (09-09-2016), CSG Mike (01-04-2016), go_a_way1 (01-04-2016), Toyota86.ir (01-04-2016)
Old 01-04-2016, 11:33 AM   #22
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Originally Posted by celek View Post
Cheap
Reliable
Fast
280WHP reliably is a turbo kit away. $3-4k and you're done. 4-5k if you want a custom tune and track-level cooling. 250WHP would take an inordinate amount of work, and the power would not be as usable - slower car. 400+WHP? Well, that's a different story. Then I'd call Element or another good shop, tell them your goals, and write a check.
Old 01-04-2016, 02:22 PM   #23
CSG Mike
CSG Mike's Avatar
I'd love to see this done... 5k for a 280whp turbo setup that won't overheat on me at the track, because if such a thing existed, I'd rather have 280whp on a turbo than 280whp on a SC.
Old 01-04-2016, 02:32 PM   #24
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Cheap
Reliable
Fast
Cheap
Reliable
Fast
Pick 2
I live by those words
Old 01-04-2016, 02:45 PM   #25
EAGLE5
Dismember
EAGLE5's Avatar
Most people will do just great in 25 minute sessions with just a big oil cooler and maybe a radiator. You, however, are some other kind of beast. On a 100+ degree day, all bets are off. I've seen a well-prepped Jackson SC overheat on a 115 degree day.
Old 01-04-2016, 03:14 PM   #26
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
Cheap
Reliable
Fast
Pick 2
In this instance we also need to add "common" in 5 or 6 years time a lot of this stuff will be figured out and easy to come by, the NA guys are still working a lot of it out for the first time.
Gear_One_Performance is offline   Reply With Quote
The Following User Says Thank You to Gear_One_Performance For This Useful Post:
Old 01-04-2016, 03:21 PM   #27
CSG Mike
CSG Mike's Avatar
Every single (literally, 100%) turbo FRS/BRZ owners who've taken my challenge, have both (initially):
- Had their cars overheat in 1 hot lap or less
- Overheated their own cars the same day, after seeing what the car can do with me behind the wheel; a demo of the car's capability changes your perspective dramatically.
Many of these owners now have cars that don't overheat, but are in far deeper than 5k (double to triple that for powertrain and supporting mods is a more common figure).
The Following 6 Users Say Thank You to CSG Mike For This Useful Post:
acro (01-04-2016), ATL BRZ (01-04-2016), ElijahF (02-19-2020), hmong337 (01-04-2016), Toyota86.ir (01-04-2016), zdr93523 (08-27-2017)
Old 01-04-2016, 04:51 PM   #28
mkivsoopra
+1 lol
mkivsoopra is offline   Reply With Quote
The Following User Says Thank You to mkivsoopra For This Useful Post:
rb6freak (01-19-2017)
Element Tuning's Time Attack Roll Cage. MA-Motorsports Review Element Tuning Tracking / Autocross / HPDE / Drifting 21 04-25-2017 12:51 PM
Element Tuning Raven Black FRS Track Build Element Tuning Member's Car Journals 130 04-04-2016 02:13 AM
Element tuning Hydra EMS mike the snake Software Tuning 29 03-29-2016 09:08 PM
Element Tuning FRS/BRZ Hydra EMS Stand-Alone Turbo 400 whp Injector Limited Element Tuning Engine, Exhaust, Transmission 40 12-17-2013 01:12 AM
Element Tuning FRS Battling the Corvettes at VIR Element Tuning FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 28 07-27-2013 03:02 PM
