#463 |
Dismember
Drives: 2013 Red Scion FR-S
Tactrix's software is locked into their hardware. Some of the clones work with the hardware, but bricking your ECU is no fun. I strongly suggest real Tactrix or OFT. EcuTek is good for people getting a custom tune from a pro. The big boys often use an ECU replacement.
#464 | |
Drives: FT86
To flash the ECU with new ROM data you need a specialized device any one of the 3 below will work they are in order of cheapest to most expensive. Tactrix is the least user friendly Tactrix adapter OpenFlash Tablet -comes with free tunes Ecutek Cable and Licience |
#465 |
Drives: 86 GT
Probably been asked before but info seems to be all over the place...
What/where are the most complete RR definitions for the A01G ROM? There are Td-d github repos, I've seen OFT ones from @Wayno dated late last year, revisions by @Kodename47 and various useful additions by @ztan. I'm not using an OFT to flash but from memory that doesn't matter in the case of A01G def's? Second question, can someone provide a working G series logcfg.txt file to do tactrix logs with boost? Think I have the wrong addresses or settings. Did try to generate a new logcfg file with that app but it gives me an error because the RR logger isn't configured correctly. I gather most boosted people are running ecutek here from my searches? Sprintex supercharger kit in my case. Last edited by dave-; 01-04-2016 at 05:31 AM. |
#466 | |
Drives: FT86
you can only extract parameters the ecu uses with the logging, if you after some extra parameters you could try asking ztan romraider logger not set up for our ecu you might want to talk to @D-VO he has done supercharger open source |
#467 | |
Drives: Toyota 86
paramid = 0xFFF87C60 isfloat = 1 scalingrpn = x,0.133322368,* Logs MAP in kPa |
#468 | |
Drives: 86 GT
It's a Sprintex SPS/210+ kit with 69mm pulley. Positive the peak was 12-13psi on the dyno. Did some logs yesterday/today with some spirited driving. http://datazap.me/u/dave/sprintex-tune http://datazap.me/u/dave/sprintex-tune-log-2 http://datazap.me/u/dave/sprintex-tune-log-3 |
#469 | |
Drives: Toyota 86
137kPa absolute = 100kPa atmospheric + 37kPa (5.3 psi) boost. Is your MAP sensor scaling right? Which sensor are you using and which ROM address did you adjust (the original def sensor scaling addresses were wrong). Just had a look at your logs - your MAP is pegged high at 137kPa which looks like a maxed out stock sensor. The psi boost value is in your logs as manifold_relative_pressure. Stock sensor scaling = 250mmHg/V -150mmHg Stock sensor at 5V = 1100mmHg ~= 145kPa ps: you can delete the AF_Corr_3 and AF_Learn_3 values from your logcfg.txt - I'm sure the latter is an OL_enrichment value and I haven't traced the AF_Corr_3. You can also boost the sampling rate by dropping some of the parameters that you aren't really looking at and decreasing the calcsampinterval value - I am using 500 at the moment and log 32 parameters at 40ms interval. Last edited by ztan; 01-05-2016 at 05:50 AM. |
#470 | |
Drives: 86 GT
paramname = Manifold_Relative_Pressure paramid = 0xFFF88F78 isfloat = 1 scalingrpn = x,0.0193367747,* Believe it is the OEM MAP sensor as the kit doesn't change it. Not 100% sure. Manifold Pressure Sensor Scaling A/B/C are the same: ROM def's are Kodename's metric & % one: <table name="Manifold Pressure Sensor Scaling A" storageaddress="1000CC" /> <table name="Manifold Pressure Sensor Scaling B" storageaddress="1000E4" /> <table name="Manifold Pressure Sensor Scaling C" storageaddress="11CC20" /> Logged using: paramname = MAP paramid = 0xFFF87C60 isfloat = 1 scalingrpn = x,0.133322368,* Should add it isn't my tune and from my inexperienced eye, looking at the logs it isn't very good anyway. |
#471 | |
Drives: Toyota 86
When you get a uprated MAP sensor, have a look at my boost fuel cut fix to protect you from major overboost. Boost protection at the moment with that stock sensor won't work, but not critical with supercharger compared to turbo. |
#472 | |
Drives: 86 GT
Have all your opensource threads saved, as you said not critical with the blower but would def do it for a turbo. Will have to confirm still stock sensor but not overly impressed with the setup so far so who knows how long the kit will stay installed anyway! |
#473 |
Drives: UK GT86
You can't change the MAP sensor on the Sprintex, but there's no need. MAP just caps at the sensor limit.
What's wrong with the setup @dave-?
.: Stealth 86 :.
#474 | |
Drives: 86 GT
Need to get the car on a dyno again and put some decent effort into the tune. I'll report back once that is done. Haven't ruled out hardware or install issues either as yet. I do know the intercooler took a few go's to bleed completely. I wasn't present for the install so not sure what happened there or if its a common thing. Haven't read much of the sprintex thread TBH. |
#475 |
Drives: Whiteout FR-S, Evo 8 RS
Hey guys. QQ for you: Where exactly does the 'GDI Firing Angle Low Load Cold' become effective? Its a little confusing. Why would there be a designation of "High Load" and "Low Load" if both tables have an X-Axis of 0.20 -> 1.20 load? Also, where does "cold" start and end? @Td-d @Kodename47 @ztan Maybe??
#476 | |
Drives: UK GT86
.: Stealth 86 :.
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 12:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 08:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 10:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 07:27 AM |
