Old 01-01-2016, 03:11 PM   #15
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
My car definitely does this, and has since new. It rolls a good inch or two, and I mean actually _rolls_. It is not related to suspension.
I've always just chalked it up to the design of the parking brake. It's also extremely grabby compared to other vehicles I've driven.
pushrod is offline   Reply With Quote
Old 01-01-2016, 03:29 PM   #16
Originally Posted by Jord104 View Post
Hi all,
Sorry to hijack the thread somewhat but I have a similar issue. I know that the wheel is moving when the handbrake is applied. This is only happening on the right hand side and there is no movement in the left hand side wheel.
This is demonstrated here:
Has anyone encountered this or do you have any ideas of a cause? I have yet to take the hub assembly apart for a closer look.
Jordan
Since your wheel is off the ground, that looks to be because of a bit of "play" in the differential ......
Which is OK.
Old 01-06-2016, 02:41 PM   #17
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
This issue is normal operation, it has to do with the design of the parking brake on most Subaru's. The Parking/E-Brake on most Subaru's are a "Drum In Disc" type design where there is a smaller drum brake inside the hub of your rear Disc brakes.
If you have ever worked on "Self-Adjusting Drum Brakes" then you know that the entire Mechanism inside the brakes floats around a bit as a function of the self adjustment part of the brakes. This is what causes the movement when you let off the floor pedal, because you are switching from the disc brake portion of the brakes to the drum brake portion and the drum brake portion of the brakes floats a little bit inside the drum as part of the self-adjustment function of the drum brakes.
Here is a useful animation on how drum brake adjusters work.
http://auto.howstuffworks.com/auto-p...rum-brake2.htm
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
The Following 2 Users Say Thank You to Sony For This Useful Post:
PandaSPUR (01-14-2016), Tcoat (01-06-2016)
Old 01-14-2016, 06:25 AM   #18
Jord104
Drives: '15 Subaru BRZ
Thanks for the replies very helpful, I had to replace a few bits on that side and never noticed the movement until after I had done so.
I also had a squeak at the time of posting when driving which I thought was related to this but I have since got rid of that and can see it is normal and handbrake functions just fine.
Jordan
Jord104 is offline   Reply With Quote
Emergency brake button?? Borzy Cosmetic Modification (Interior/Exterior/Lighting) 2 10-13-2015 08:18 PM
WTB: BRZ handbrake cover and handbrake boot w/ red stitching 86tylerfrs Want-To-Buy Requests 4 01-20-2015 04:11 PM
Emergency brake adjustment? F3dzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-26-2013 10:59 AM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Parking/Emergency Brake - "Clunk" EsoBOFH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-24-2012 11:43 AM
