Old 12-08-2015, 04:07 AM   #1
MasonL1997
MasonL1997's Avatar
Drives: Man
Send a message via AIM to MasonL1997 Send a message via Yahoo to MasonL1997
Car Rolls Slightly Before Handbrake/Emergency Brake Catches
Hi everyone,
After pulling my handbrake up and on a slight incline, my car will roll a little before the handbrake grabs. Every car ive been in has never done this. Is it a normal twin thing? Is there any way to fix/stop this?
Thanks!
Mason
MasonL1997 is offline   Reply With Quote
Old 12-08-2015, 04:42 AM   #2
humfrz
Originally Posted by MasonL1997 View Post
Hi everyone,
Thanks!
Mason
I reckon that would depend upon what you mean by a "little". If an inch or two, I wouldn't worry about it.
Sometimes cars will "shift" a bit on the suspension, when parked on a hill, after the emergency brake is set ....... maybe that's what you are feeling .... ??
humfrz
Old 12-08-2015, 06:56 AM   #3
MasonL1997
MasonL1997's Avatar
Drives: Man
humfrz
it rolls about an inch. Ill release my foot off the brake pedal after pulling the handbrake up, it then rolls slightly, waiting for the handbrake to catch. Does yours do that humfrz?
Old 12-08-2015, 07:26 AM   #4
humfrz
When I set the handbrake on my car, when it's in my sloped driveway, then take my foot off the brake, it "feels" like it moves forward a bit.
However, in reality, the handbrake on our cars is a independent, mechanical system, of levers, cables and brake shoes and drums.
So, if it's working properly, when the handbrake is set, the wheel should be locked in place.
I suggest you have someone observe the wheel, when you set the handbrake and see if it actually does rotate.
Betcha it doesn't ........ it just feels like it does ......
Report the results of your experiment.
humfrz
Old 12-08-2015, 08:27 AM   #5
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
When you have your foot on the brake, all four wheels are locked. The handbrake only locks your rear wheels. Releasing the brake pedal, especially on a hill, will allow your front wheels to move a miniscule amount down the incline (backwards when facing uphill, forwards when facing downhill) while the back wheels remain motionless. Your suspension allows this as the car finds a new balance with only the back wheels locked by the handbrake.
HOWEVER.. that to me has always just felt like a settling or re-leveling of the car, and not an actual rolling movement. In an automatic car that's been put in park but not had the handbrake engaged, it's normal for a short roll to take place upon release of the brake pedal, but cars really shouldn't roll, meaning the back wheels rotate, with the handbrake engaged.
Do you have any more travel available on your handbrake? If you pull it up harder, say an other click or two, can you get the car to remain stationary when releasing the brake pedal? If so, then your parking brakes need adjustment or new shoes, or you just need to man up and pull on the handbrake harder! . The adjustment can be done fairly easily. New shoes requires removing the rear calipers and rotors and messing around with fiddly springs which I hate to do. I drove for years w/out a parking brake on my last car just 'cause I hate replacing them so much. It's not that bad, really.. just frustrating if you haven't changed a lot of them.
If you count on your parking brake, then I'd definitely check into your symptoms further. A definite roll, i.e., all four wheels obviously rotating, should not be happening.
Hope that helps..
Barry
MuseChaser is offline   Reply With Quote
Old 12-08-2015, 08:45 AM   #6
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
It's relatively easy to adjust your hand brake at the handle and the adjusters individually on either wheel but an inch or two of movement before the hand brake fully engages is normal.
Gear_One_Performance is offline   Reply With Quote
Old 12-08-2015, 09:49 AM   #7
radroach
Drives: car
One thing I've wondered about this, does it put any pressure on the transmission if you have it in 1st gear and it rolls back an inch?
Old 12-08-2015, 01:13 PM   #8
PMPB
Drives: BRZ Sport-tech
Well, it really depend if the parking break was engaged or not, and how tightly it was engaged, on what hill.
The answer is yes. But really, the pressure applied to the transmission is insignificant.... It's a very small fraction of the force applied through the gears while accelerating.
PMPB is offline   Reply With Quote
Old 12-08-2015, 03:12 PM   #9
MrDinkleman
Drives: 2016 Oceanic, "base" model
Yes, mine does the same thing but only when pointed down hill. Pointing up hill, the brake holds as soon as I pull up the handle. I think it has something to do with the emergency brake's drum-inside-disc design.
There is thread here about a loud "CLUNK" when you pull up the brake handle while moving forward (to slow down without showing brake lights). From that, I surmise that the emergency brake shoes are designed, for some reason, to shift when the car moves forward when the parking brake is applied.
MrDinkleman is offline   Reply With Quote
Old 12-08-2015, 03:37 PM   #10
humfrz
It can put some pressure on a gear in the transmission.
What I suggest is that when you stop, set the emergency first, let off the regular brakes, turn off the engine, then put the car in gear.
humfrz
Old 01-01-2016, 04:41 AM   #11
Jord104
Drives: '15 Subaru BRZ
Hi all,
Sorry to hijack the thread somewhat but I have a similar issue. I know that the wheel is moving when the handbrake is applied. This is only happening on the right hand side and there is no movement in the left hand side wheel.
This is demonstrated here:
Has anyone encountered this or do you have any ideas of a cause? I have yet to take the hub assembly apart for a closer look.
Jordan
Jord104 is offline   Reply With Quote
Old 01-01-2016, 05:04 AM   #12
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
clutch grabs. Brake takes bit to grab as well.
Packofcrows is offline   Reply With Quote
Old 01-01-2016, 12:38 PM   #13
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Inclines suck, I try not to park on them. Its hard to get into R if you are on an incline and have to back out. This car is and my last car was, and yes if you don't get that last little click it will roll
RichardsFRS is offline   Reply With Quote
Old 01-01-2016, 02:47 PM   #14
ajc209
Drives: GT86 Cosworth
Originally Posted by Jord104 View Post
Hi all,
Jordan
I noticed this exact same thing on my car when it was jacked up the other day. Only on the one side though.
Sent from my GT-I9300 using Tapatalk
ajc209 is offline   Reply With Quote
Emergency brake button?? Borzy Cosmetic Modification (Interior/Exterior/Lighting) 2 10-13-2015 08:18 PM
WTB: BRZ handbrake cover and handbrake boot w/ red stitching 86tylerfrs Want-To-Buy Requests 4 01-20-2015 04:11 PM
Emergency brake adjustment? F3dzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-26-2013 10:59 AM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Parking/Emergency Brake - "Clunk" EsoBOFH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-24-2012 11:43 AM
