Drives: GR Corolla
Rear Speaker Wire Question
Hi everyone. While searching the section, I came across a post that said it's okay to repurpose the rear speaker wires off of the factory harness. I was thinking of getting one of the Bazooka bass tubes (either the 850FH or 8100FHC). I don't really care for the rear speakers, so I was wondering if I can disconnect those, and tap the Bazooka FAST harness to it?
This way, I can somewhat control the volume of the sub by fading the volume to the rear. I just want to add a little more low end to the system, and I use my trunk often, so I need something that I can connect and disconnect easily and quickly. Would this be advisable to do? Thanks, guys. EDIT: if you're planning on tapping off the rear speakers, don't bother. Since they're high-passed, the Bazooka tube will not have much output since the wires aren't full range. Must use the front speaker wires. Last edited by Kaotic Lazagna; 02-10-2016 at 06:55 PM. |
#2 |
Drives: 13 mt fr-s
You can keep your rear speakers.
In the trunk, under the factory floor thing (where the spare tire is,) there is an amp. You can tap into the on/off signal wire from that (easy search) as well tap off the signal to the speakers and throw on a low pass filter. Or just run a set of rca's from the factory unit. It is super easy to run a power wire from the battery to the trunk. Many diy's. (easy search) I garentee you can do these things yourself. Couple hours maybe, vs hundredsss in shop fees. |
#3 | |
Drives: GR Corolla
I don't have a problem installing things. I've done the system I had on my Yaris (HU, speakers, amp, sub): ![]() I've installed wiring and speakers on an FX16 from scratch as well. It's more along the lines of keeping things simple with this. Taking out and putting in a box like that is just a PITA. I didn't mind having it in the Yaris (even ended up getting a slightly larger, ported box) since it had a good amount of trunk space. I'm not looking for the same amount of bass I had in my Yaris, just to fill the low's a little, and being able to take it out easily and quickly. |
| sub in the rear speaker location | aznatama | Electronics | Audio | NAV | Infotainment | 4 | 11-07-2014 05:18 PM |
| Do I have to run new speaker wire into doors? | pmj | Electronics | Audio | NAV | Infotainment | 11 | 10-01-2014 10:54 PM |
| KICKER SPEAKER WIRE: $25 SHIPPED | AG3NT_5CARFAC3 | Miscellaneous | 2 | 11-07-2013 03:55 PM |
| Door speaker question | BlackyRose | Electronics | Audio | NAV | Infotainment | 2 | 07-26-2013 10:45 PM |
| Amplifier battery wire question!?!? | mbh1101 | Electronics | Audio | NAV | Infotainment | 4 | 03-04-2013 09:07 AM |
