#1 | ||||||||
Drives: 2005 Toyota Camry
INSTALLED || Blitz Racing Oil Cooler Kit RD for FRS/BRZ
Will be installing this on my car soon, most likely after the engine goes under the knife for warranty work.
Some nice features of this Blitz oil cooler are:
http://www.blitzna.com/oil-cooler-ki...r-zn6-zc6.html http://www.blitz.co.jp/products/cool...ler_rs_rd.html ![]() -alex Quote:
| The Following 11 Users Say Thank You to mav1178 For This Useful Post: | 86kahl (01-01-2016), chaoskaze (12-30-2015), Clipdat (12-30-2015), DocWalt (03-03-2018), EndlessAzure (02-02-2019), JBezugs (04-04-2018), ottoyu34 (04-06-2016), Sportsguy83 (04-20-2016), TofuJoe (07-30-2017), whataboutbob (12-30-2015), yEEt42069 (02-03-2022) |
#2 |
/scion
Drives: '13 86 M/T
This should be good
"Practice makes better. Only Senna is perfect." - CSG Mike
#3 |
I have one of these and its been on for over a year with no problems! Braided lines and preinstalled AN fittings give me a piece of mind that there will be NO LEAKS.
| The Following User Says Thank You to xero404 For This Useful Post: | Clipdat (12-30-2015) |
#4 | |
Proud of BOXER
Drives: Subaru Boxer
Can anyone explain this benefit: "Built-in thermostat"
Does this mean that on short trips it won't try to overly cool your oil?
#5 |
don't most oil coolers come with a thermostat in the adapter plate? it definitely looks like a quality piece though, and I wouldn't expect anything less for that price tag too. I'm curious what those plates are for though. they look nice
the thermostat opens when the oil reaches a certain temperature in order to start cooling the oil. however, many people state that even with the thermostat closed, there is still a slight flow of oil through the cooler so most people just block it off during the winter so the oil reaches temp easier
#6 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
A thermostat will just prevent most of the oil from going to the core until it reaches the preset temperature then more oil will be diverted to the core to maintain a desired temperature. I run a 190ish thermostat on my car. The reason you want one is to heat the oil up faster otherwise it would take a long time to warm up.
| The Following User Says Thank You to go_a_way1 For This Useful Post: | Clipdat (12-30-2015) |
#7 |
Review Soon || Blitz Racing Oil Cooler Kit RD for FRS/BRZ
Warming up the car on idle does take a bit longer. Once warmed up and On the freeway I'm usually in the operating range of 180-200f range so no worries of overcooling. The plates are for the duct around the cooler
#8 | |
Not Bаnned Anymore
Haha you beat me to it! In my sandwich plate the thermostat is normally open closes when it warms up. The oil flows right through for the most part but when it starts to close around 190 F more oil is forced to go to the core and is cooled then back to the sandwich plate on the other side and up into the oil filter. When I reach about 220+ its fully closed and all the oil goes to the core and the temps don't get much hotter then that. Oil will always flow to the core but not much until it warms up. In the winter I remove the thermostat all together (as it takes a little space where the oil by passes even when fully open i.e. cold oil) my car warms up nearly as fast a stock and hold 190F sames as coolant temps unless I really go hard on it in -20C Sorry if I cant spell I am on my phone and dont want to re read this haha |
#9 | ||
Proud of BOXER
Interesting, thanks for sharing your experiences. What kit do you have exactly?
I've been wanting to get an oil cooler for a while, ever since I first laid eyes on the Perrin oil cooler, which to me looks like a really nice setup. This is only the second oil cooler which has made me as excited as I was about the Perrin. The design looks great and I like the ducting to direct the air onto the core. Looking forward to hearing the OP's review! Quote:
| The Following User Says Thank You to Clipdat For This Useful Post: | go_a_way1 (12-30-2015) |
#10 | |
Not Bаnned Anymore
#11 |
I wonder how this mounts up. if I recall correctly, the Perrin cooler mounts to the plastic undertray of the bumper which I am not a fan of.
#12 | |
The thermostat inside this unit opens at 75C, which is after the coolant thermostat opens. Just like the coolant thermostat, it prevents oil from circulating to the cooler core until it reaches operating temperature.
-alex |
#13 |
Pictures from the Blitz NA Flickr account:
https://www.flickr.com/photos/137904...57660365503073 -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | 8R6 (01-12-2016) |
#14 | |
Proud of BOXER
Bump for updates.
| Review soon || Blitz Nür-Spec F-Ti 1-piece exhaust system | mav1178 | Engine, Exhaust, Transmission | 41 | 12-12-2016 03:52 PM |
| Review soon || Blitz Damper ZZ-R Spec-C | mav1178 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 02-02-2016 03:51 PM |
| Review || Blitz Hybrid A/C cabin filter | mav1178 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 11-27-2015 02:30 PM |
| BC Racing BR's vs Blitz ZZR's | Wise | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-01-2013 09:01 PM |
