Old 11-27-2015, 02:25 PM   #1
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Review || Blitz Hybrid A/C cabin filter
Like most of you (should be doing), I've changed my cabin filter out a few times already. Ideally you should swap it out once every year so...
I thought about finding a better solution that is more sustainable, turns out Blitz offers a Hybrid AC filter that is reusable and has similar odor filter elements like a factory filter.
The factory filter has activated carbon embedded in the filter media, so that it absorbs odors. The only drawback is that it is not reusable. The Blitz filter has a photocatalyst element on it (apparently made of Titanium Dioxide) that is meant to be reused often.
The filter part is pretty straightforward, and to reuse this filter you just have to remove it once a season, wash it, and leave it out in the sun to recharge the photocatalyst.
If I can get 2 or more replacement cycles out of this, it will already be better than the factory filter.
Stock vs the Blitz filter:
Of interest: the Blitz filter is marked with direction of airflow, however the stock filter is marked with one side as "up"... this is important because the factory A/C unit pulls air from the top down, so the Blitz filter needs to be installed with the catalyst element facing downward.
Found it here:
http://www.blitzna.com/interior/ac-c...ter-ha303.html
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
go_a_way1 (11-27-2015), swarb (06-03-2016)
Old 11-27-2015, 02:30 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Found it here:
-alex
AWESOME find!! Let us how well it works!
DIY Cabin Air Filter Inspection/Replacement F1point4 DIY (Do-It-Yourself) Guides 137 08-12-2023 06:32 PM
DIY: Homemade Cabin Air Filter from Filtrete BabaYaga DIY (Do-It-Yourself) Guides 0 10-11-2014 03:29 PM
Cusco Oil Filter or Blitz Oil Filter Mr.Impreza CANADA 6 10-11-2014 07:08 AM
OEM Subaru engine air filter + cabin air filter autobrz Mechanical Maintenance and Tools 6 03-09-2014 09:28 PM
Do our Scion Toyota 86 have a cabin air filter ? dssence Scion FR-S / Toyota 86 GT86 General Forum 17 02-03-2014 12:23 PM
