Old 12-24-2015, 03:22 AM   #43
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by swarb View Post
You should read the WHOLE thread.
😩 fine...
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 12-24-2015, 03:49 AM   #44
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by Astroboy View Post
How do you change them? You just need to remove the wheel and replace them from the back correct without removing the hub correct? Never really looked black there so Idk. I'm more worried about that bent jack point! I how it doesn't bend this week while it's on the lift when I'm replacing the clutch this week and kill me...
Google never hurt either. It kinda sucks, the tools mentioned in the thread below mean you should be able to do everything in your garage, even with hand tools the only special things I needed was a spare jackstand and a vice meant I could pull the studs through with hand tools instead of an impact driver but getting them pressed in the right way is easier.
http://www.ft86club.com/forums/showthread.php?t=21563
You need to remove the rear hub to install the long studs, I think you might be able to do the short studs with the hub in place, kinda sucks but not impossible to do.
ineedyourdiddly
Old 12-24-2015, 03:57 AM   #45
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Damn, talk about a blast from the past!
Let me tell ya! I started using anti seize and I never broke a lug stud again! And then I got Muteki SR48s after I got my wheels, and those haven't given me an issue either (I install them without Anti-Seize).
As far as replacing them goes, I've done it on both front and rear in my driveway without removing the hub. As long as it's the stock stud, you shouldn't have an issue. I have been planning on installing ARP Extendeds, but I've had good luck with the stocks+Mutekis, so I haven't bothered.
- The Ancient BRZ Sacrament
by Zaku
The Following User Says Thank You to Guff For This Useful Post:
strat61caster (12-24-2015)
Old 12-24-2015, 04:48 AM   #46
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I never have this problem with mines.
SUB-FT86 is offline   Reply With Quote
Old 12-24-2015, 09:11 AM   #47
Sideways
BRZZZZZ
Sideways's Avatar
Drives: 2013 BRZ Whiteout
Never had any problem with studs on my brz. I use anti seize on my lug nuts too, but not every time I remove my wheels and I only use a very small dab of it. I use anti seize coz during winter snow time, lugs gets rusty from all the salt they use here in Canada and its makes tire change just a little easy.
Sideways is offline   Reply With Quote
Old 12-24-2015, 11:16 AM   #48
shellslinger
Drives: Whiteout FRS
Stripped my driver's side front wheel stud the other day as well. PITA to deal with. I may change over to ARP studs in the near future when time permits.
shellslinger is offline   Reply With Quote
The Following User Says Thank You to shellslinger For This Useful Post:
Astroboy (12-24-2015)
Old 12-24-2015, 09:13 PM   #49
FRS Justin
Drives: 2013 Asphalt FRS
1 Are you running a aftermarket wheel and are they hub centric? Actually measure the hub and wheel, I have seen wheels millimeters off.
2 Are your lug nuts open ended?
3 Do you torque in a star pattern?
4 Are any lug nuts loose or rusted when removed
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 12-28-2015, 03:46 AM   #50
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Try anti seize. coppery stuff not silver one. My father used to grease just the end of it. I dont grease it, I use the anti seize (have been for like 8yrs now). Never had any issues.
Old 12-28-2015, 10:28 AM   #51
Nickosport
Drives: 2015 WRB BRZ Premium
I'd like to add that anti-seize is not a lubricant; its an abrasive.
So all of that BS above about lubricated vs. nonlubricated torque in this particular situation means precisely squat.
That said, either use antiseize and avoid breaking studs, or don't and get used to replacing them. I've definitely broken a dry stud removing the lug nut plenty of times, and ive broken a stud with antisieze by removing the lug nut...once...ever.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
Nickosport is offline   Reply With Quote
Old 12-28-2015, 11:43 AM   #52
Gen3MR2
Gen3MR2's Avatar
Drives: 93 MR2 gen3 3sgte, 13 FR-S
I'll try out the Never Seize.
My predicament now is that I don't know if I should buy OEM studs and keep replacing them if they break, or if I really need to go with something stronger. I was hoping also to gauge exactly how prevalent this problem is so that I might be able to report it to some higher ups at Toyota or Subaru, should that be necessary.
Never seize has done the trick for me. I broke 4 or 5 before I started using it and haven't broken one since.
I was swapping out wheels once or twice a month because of the autox season.
Instagram @gen3mr2
Gen3MR2 is offline   Reply With Quote
Old 12-28-2015, 02:10 PM   #53
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
I've always used a little anti-seize on all of my cars because of the winters, all of my studs are fine.
Scenic Driver is offline   Reply With Quote
Old 12-28-2015, 08:37 PM   #54
Packofcrows
Originally Posted by new2subaru View Post
Hey Pack,
Why not the silver one? I've used it for years without an issue.
Sorry I meant silver not copper.
Silver is better because it doesn't harden and it does better in hot temps and resistant to water. Not that it gets wet there but its good to know it wont just disappear and rub off.
The Following User Says Thank You to Packofcrows For This Useful Post:
new2subaru (12-28-2015)
Old 12-29-2015, 11:08 AM   #55
stevesnj
stevesnj's Avatar
From the Owners Manual... I use a battery terminal brush on the stud end and battery terminal end for inside the nut. Clean off with brake cleaner and install dry.
My 2016 Build thread
Old 12-29-2015, 11:32 AM   #56
Don't muddle up the issue ...... many have already made up their minds ......
Ultramaroon (12-29-2015)
Extened Studs? BlaineWasHere Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-29-2013 11:29 AM
Down hill breaking... ABS? shaofis Issues | Warranty | Recalls / TSB 11 10-22-2012 04:28 PM
Breaking Bad: Season 5 |-Goku-| Off-Topic Lounge [WARNING: NO POLITICS] 15 07-22-2012 01:02 AM
Breaking Bad Season 4 tranzformer Off-Topic Lounge [WARNING: NO POLITICS] 4 10-10-2011 08:17 PM
