Old 12-20-2015, 11:35 AM   #15
Indy_FRS
Thanks everyone for the replys I'll try covering the core and see what kind of results I get with that. I was just trying to find a solution that didn't require me to remove the bumper an additional two times a year, although I am getting quite fast with it. The 15 row Setrab core have is definitely oversized for what I use it for.
I am also running 5w30 oil, I may start returning to 0w20 during winter months. I might have not noticed this if it wasn't for having an oil presure sender. On cold starts I'm over 100PSI for atleast 5 min of idle.
I still might just detach and plug the oil cooler lines and build a small bypass hose for the sandwich plate. Then I won't have heat the additional quart my oil cooler and hoses hold.
Indy_FRS is offline   Reply With Quote
Old 12-20-2015, 11:37 AM   #16
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by FRS Justin View Post
But does it take awhile to warm up or does it cycle in and out?
What are the outdoor temps that start effecting this and does cooler placement have any bearing on said problem?
I think the coldest its been in san Antonio in the morning is 40degrees and mine is working fine. warms up pretty quick but it does drop in and out of optimal range a bit at hwy speeds I was just going to order a higher temp t-stat. My placement is behind fog light area. thanks
Due to the size of oil cooler, even in 80-90 F temps the oil temps level out at 150-160 F street driving. Last weekend on track I saw 184F Max temps without tape in 45 F ambient.
@mkivsoopra
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
FRS Justin (12-20-2015), mkivsoopra (12-20-2015)
Old 12-20-2015, 12:30 PM   #17
OkieSnuffBox
Drives: '23 BRZ Limited
My thought process was that when mine opened, the extra quart and a half that started to flow was the reason. With mine bolted up on the passenger side the extra length of the lines really increases the volume of oil needed. My car takes 8 quarts total with deep oil pan. so does it heat up like factory, no but it doesn't take a whole lot more time maybe 3 minutes as a guess.
Do some data logs then.
Even stock with no oil cooler, it takes 6-7 minutes on the highway for my oil to get up to temp. I work at the airport, so I basically leave the parking lot, have a 1 mile drive, then I'm on the highway.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Old 12-20-2015, 12:33 PM   #18
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
@Indy_FRS as others have mentioned, cover it with a plate. I originally had my license plate on the grill but now I have it side mounted - I installed a black block off plate where the original plate mount was. Since I have a high-mounted oil cooler (JR), it basically covers the entire thing.
1Cor10:23 is offline   Reply With Quote
Old 12-20-2015, 12:35 PM   #19
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
If you want to bypass the cooler instead of covering it, could you just detach the outlet hose from sandwich plate at the cooler and connect it to the inlet side of the SP? Then connect the hose from the outlet side of the cooler to the cooler's inlet? Hope this makes sense, it did in my head.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 12-20-2015, 02:36 PM   #20
Indy_FRS
That's a good idea, however I live in a state that doesn't require front license plates therefore I have a complete intact front bumper. Also to mention I do not have access to my front tow hook where some front plates mount due to my aftermarket crash bar. I'll definately weigh my options, in all honesty the car probably won't get driven a ton until March when all the bastard road salt is removed from the road.
Old 12-20-2015, 03:03 PM   #21
ZionsWrath
Thanks
ZionsWrath's Avatar
Stick your hands between the grill with tape. My bumper doesnt come off to tape it. I have Jackson racing oil cooler
Old 12-20-2015, 05:01 PM   #22
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Originally Posted by Indy_FRS View Post
I am running a Setrab oil cooler core with a Mocal thermostatic plate (Maximal Performance kit). My car is also turbo charged. In Indiana weather below 60F it takes an extremely long time to get my oil in a descent operating range 180F+ to actually enjoy the car. I don't really want to completely pull the oil cooler kit each winter. Fortunately the car is somewhat of a garage queen and doesn't get out much once the roads get salted here.
My best thought was disconnecting the two lines to the core and capping them and installing a bypass loop between the inlet and outlet -an fittings on the sandwich plate. Any concerns or better ideas for this issue.
I imagine I could also block the core but that will require removing the bumper and will somewhat block the intercooler and radiator.
This is what i did. Ended up removing oil cooler though but im running a bypass loop cuz didnt feel like removing sandwich plate
Element Tuning 10:1 Pro Comp Long Block, Ptuning SS GT3076R turbo kit, Exedy Stage 2 Clutch, and a bunch of other stuff
Darryljr11 is offline   Reply With Quote
Old 12-20-2015, 05:35 PM   #23
stugray
Drives: 2013 GBS BRZ Limited
Look this is simple:
If you are running a thermostatic sandwich adapter plate, then it SHOULD warm up to the temp that the thermostat is set to and stay there in very cold weather.
This is not good for long term driving as you want the oil to get above 212F at least occasionally to boil off the water.
If you are running a sandwich adapter that is NOT thermostatic, then to disable it for the winter just:
Unscrew the oil filter.
Unscrew the Tstat plate and put in a ziplock bag & ziptie the plate off to the side.
Screw the filter back on.
Done.
if you do this while the oil is fairly warm, it wont dump much oil into the bag.
if you put it in, in the cold, then expect it to dump some oil out when the outside temps rise again.
The Following User Says Thank You to stugray For This Useful Post:
Old 12-20-2015, 09:33 PM   #24
mrk1
Drives: Sterling BRZ Ltd
I just cap my lines and remove the sandwich plate when it started to get cold and the track closed. I don't mind doing it this way as I see a thermostat as just another thing to fail or leak.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 12-20-2015, 11:43 PM   #25
The boiling thing is a fallacy. The optimum temperature is 180-190 F. The water evaporates just fine at that temp. It doesn't need to boil which, BTW, is below 212F because the crankcase pressure is slightly below ambient pressure.
jawn (12-21-2015), stugray (12-21-2015)
Old 12-21-2015, 09:53 AM   #26
1Cor10:23
1Cor10:23's Avatar
Check out my build log in signature, I had my plate drilled in the grill and not the bumper. The holes are barely noticeable and I even run the plate during summer because I like to DD as close to 200F as possible. When I get to the track, I remove
Old 12-21-2015, 10:17 AM   #27
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
PV=nRT, yo.
jawn is offline   Reply With Quote
The Following 2 Users Say Thank You to jawn For This Useful Post:
Spartarus (12-21-2015), Ultramaroon (12-21-2015)
Old 12-21-2015, 10:23 AM   #28
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Man, all I do is remove the thermostat all together from my Mishimoto plate as it is a normally open setup the lets most of the oil bypass the cooler, but when it gets hot it closes and that forces the oil through the core and around to the other side. It still takes up a little space in the bypass area, so I removed it all together for max bypass flow. The coldest my car has seen so far this year is -20C and it warms up fine.
BRZ Nav Bypass lxsedan CANADA 43 03-30-2015 07:44 AM
FS: Kraftwerks supercharger kit 2 months old $3000! Oil cooler 450 Derka Engine, Exhaust, Bolt-Ons 5 03-21-2015 07:04 AM
BRZ Nav bypass Questions Heero CANADA 0 03-07-2015 01:12 PM
BRZ NAV/DVD bypass Scooby South Electronics | Audio | NAV | Infotainment 88 02-24-2014 03:41 PM
tpms bypass? d.liang Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 02-24-2014 03:32 PM
