Old 12-19-2015, 02:27 PM   #127
ztan
Drives: Toyota 86
Originally Posted by Kodename47 View Post
Please do explain then how the base/normal/safe all interact....
Just had a look at the disassembly.
There is an interpolating factor at FFF89C88 (A01G) which is used to interpolate between AVCS Intake Base table and the return from AVCS Intake Safe/Normal table (Safe/Normal switch is determined by IAM with hysteresis). Exhaust code is virtually identical. Have not logged FFF89C88 to see when it is active, but presumably not very much.
ztan is offline   Reply With Quote
The Following 3 Users Say Thank You to ztan For This Useful Post:
aagun (12-06-2016), KoolBRZ (12-19-2015), makinen (12-20-2015)
Old 12-19-2015, 03:02 PM   #128
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
I would also like to know how many cells it averages. Is it a 3 cell spread across rows, and a 5 cell spread down columns? I know there is a spread for smoothing. I would just like to know how wide it is to know how long a change will last across RPM's or Load. Also, which is the more advanced table, and which is the less advanced table, Safe or Normal, as determined by the IAM.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
Old 12-19-2015, 07:41 PM   #129
Kodename47
Kodename47's Avatar
Drives: UK GT86
@ztan that's how I was told and that's why base and the safe maps are set the same (or all 3 in my case).
There is no smoothing.
Safe = IAM high
Normal = IAM Low
I have defined boundary of IAM = 0.4 for the normal/safe determination.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-19-2015, 08:15 PM   #130
shr133
shr133's Avatar
Drives: 2013 FRS
I tried out a tune with modified base maps yesterday. It felt like too little, too much. Not much under 2800 RPM, then it really screamed. AFR's were all over the place. I switched back to a known good tune right away. I've found it's always good to keep at least one known-good tune in my OFT, then try out with the other four tunes. Today I'm trying out slightly de-tuned Base tables. I reduced the highest numbers and smoothed out the dips, since I am FI I don't need compensation for the dips. If it works better I will post it. I have determined, however, that the Base tables are active, no matter what temp the engine is at.
That's why I need to upgrade to race rom so I can run maps back to back...
I'm not sure when the base map would take over so far now make all the maps the same so I know for sure what I like or don't like...
Hopefully it warms up again so I can do some tweaks....
Below 20 last couple of days.... Hates the
shr133 is offline   Reply With Quote
Old 12-19-2015, 08:50 PM   #131
ztan
Drives: Toyota 86
The Pull2D and Pull3D functions do not smooth across cells - they are direct linear interpolation based on the 2 nearest values in a 2D table and 4 nearest values in a 3D table.
The Following User Says Thank You to ztan For This Useful Post:
thambu19 (12-21-2015)
Old 12-20-2015, 01:57 PM   #132
KoolBRZ
KoolBRZ's Avatar
Would you mind...
Safe = IAM high
Normal = IAM Low
Could you show the tables you have created for Base, Safe, and Normal?
Old 12-20-2015, 02:25 PM   #133
Kodename47
Kodename47's Avatar
Drives: UK GT86
All 3 are set the same on mine.
I can't post them for 2 reasons:
1) They're not my cam maps
2) If I use the ECUtek custom maps, it renders these irrelevant.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-20-2015, 04:34 PM   #134
ztan
Drives: Toyota 86
Greddy T518Z turbo. Base maps similar, Safe and Normal identical.
The Following 2 Users Say Thank You to ztan For This Useful Post:
freerunner (12-21-2015), KoolBRZ (12-20-2015)
Old 12-20-2015, 05:14 PM   #135
KoolBRZ
KoolBRZ's Avatar
Thank you @ztan. Once again, the beauty of using Open Source software is the ability to show what you know without being sued for it.
Old 12-20-2015, 06:19 PM   #136
ztan
Drives: Toyota 86
I agree. As you're well aware, Open Source is my preferred route.
Credit @Shiv@Openflash where credit is due. The AVCS map I use is based on his OFT350 work, running less overlap in a few areas where I was still getting quite a bit of knock. Not sure if this was due to running a turbo that spools just that bit quicker, local environment and fuel, or just the way I drive (on the road, not on the dyno).
Old 12-20-2015, 07:05 PM   #137
KoolBRZ
KoolBRZ's Avatar
These maps feel a bit tame under 3000 rpms. I like what @shr133 did at the low rpms, so I'm going to do some blending and I'll post what I find works for me.
Old 12-20-2015, 07:10 PM   #138
shr133
shr133's Avatar
Drives: 2013 FRS
I was wondering what a turbo map would look like....
A turbo may be in the future...
Old 12-20-2015, 07:58 PM   #139
shr133
shr133's Avatar
Drives: 2013 FRS
I tweaked my maps a little, I'm bring in the cam timing faster moving my map 1 step to the left and going to a max of 35 degrees of intake...
The biggest thing is I went to 5 degrees less exhaust timing with a max of 25 degrees...
Feels less "torquey" but revs much better and seams to run cleaner...
Have to drive it a little more but spun the tires good going to second for the first time so it must be running better...
I think I'm really close on the maps, now I'm working on the optimum split...
Old 12-20-2015, 08:52 PM   #140
KoolBRZ
KoolBRZ's Avatar
Can you show pics?
Timing chain issue? Hardpack Issues | Warranty | Recalls / TSB 14 01-10-2016 11:25 PM
AVCS failures? hmong337 Forced Induction 26 02-12-2015 03:01 PM
Stock Rom: Timing + Learn Value sw20kosh Software Tuning 7 12-11-2013 07:09 PM
E85, Boost and Ignition Timing jamesm Software Tuning 23 12-11-2013 02:19 PM
Timing belt shredded..?! drei CANADA 5 12-06-2013 05:54 PM
