Old 12-15-2015, 10:13 PM   #603
ButeraFRS
Guest
Posts: n/a
Welp it was a long and tiresome day, but it's finally done.
The Following 2 Users Say Thank You to For This Useful Post:
Clipdat (12-16-2015), DylanFRS (12-16-2015)
Old 12-15-2015, 10:20 PM   #604
adrixe
adrixe's Avatar
Drives: 2014 Subaru BRZ
Niice! Got the same keyboards. Awesome!
Sent from my SM-N900W8 using Tapatalk
adrixe is offline   Reply With Quote
Old 12-15-2015, 10:35 PM   #605
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Anyone other than me still playing BF4?
Originally Posted by humfrz
I'm old and lazy
Old 12-15-2015, 10:36 PM   #606
ButeraFRS
Guest
Posts: n/a
Was trying to load it up again but I forgot my password. When I get it recovered I'll pm you my ea name
The Following User Says Thank You to For This Useful Post:
Clipdat (12-15-2015)
Old 12-15-2015, 11:24 PM   #607
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Just got all my parts in for my first PC build. Should have it put together this weekend! Time for some R6:Siege and Rocket League!
Old 12-16-2015, 12:53 AM   #608
Clipdat
Proud of BOXER
Clipdat's Avatar
I'm not great.
I'm old and lazy
Old 12-17-2015, 07:49 PM   #609
ButeraFRS
Guest
Posts: n/a
I'm getting CPU temps of 70 on r6 siege on ultra settings. Running a cool master evo 212, Intel i7 4790k and a msi 970
Is this good, bad or normal?
Old 12-17-2015, 08:26 PM   #610
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Sounds high. Re-seat the heat sink with fresh thermal paste. Make sure the fan is working and blowing. I usually use a credit card to get paste off.
Old 12-17-2015, 08:31 PM   #611
ButeraFRS
Guest
Posts: n/a
Yeah I'm gonna try that. Should I use rubbing alcohol to help Get some of the paste off as well?
Old 12-17-2015, 09:41 PM   #612
EAGLE5
Dismember
EAGLE5's Avatar
Sorry. Been a while since I've done this. Yes, a credit card to scrape (bamboo would do too) and then a cotton swab and alcohol to get any oils and gunk off. Just make sure you get all lint off at the same time. Canned air helps, but it's not worth buying. Air dry. Then new paste. It doesn't take much paste. I usually spread it out a little, but I've heard varying theories on the right way. There are differences in paste quality, but anything more than 5 or 10 bucks is scamming you. Under load, it should probably get down to 50 degrees C. I usually just use stock intel heat sinks. They work great for anything but overclocking.
Old 12-17-2015, 11:31 PM   #613
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Just a pea sized drop in the center is all you need for a good even spread. Don't bother smearing it around.
There's a good video on YouTube that shows it with a piece of clear plastic.
Old 12-17-2015, 11:40 PM   #614
Vladimir Tutin
Vladimir Tutin's Avatar
Drives: '13 Hot-Lava FR-S
Use 70% isopropyl or better rubbing alcohol with a qtip.
By the way, 70c is up there but it's not in danger territory yet. You still have about 20c or so until you hit the thermal limit. What temps are you getting under a stress test?
Vladimir Tutin is offline   Reply With Quote
The Following User Says Thank You to Vladimir Tutin For This Useful Post:
fumanchu1 (12-18-2015)
Old 12-18-2015, 01:09 AM   #615
EAGLE5
Dismember
EAGLE5's Avatar
70c can probably lead to CPU throttling and will definitely limit things like overclocking.
Old 12-18-2015, 07:41 AM   #616
Vladimir Tutin
CPU throttling occurs around 90c-100c and has a max temp rating of 105c on the 4790k. If he gets throttled when as low as 70c then there is something wrong with the CPU. Yes if that's idle temps it'll limit overclocking. Hell, many overclockers are comfortable licking 80c. 70c isn't a good temp and yes he should remount the cooler, but it's not a dangerous temp.
pc master race, u no have 3080
gamers lounge Touge_ninja Off-Topic Lounge [WARNING: NO POLITICS] 25 01-21-2014 04:32 PM
GT Acadamy Gamers Banned from Britsh GT Pro-Am WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 16 02-11-2013 06:37 PM
