#519 |
Panda Trueno
Drives: No twin now.
That's cool, but it isn't an average of 1/4 mile times from multiple people at a real track. There are very few people who take these cars to the dragstrip anyways, but it wouldn't be outrageous to think someone will.
| The Following User Says Thank You to Summerwolf For This Useful Post: | FRS Justin (12-17-2015) |
#520 | |
1337
Drives: 2013 BRZ WRB S/C
#521 | ||
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
My installer and I had the unfortunate luck of getting sent the wrong file and only realizing it after the install at 5:50pm on a Fri. We tried e-mailing anyway in the hopes of getting a reply and luckily/surprisingly we did, got the correct file and I was good to go. |
| The Following 2 Users Say Thank You to BigFatFlip For This Useful Post: | Firesnake (12-17-2015), FRS Justin (12-17-2015) |
#522 |
Drives: 2013 FRS
Good tip! I can't find the instruction to email them the info for the file in the provided book. I'm testing mine first and discovered they're not available after calling in.
#523 | |
Edit: after some research, it looks like the throttle indicated by ecutek is the drive by wire throttle body position, not the pedal. At full pedal down, ecutek shows it at 80% while OFT shows it at 95%. I learn something everyday! Last edited by BigFatFlip; 12-17-2015 at 02:14 PM. |
#524 |
Drives: 2013 Asphalt FRS
Your right its in the 80s but it would be nice to know if his foot was 100%down on the floor
Edit: After posting I wanted to check myself so I pulled up a old log file and I was wrong mine is in the 80's
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp Last edited by FRS Justin; 12-17-2015 at 04:20 PM. |
#525 |
I would take it to the strip and hammer on it. hell ya
Facebook FT86PROJECT9S 710whp |
#526 | |
Drives: Red Toaster(Dodge Nitro)
Why is it that you can't open it 100%? And can one tune the throttle map for it? Sent from my Nexus 5 using Tapatalk
I mostly lurk, still don't own an 86...
#527 | |
#528 | |
I just scanned the ECUTEK manual and came up with nothing. the only thing that it talked about was. Wide Open Torque Threshold Accel Pedal to Desired Torque And neither seem to cover it, it was kind of scary thinking about adjusting it, and exactly why I pay to have this done.
#529 |
Drives: UK GT86
Throttle % will always be 80% in ECUtek, throttle angle varies like in OFT however if you log the TPS voltage it doesn't change. So 80% is max opening, it indicates 80% of the TPS voltage range. This cannot be increased.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | FRS Justin (12-17-2015) |
#530 | |||
#531 |
Drives: 2013 FRS
Hey guys, Edelbrock did get back to me the same day, nice service!
I was able to test flash the ECU to the Edelbrock tune, and FYI, you have to email them the calibration ID of your existing ECU to get the right Edelbrock calibration file from them. Now that I flashed it I need to set it back to stock until I install, any ideas on how to do that? It seems the original ECU calibration I was running is not listed amongst the calibrations the software downloaded automatically. I need ZA1JA01C. Where do I find this? Another interesting note, despite having the above code I'm actually running a modified ZA1JB01C calibration provided by Edelbrock... should I just load the stock version of that (which is present in the EcuTek provided files)? Shoot, hope I didn't just get myself stuck! |
#532 | |
Drives: UK GT86
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | 86fun (12-17-2015) |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
