Old 12-17-2015, 01:05 PM   #519
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
That's cool, but it isn't an average of 1/4 mile times from multiple people at a real track. There are very few people who take these cars to the dragstrip anyways, but it wouldn't be outrageous to think someone will.
The Following User Says Thank You to Summerwolf For This Useful Post:
FRS Justin (12-17-2015)
Old 12-17-2015, 01:09 PM   #520
djdnz
1337
Drives: 2013 BRZ WRB S/C
Originally Posted by 86fun View Post
Those who have installed, where did you get the Edelbrock calibration file from? The instructions refer to a flash drive to copy calibration files from, but there is no flash drive, just a DES stick for the license. Several compatible calibration files can be found after updating the app but they all have random names and none are obviously named to be from Edelbrock. I asked Edelbrock but they are offline for the holidays...
Edelbrock emails you your tune after you send them the details of your ECU... I would maybe try giving them a call, it would SUCK if they didn't get back to you until after christmas.
djdnz is offline   Reply With Quote
Old 12-17-2015, 01:31 PM   #521
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
For any future owners planning on installing it themselves or done by a shop, make sure you (or your shop) e-mails edelbrock well in advanced to get your file and double check that its compatible.
My installer and I had the unfortunate luck of getting sent the wrong file and only realizing it after the install at 5:50pm on a Fri. We tried e-mailing anyway in the hopes of getting a reply and luckily/surprisingly we did, got the correct file and I was good to go.
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post:
Firesnake (12-17-2015), FRS Justin (12-17-2015)
Old 12-17-2015, 01:38 PM   #522
86fun
Drives: 2013 FRS
Good tip! I can't find the instruction to email them the info for the file in the provided book. I'm testing mine first and discovered they're not available after calling in.
86fun is offline   Reply With Quote
Old 12-17-2015, 01:38 PM   #523
BigFatFlip
BigFatFlip's Avatar
Originally Posted by FRS Justin View Post
Did you have it floored or just 60 to 70% wide open? It never showed close to 100% TPS or TPA....
Don't remember, did the pull on an empty side street and was more focused on my surroundings. Like @CSG Mike mentioned, even with the throttle to the floor, the highest I've seen it was at 80%.
Edit: after some research, it looks like the throttle indicated by ecutek is the drive by wire throttle body position, not the pedal. At full pedal down, ecutek shows it at 80% while OFT shows it at 95%. I learn something everyday!
Old 12-17-2015, 03:29 PM   #524
FRS Justin
Drives: 2013 Asphalt FRS
You can't hit 100% throttle position.
Your right its in the 80s but it would be nice to know if his foot was 100%down on the floor
Edit: After posting I wanted to check myself so I pulled up a old log file and I was wrong mine is in the 80's
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 12-17-2015, 03:31 PM   #525
FRS Justin
I would take it to the strip and hammer on it. hell ya
710whp
Old 12-17-2015, 03:32 PM   #526
HUNTERANGEL121
HUNTERANGEL121's Avatar
Drives: Red Toaster(Dodge Nitro)
Your right its in the 90s but it would be nice to know if his foot was 100%down on the floor
Looking to be edumucated.
Why is it that you can't open it 100%? And can one tune the throttle map for it?
I mostly lurk, still don't own an 86...
HUNTERANGEL121 is offline   Reply With Quote
Old 12-17-2015, 03:38 PM   #527
FRS Justin
Ecutek will vary actually it will depend on how it's scaled, I was just asking because if you did and it was that low it would lead me to believe it should be checked. I assumed since you said pull it was wide open but the numbers lead me to ask.
710whp
Old 12-17-2015, 04:17 PM   #528
FRS Justin
I just scanned the ECUTEK manual and came up with nothing. the only thing that it talked about was.
Wide Open Torque Threshold
Accel Pedal to Desired Torque
And neither seem to cover it, it was kind of scary thinking about adjusting it, and exactly why I pay to have this done.
710whp
Old 12-17-2015, 04:31 PM   #529
Kodename47
Kodename47's Avatar
Drives: UK GT86
Throttle % will always be 80% in ECUtek, throttle angle varies like in OFT however if you log the TPS voltage it doesn't change. So 80% is max opening, it indicates 80% of the TPS voltage range. This cannot be increased.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-17-2015, 04:46 PM   #530
BigFatFlip
BigFatFlip's Avatar
^What he said. There's a handful of threads about this. Here's an excerpt:
Throttle Position
You will often see you throttle percentage at less than 100% in your logs even though you have pedal nailed to the floor. This is because its a drive by wire throttle and its logging the throttle plate position not the accelerator pedal position.
OFT (open flash tablet) generally logs WOT (wide open throttle) around 95%
Ecutek arround 80%
You may also see the throttle percent taper off at high RPM this is normal and ECU adjusting throttle plate angle.
ECU (engine control unit) will also back off throttle if you loose traction with the traction control or stability control active
source: http://www.ft86club.com/forums/showthread.php?p=1842501
Old 12-17-2015, 06:40 PM   #531
86fun
Drives: 2013 FRS
Hey guys, Edelbrock did get back to me the same day, nice service!
I was able to test flash the ECU to the Edelbrock tune, and FYI, you have to email them the calibration ID of your existing ECU to get the right Edelbrock calibration file from them.
Now that I flashed it I need to set it back to stock until I install, any ideas on how to do that? It seems the original ECU calibration I was running is not listed amongst the calibrations the software downloaded automatically. I need ZA1JA01C. Where do I find this? Another interesting note, despite having the above code I'm actually running a modified ZA1JB01C calibration provided by Edelbrock... should I just load the stock version of that (which is present in the EcuTek provided files)?
Shoot, hope I didn't just get myself stuck!
Old 12-17-2015, 06:43 PM   #532
Kodename47
Kodename47's Avatar
Drives: UK GT86
Load the B01C as it's the most up-to-date compatible C series file.
.: Stealth 86 :.
Kodename 47 DJ:
86fun (12-17-2015)
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
