Old 06-05-2012, 02:20 AM   #1
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Blocking Your TPMS Light
OK, you swapped wheels and you didn't swap in your TPMS sensors. This means that you experienced several minutes of glee when your TPMS light didn't illuminate, but then it started flashing in your face. While there may be some fancy technical way to disable the system, I chose to take the shade-tree mechanic route and just block the light. Here is how I did it.
CLARIFICATION: Removing your TPMS sensors from the car will NOT affect the traction control system. You can still disable traction control no matter what. Also, the TPMS sensors need movement to activate, so sealing them in a canister in your trunk (or inside your spare tire) will not work because they won't be rotating.
Start by removing the single Phillips screw that is above your tach.
Now you can lift the front edge of the cluster cover while also pulling forward. I placed my palm near the back of the cover while pulling forward, and simultaneously lifted the front edge up.
Now you have revealed two more screws that have to come out. These fasten the instrument cluster to the dashboard.
Now over to the left side of the dash. Use your finger to pry the lower part of the cover out toward you.
The cover will just pop off.
Now remove the Phillips screw that is near the bottom area revealed when you removed the cover.
Just above your gas pedal is another Phillips screw that needs to come out.
The lower dash cover will pop out now. Disconnect any plugs. I like to use a small flat-tipped screwdriver to push in the tab, then twist to force the plug out of the socket. NEVER pull on the wires to get the plug out.
With the lower cover off, you need to pry the radio surround out a little. You don't need to remove the entire piece, just get it off enough to slip the cluster surround out from beneath it.
You have to firmly pull the top left and right corners of the cluster surround out of the clips. I pried pretty hard and it finally came out without breaking. (whew)
Now you should be able to remove the cluster. Oops, did we forget something?
Don't forget to unplug the cluster! Not too hard.
We need to get to the cluster dial face, so lets split this sucker open. There are six plastic tabs around the cluster that we need to loosen. Start with these two on the top.
Then hit the two on the sides, and lastly the two on the bottom. Use a small flat-tipped screwdriver and LIGHTLY pry the black plastic tab up. Don't go crazy or you could snap it off!
After attempting to remove the needles to get the cluster face off, I realized I didn't have the skills, so I just gently pried the lower speedometer face away to reveal the light cavity for the TPMS.
I used some black electrical tape that I folded over on itself several times. I cut it roughly to the same dimensions as the light cavity, only slightly larger.
Finally, I used some long needlenose pliers (or tweezers would work) to slide my black tape piece into the cavity. Follow the instructions in reverse to reinstall everything.
It worked perfectly! The light is now hidden from my view and I will never be annoyed by it again!
The Following 22 Users Say Thank You to DarrenDriven For This Useful Post:
8R6 (07-17-2014), Anthonytpt (02-04-2014), Blackrsx (02-15-2014), Bonburner (02-04-2014), chulooz (06-10-2012), Dadhawk (06-05-2012), D_Thissen (12-22-2016), flippy (04-17-2015), H1C (02-13-2024), Khyron686 (06-08-2012), mattles (06-05-2012), neutron256 (06-05-2012), normancw (02-04-2014), phm14 (06-09-2012), Randyliciious (09-12-2013), RedAlert (10-09-2013), Shanahan (04-04-2013), slowandcurious05 (05-25-2015), SuperTom (01-21-2020), toddj55 (04-03-2013), xxBrun0xx (11-23-2015), YinYang1980 (07-01-2012)
Old 06-05-2012, 04:30 AM   #2
MRZ415
Drives: 2015 Subaru WRX
I wonder wont it be easier to disable TMPS via software ?
on my VW for example I used VCDS and disabled TMPS sensors,
so I can only imagine something similar can be done on Subarus ?
MRZ415 is offline   Reply With Quote
Old 06-05-2012, 06:15 AM   #3
blalor
Drives: WRB BRZ Limited 6MT
Mods, please sticky this!
blalor is offline   Reply With Quote
Old 06-05-2012, 07:39 AM   #4
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
No need for a sticky it's in the directly which is already a sticky.
Darren, can the white housing be separated? If so you can just remove the bulb which would be cleaner IMO.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
civicdrivr (06-05-2012)
Old 06-05-2012, 08:12 AM   #5
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Excellent write up. Althought I think I'll just be living Witt the light or buying the sensors.
Old 06-05-2012, 11:41 AM   #6
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
Way too much work for outcome.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
The Following User Says Thank You to russv For This Useful Post:
mixtape (04-14-2016)
Old 06-05-2012, 11:52 AM   #7
DarrenDriven
NW Region Moderator
I tried to separate the gauge cluster to remove the light, but to do that you need to pull all the needles, pull the dial face off and access the screws underneath it. I gently tugged on one needle to see if it would come off easily and it didn't. I feared that I would damage the cluster by removing the needles, so I went this route instead.
russv: wait until you have that yellow light flashing in your face for a few days and then see if this ten minutes of work is worth it! I think you'll change your mind.
The Following User Says Thank You to DarrenDriven For This Useful Post:
Old 06-07-2012, 05:57 PM   #8
Zaneman
Drives: 2013 BRZ limited
The last time I pulled off my needles I used 2 plastic spoons... Just a thought for the next person that tries this.
Zaneman is offline   Reply With Quote
Old 06-08-2012, 09:07 AM   #9
MTeator
First 86
bravo for the effort and documenting that. But holy crap I'm not that brave with taking apart my dash
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
Old 06-08-2012, 09:12 AM   #10
Chenslee
Chenslee's Avatar
Drives: 2015 Halo FR-S
meh.
Chenslee is offline   Reply With Quote
The Following User Says Thank You to Chenslee For This Useful Post:
sparks (06-08-2012)
Old 06-08-2012, 11:21 AM   #11
yayforaddison
yayforaddison's Avatar
Drives: Whiteout FR-S
Or just get sensors put in your new wheels. Much easier
yayforaddison is offline   Reply With Quote
The Following 5 Users Say Thank You to yayforaddison For This Useful Post:
20valvewynn83 (01-31-2013), 8RZ (12-20-2016), Huehuecoyotl (04-11-2013), mixtape (04-14-2016), OAKOS Automotive (12-03-2013)
Old 06-08-2012, 11:25 AM   #12
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Chenslee View Post
meh.
Too bad that won't work. The sensors need to be awake which requires motion, not pressure. This isn't a Toyota Tundra
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-08-2012, 11:27 AM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yes.. and $400 from Tire Rack plus dealership charge to reprogram them since the ATEQ tools and such don't work yet.
I've been driving on mine since yesterday and the light still hasn't come on, I guess my driving has all been under the threshold for the system to complain, but still, I've driven with CELs for years so the little fishbowl light isn't going to bother me
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-08-2012, 01:15 PM   #14
DarrenDriven
NW Region Moderator
The mod only took about 10 minutes, was like five screws and is completely reversible. I'm not sure why people are freaking out about it!
TPMS Sensors kanundrum Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 249 06-21-2019 04:22 AM
TPMS Sensors.. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 04-08-2014 01:22 PM
Subaru TPMS Nonsense Grimlock BRZ First-Gen (2012+) — General Topics 67 10-07-2013 03:15 PM
TPMS Sensors ashtray Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 78 05-24-2013 04:24 PM
TPMS Sensor Part Number or Compatibility civicdrivr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-07-2012 01:06 PM
