Old 12-14-2015, 11:10 PM   #15
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
^ This hahaha!!
I have a remote start for a reason
In the real cold start world:
Start it
Let it drop from high to mid idle
Put in gear and drive it away
Take it easy for 5 minutes or so of driving to bring cats, bearings, oil and fluids up to semblance of earth like temperatures
Let er rip
The only reason I would let it sit and idle for 5 minutes or more is to allow the heater to come to temperature and blow through the defroster before tackling 1/2 an inch of solid ice all over the car.
Tcoats idea is better than remote start, two years ago we had record cold in PA getting to below 0 Degrees Fahrenheit on multiple occasions and way colder with wind chill. I did a little experiment and timed how long it took to get my 2014 Rogue to proper engine and oil temp levels as is displayed on the multi controllable display in the gauge cluster. Around 13.5 minutes at idle to get coolant and oil to temp on idle, and literally 6 minutes to get coolant and oil to temp by driving around and less mpg wasted because I was driving off in the morning to work/school rather than idling away.
Old 12-14-2015, 11:34 PM   #16
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
My car will see -35C without windchill a number of times each winter so I let it idle lots and my gas milage is completely crap but I don't care as it is still crap in the summer hahaha. I didnt buy the FRS for fuel economy
But you are right it warms up much faster if you drive it
86kahl (12-15-2015)
Old 12-14-2015, 11:44 PM   #17
FRSBRZGT86FAN
Lol wasn't directly referring to this car mpg wise anywho I get 17 MPG because I constantly push it in even the slightest curvy situation lol
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
go_a_way1 (12-15-2015)
Old 12-15-2015, 01:21 AM   #18
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
Heaps of stuff happens at initial cold startup
Different compensations are applied on hot start
see diagram below
On Cold start
Fueling is enriched to heat cats, fast idle and retarded timing (thats the noisy bark at startup)
Different offsets to MAF (fueling) are applied depending if in neutral or in gear.
Different idle depending on coolant temps.
If you load the engine so it drops below its idle target of say 1800 rpm in initial phase the eCU applies more compensation to try to hold the idle at 1800, so if you then depress the clutch it will idle above 1800 for a bit , before settling back to its target idle speed. It a bit like anti-stall.
Idle targets A through to I are applied throughout the startup/warmup phase depending upon time since startup I suspect and coolant temps ,probably other factors as well
Best let it idle for a minute or so till idle settles to about 1200.
Awesome information! Thanks for the write up, really helpful. I'll just give it a bit more time to warm up while these temps stay the way they are.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
Manic is offline   Reply With Quote
Old 12-15-2015, 06:33 AM   #19
If I read yours right you do that to warm up the passenger compartment not the engine anyway. It is the difference between warming up the car and warming up the drive train.
FRSBRZGT86FAN (12-15-2015), go_a_way1 (12-15-2015)
Old 12-15-2015, 07:52 AM   #20
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Your right its mainly to get the heater to start working sooner. I do find that my oil temps are close to 100F when I start to drive though so thats better then it being really cold right
Old 12-15-2015, 08:04 AM   #21
Every little bit helps.
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 02:14 PM
Cold start JG Engine, Exhaust, Transmission 8 08-29-2015 02:55 AM
E85 cold start Turdinator Software Tuning 8 08-29-2014 11:12 AM
backfire at cold start FreaQshoQ Scion FR-S / Toyota 86 GT86 General Forum 15 10-16-2013 06:21 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
