Old 11-30-2015, 01:00 AM   #1
tonytduc
tonytduc's Avatar
Oil Catch Can for Turbo Setup
Which brand oil catch can do you guys run with your turbo setup? Thanks
tonytduc is offline   Reply With Quote
Old 11-30-2015, 01:21 AM   #2
Northwest86
Drives: Velocity Orange 86 GT
Radium Dual setup. Excellent fitment on left and Right hand drive. Right hand drive just had to tweak the master cylinder hardline. They come with quality made brakets and all the required hardware. Thats them in my setup.
Northwest86 is offline   Reply With Quote
The Following User Says Thank You to Northwest86 For This Useful Post:
tonytduc (11-30-2015)
Old 11-30-2015, 10:59 AM   #3
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
http://www.ft86club.com/forums/showthread.php?t=24340
xkalelx is offline   Reply With Quote
Old 12-14-2015, 05:47 AM   #4
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Crawford AOS:
http://www.ft86club.com/forums/showthread.php?t=98687
Efferalgan is offline   Reply With Quote
The Following User Says Thank You to Efferalgan For This Useful Post:
DarkPira7e (12-18-2017)
Old 12-14-2015, 07:32 AM   #5
Northwest86
Wow thats alot. Boosted application I presume?
Old 12-14-2015, 09:27 AM   #6
Efferalgan
Yep. HKS V2 SC. There is link to my thread on this in the previous post.
Old 03-01-2016, 01:18 PM   #7
wbradley
Sarcastic SOB
wbradley's Avatar
The oil location indicates blowby from the crankcase vent, not the PCV. I don't think there's reason to thing there's anything wrong with the can you have.
Old 03-21-2016, 11:34 AM   #8
Efferalgan
This AOS combines both vent routes into the same cavity, so it's clear that the oil comes back to the engine via the intake but it's not certain that this oil comes from the crankcase vent initially. The 2 lines are not isolated.
Old 03-21-2016, 04:20 PM   #9
wbradley
Sarcastic SOB
wbradley's Avatar
My catch can intercepts blow by from the PCV and returns it to the intake manifold where the PCV normally does. The crankcase vent returns oil to the intake before the throttle body. I thought perhaps your setup was similar in which case this would explain the oil in the throttle body.
Old 03-21-2016, 05:21 PM   #10
Efferalgan
Nope. The Crawford merges both routes, it's not a "twin beds room" with two separate cans with own ins and outs but one "king size bed"
Old 03-21-2016, 06:33 PM   #11
wbradley
Sarcastic SOB
wbradley's Avatar
Wow it seems a mystery how oil ends up in front of the butterfly valve.
Old 03-22-2016, 01:44 AM   #12
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Or you can... you know... vent it to atmosphere?
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 03-22-2016, 07:05 AM   #13
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I purchased a universal catchcan that vents to atmosphere. I had to make a bracket that holds the can to the battery. I deleted all pcv valves and have 1/2 hoses leading to the catch can. Installed a 1/2 barb where the crankcase pcv was.
The only thing I may do is delete the catchcan filter and run a hose from the top of the catch can to near the trans or tap the turbo air filter and have it recycling. I can smell oil/gas with the AC on now
I used 1/2 hoses because the oil doesn't get as much build up compared to tiny hoses that alot of theses kits use.
Cost to make my own setup was $130 including catchcan, barbs, hoses and metal to make bracket.
Before catchcan and pcv delete I was getting tomuch pressure in my crankcase and it was causing mystery oil leaks. Ever since the install I've had zero leaks.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following 2 Users Say Thank You to GsxrMe For This Useful Post:
#maverick# (03-22-2016), ORGANIZED-CHAOS (04-02-2017)
Old 03-22-2016, 02:40 PM   #14
kbye
kbye's Avatar
Drives: 2014 FR-S
I don't know why ppl VTA. It stinks and the fumes are likely gonna stay trapped in the engine bay, leaving residue. It's the easy way out, if you ask me. Do it right and catch it or recirculate it.
kbye is offline   Reply With Quote
Radium Catch Can Setup? Turbo idle problem drambo136 Forced Induction 36 11-11-2018 07:05 PM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 06:36 AM
FS: Radium Universal Catch Can - BRZ/FR-S Setup F1point4 Engine, Exhaust, Bolt-Ons 8 04-09-2015 01:08 PM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring NY / NJ / CT / PA 0 10-20-2014 10:48 AM
High HP turbo catch can setup Dan@AWD Forced Induction 32 08-06-2014 08:52 AM
