Old 12-13-2015, 01:14 AM   #15
xiayu0320
Drives: 2013 GBS BRZ
Originally Posted by FRSBRZGT86FAN View Post
If you need help just pm me or @steve99
Ok. Thank you so much. I'll pm you if I still get error tomorrow.
xiayu0320 is offline   Reply With Quote
Old 12-13-2015, 01:32 AM   #16
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by xiayu0320 View Post
Thanks, I'll try it tomorrow. I just want to make sure OFT can flashing the ECU if file in ECU that incomplete.
Worse comes to worse though and it still doesn't work I'd worry that because the car can't start your battery voltage is rapidly dropping every time you try to crank. That means you may need to go to a dealer and try and get something warranty repaired
Old 12-13-2015, 01:53 AM   #17
xiayu0320
Yes that's what I'm worry about. I don't want go to dealer. That's to much work for me. The car can't start, I'll need towing and they are close tomorrow.
Old 12-13-2015, 09:17 AM   #18
steve99
Drives: FT86
File in my computer, I'll post later. I think is green and lc works fine before. I just try to flashed original stg2 uel 93oct file that I download from openflash website, I didn't edit anything in that stg2 file.
In this situation where you have problems best to flash original stock rom stored in OFT called "Original File" this is your original stock rom stored by oft. This may allow oft to flash over corrupted rom.
I have done this with Tactrix but not OFT
Old 12-13-2015, 11:02 AM   #19
xiayu0320
I'll try this later. I may buy a tactrix if oft still doesn't work. I tried to flash back to original file many times yesterday but oft still shows error.
Old 12-13-2015, 12:02 PM   #20
FRSBRZGT86FAN
That sucks dude, what about the flash over to stage 1 or stage 2?
Old 12-13-2015, 12:07 PM   #21
xiayu0320
Always show me error. Every times. Sounds like out of battery when I start the car, just 1 sec with that sound.
Old 12-13-2015, 12:16 PM   #22
FRSBRZGT86FAN
Do you still have the 2 or 3 year roadside assistance? You might need to call em up and have em transport to the dealer even though it's Sunday they'll do it.
Old 12-13-2015, 12:21 PM   #23
xiayu0320
I don't have it. I only have the Subaru gold warranty. But I think it will cover it.
Old 12-13-2015, 12:33 PM   #24
FRSBRZGT86FAN
Worse comes to worse in the diagnosis don't say you did anything related to tuning and such, also you might want to put the OEM headers back on. Depending on the dealer they will definitely invalidate the warranty if that stuff is left on there and they notice the ecu calibration stuff is all messed up. Just say it didn't start in the morning and earlier on it was running quite rough.
Old 12-13-2015, 12:45 PM   #25
xiayu0320
Yes, I think I need to put the oem header back on if I still can't flash stock rom into ECU today. Then go to dealer.
Old 12-13-2015, 12:50 PM   #26
steve99
Drives: FT86
make sure battery is charged, oft will not flash if volts too low.
Old 12-13-2015, 12:53 PM   #27
xiayu0320
Hope it just low volts. I'm gonna find a charging cable.
Old 12-13-2015, 04:33 PM   #28
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
happens to me all the time. what i do is unplug oft and then plug it back in to flash.
shaynek is offline   Reply With Quote
The Following User Says Thank You to shaynek For This Useful Post:
xiayu0320 (12-13-2015)
error sokol Cars for Sale/Trade 9 12-09-2014 03:22 AM
ECUtek error 37 NickFRS Software Tuning 5 06-29-2014 04:14 PM
Unichip Error Code Ingeberger Engine, Exhaust, Transmission 5 12-29-2013 01:09 PM
Paperwork error Rob_g Scion FR-S / Toyota 86 GT86 General Forum 4 05-24-2012 11:38 PM
Driver error Midship Runabout Off-Topic Lounge [WARNING: NO POLITICS] 5 07-14-2010 07:25 PM
