Old 12-12-2015, 08:21 PM   #1
xiayu0320
Drives: 2013 GBS BRZ
OFT error, help needed
I got an error shows an error occured while writing to the ECU Please try again. I think it may cause dislodging of the OBD2 cable. My car cannot start right now and there is no (*) on my current file. I think the ECU file may broken so OFT cannot identify the current file in ECU. Does anyone know how to solve this problem? Thanks!
xiayu0320 is offline   Reply With Quote
Old 12-12-2015, 09:26 PM   #2
steve99
check the obd connection, some cars have intermittent obd connections.
try putting some forwards or backwards pressure on obd connector on car bay use rubber band to get a connection, then look at fixing obd socket.
make sure cable is plugged in propertly at oft end as well.
make sure car battery is charged and the your turning ingnition full on (do not start) when flashing not just accessory position
Old 12-12-2015, 10:06 PM   #3
xiayu0320
Thanks man! I'll check them tomorrow. But I think there is no problem with obd connector because all other functions are worked. Do you think there have some other problems cause the OFT cannot flash the ECU?
Old 12-12-2015, 10:38 PM   #4
steve99
First thing that happens with reflash is original rom in car erased then new one flashed. if process interrupted then you end up with no usable rom in ecu and car wont start.
Try reflashing your stock rom back to car.
oft will be interactive if it get power from car via obd port but logging and flashing will not work if rom is incomplete or no data communication with ecu due mayne the data pins not making good contact in obd connector but power pins ok
Old 12-12-2015, 10:41 PM   #5
steve99
did you make any changes to the tuned rom with romraider ??
Old 12-12-2015, 10:51 PM   #6
xiayu0320
Yes, I just did launch control before. I changed UEL header today, and then I try to flashing oft stg2 uel 93oct file into the ECU. OFT shows I complete flashing but I can't start my car. After that I try to reflashing to the stock file, then OFT shows error.
Old 12-12-2015, 10:54 PM   #7
xiayu0320
Do I need to use other device to reflashing stock rom or I can just use my OFT to reflashing?
Old 12-13-2015, 12:15 AM   #8
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
You use OFT, it should've read the stock one at the beginning
Old 12-13-2015, 12:26 AM   #9
xiayu0320
Thanks, I'll try it tomorrow. I just want to make sure OFT can flashing the ECU if file in ECU that incomplete.
Old 12-13-2015, 12:41 AM   #10
steve99
hmm does not sound good have a read of the romraider tips link below.
http://www.ft86club.com/forums/showthread.php?t=79152
when you changed lc\ffs parameters were the boxes on romraider black with no data or green ?????
post up the definition and your rom file
Old 12-13-2015, 12:54 AM   #11
steve99
If you have used incorrect def file to edit it likely written a corrupt rom to ecu.
Use the oft to write bact the Original File to the ecu the one in the top slot.
if it still wont write try this
Switch off ignition
Remove positive battery terminal
With battery disconnected, depress brake pedal to bleed off and redidual power
Replace battery terminal
Flash your original tune to car on first turn on of ignition
Ie plug in oft turn ignition on go to write , wtite original tune without turning ignition off even if oft asks you to.
After that i think you got big problem, contact the oft guys.
Old 12-13-2015, 12:55 AM   #12
xiayu0320
File in my computer, I'll post later. I think is green and lc works fine before. I just try to flashed original stg2 uel 93oct file that I download from openflash website, I didn't edit anything in that stg2 file.
Old 12-13-2015, 12:59 AM   #13
xiayu0320
Switch off ignition
Thank you so much, I'll try it tomorrow. Wish I don't get a big problem.
Old 12-13-2015, 01:09 AM   #14
FRSBRZGT86FAN
If you need help just pm me or @steve99
error sokol Cars for Sale/Trade 9 12-09-2014 03:22 AM
ECUtek error 37 NickFRS Software Tuning 5 06-29-2014 04:14 PM
Unichip Error Code Ingeberger Engine, Exhaust, Transmission 5 12-29-2013 01:09 PM
Paperwork error Rob_g Scion FR-S / Toyota 86 GT86 General Forum 4 05-24-2012 11:38 PM
Driver error Midship Runabout Off-Topic Lounge [WARNING: NO POLITICS] 5 07-14-2010 07:25 PM
