Old 12-09-2015, 02:07 PM   #1
mcbrawr
Drives: 2014 BRZ Limited
Final Drive: 4.56 vs. 4.88
I've ordered all the extras needed to make the swap (seals, bearings) but have yet to order a ring and pinion due to not knowing which would fit my needs better.
I use the car as my DD, work commute is around 5 miles to/from. The closest freeway is the DC beltway an hour and a half north of me. My goals are to have a noticeable increase in acceleration without sacrificing the driving experience. We usually take my wifes car on longer trips during holidays but I do enjoy the 5+ hour drive to WV occasionally.
What are the top speed limitations to each?
Does 4.88 make it basically torture to drive 80mph for hours on end?
Which would be the better choice?
'14 BRZ Limited | SBD500X + HRI Tuning | Tanabe Concept G Exhaust | XXR 527 18x8.75 | Hankook Ventus V12 EVO2 245/40/18
mcbrawr is offline   Reply With Quote
Old 12-09-2015, 02:18 PM   #2
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
What transmission do you have?
Freeman is offline   Reply With Quote
Old 12-09-2015, 02:33 PM   #3
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
You can calculate top speeds per gear here: http://www.apexgarage.com/tech/gear_ratios.shtml
Old 12-09-2015, 02:35 PM   #4
mcbrawr
manual transmission.
Old 12-09-2015, 03:57 PM   #5
swarb
4.10 to 4.56 is pretty much 11%
So if you are at 3k rpm at a given speed, 4.56 would be about 3,300rpm. Maybe that will help you imagine what rpm you would be at with a higher final drive.
4.88 is is about 18% Let me know if you find out the rpms at 80mph for all the different final drives. I am too lazy to check right now.
Old 12-09-2015, 04:27 PM   #6
Foulsmell
Foulsmell's Avatar
Drives: Gt86
I went for 4.67 Mfactory on my DD M/T. It's perfect. Easier to drive than before due to the extra torque and comfortable cruising at higher speeds.
Foulsmell is offline   Reply With Quote
The Following User Says Thank You to Foulsmell For This Useful Post:
jcw99 (04-21-2019)
Old 12-09-2015, 04:43 PM   #7
mcbrawr
I don't think Weir sells a 4.67, or I would be very tempted to take that route myself!
Old 12-09-2015, 04:44 PM   #8
Foulsmell
Foulsmell's Avatar
Drives: Gt86
No it's an Mfactory one. I'm in the uk.
Old 12-09-2015, 04:46 PM   #9
Foulsmell
Foulsmell's Avatar
Drives: Gt86
It also depends on other mods. You won't need the 4.88 if you've got header exhaust etc for a DD I would say.
Old 12-09-2015, 04:52 PM   #10
mrk1
Drives: Sterling BRZ Ltd
4.56 is very streetable and daily driveable, 4.88 is a bit more aggressive and maybe a little rough on a +5hr drive.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
kodyo (12-27-2015)
Old 12-09-2015, 05:54 PM   #11
Sargy
Long Distance Driver
Sargy's Avatar
Your at around 113 MPH when topping 5th gear.
crusing speeds in 6th gear at 70-75mph is around 4K rpm.
I drove to Toronto from Northern VA without any complaints. My Girlfriend was happily asleep. it all depends on the drivers needs and how loud the exhaust can be because the RPM will be higher most of the time.
Sargy is offline   Reply With Quote
Old 12-09-2015, 09:55 PM   #12
stevesnj
stevesnj's Avatar
Use this handy little calculator to get a more precise idea of the final ratio at the wheels with tire size.
https://tiresize.com/gear-ratio-calculator/
My 2016 Build thread
Old 12-10-2015, 09:00 AM   #13
M1K3
M1K3's Avatar
Drives: vrooom...
MFactory has a really good gear ratio calculator with a line graph for each gear:
http://calc.teammfactory.com/index.php
Here is a 4.56 vs 4.88 with 245/40/17 tires and stock 86 gears:
4.56vs4.88
M1K3 is offline   Reply With Quote
The Following 3 Users Say Thank You to M1K3 For This Useful Post:
Anthony (12-14-2015), mcbrawr (12-10-2015), stevesnj (12-10-2015)
Old 12-10-2015, 10:11 AM   #14
mcbrawr
I guess my next question would be this:
Looking at the MFactory gearing calculator, I will have to be in 5th gear to hit 100mph. With 4.88 gears how will 5th feel? Like 4th currently?
4.8 final drive drift86 Engine, Exhaust, Transmission 29 11-28-2022 01:49 PM
WTB: 4.56 Final Drive jaorocks1 Want-To-Buy Requests 0 11-04-2015 08:36 PM
3.7 Final Drive GsxrMe Engine, Exhaust, Transmission 9 09-28-2015 08:55 AM
Final Drive 4.67 Bongertz Engine, Exhaust, Transmission 33 09-02-2015 04:11 PM
3.3 Final drive? Manji Engine, Exhaust, Transmission 18 01-01-2015 03:51 PM
