Old 12-08-2015, 12:22 PM   #15
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by solidONE View Post
There are guys claiming they're getting even tire wear in the front with more than -3* camber. Not sure how they are doing this, or if they're measuring the center tread depth.
I know I will get even wear when I run -2.5 or w/e I end up running next spring as on stock alignments I replace my tires every 20k due to wear hahaha!
LenA (12-08-2015)
Old 12-08-2015, 12:44 PM   #16
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
You could have flipped the tires after a couple of events or some mileage to try to maximize your tire life. Though, unless you granny your car everywhere, stock alignment (-0~-0.5* front camber) is not very easy on the outside edge of the front tires. -2.0~2.5 front is good compromise, I think.
Intent > Content
The Following 2 Users Say Thank You to solidONE For This Useful Post:
LenA (12-08-2015), wparsons (03-21-2017)
Old 12-08-2015, 12:47 PM   #17
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Yeah I drive the piss outa my car and most tires are 260 or less treadwear haha! It is my own doing but to me its more about the smiles then the $$$
I plan on running -2.5 front and -1.5 rear when I install my coils and LCA's this spring with 0 toe all around. You think thats a good starting point?
LenA (12-08-2015)
Old 12-08-2015, 12:52 PM   #18
solidONE
solidONE's Avatar
Yes. I'd maybe run a tiny more more camber in the rear, specially with 0 toe, but that's my preference. Rotate the wheels often and I'd think you'd get some pretty good mileage out of the tires.
Intent > Content
go_a_way1 (12-08-2015), LenA (12-08-2015)
Old 12-08-2015, 12:53 PM   #19
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by jsimon7777 View Post
How is the ride on the b14?
I only have a few dozen miles on them, initially it seems to soak up the little road imperfections better than OEM but it seems to bounce on big displacements like speed bumps. I'll be autocrossing it next weekend and able to put some real miles on it over the next three weeks which is why I haven't posted anything about it. Seems like a great quality bang for your buck lowering (I winged the collar heights and I ended up 1" lower than stock, might be able to get some height), comfort is very similar to OEM and the stiffer springs are apparent but not harsh even with the light driving I've done.
I think that drive cycle is extremely important, I drove a few hundred miles on the freeway with -3 degrees and feel like it took a noticeable amount off the inner shoulder, but they wear evenly on track at that alignment. I've been adjusting camber before and after events, seems to have almost no effect on toe. Someone who's car sees 90% hard driving will wear pretty well with -3 degrees, 90% DD will roast those tires compared to a more conservative alignment.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
EAGLE5 (12-08-2015), LenA (12-08-2015), wparsons (12-08-2015)
Old 12-08-2015, 01:54 PM   #20
wparsons
wparsons's Avatar
Originally Posted by churchx View Post
djdnz: it's worth checking/doing alignment at least once even on completely stock car anyway. Simply because factory (and thus many dealership's) allowances are too broad, and alignment of completely new stock car can have alignment out of whack vs what is expected from performance car and still be within "factory" specs. You may be in luck and have it little out of shape .. but you can be aswell not as lucky.
Originally Posted by djdnz View Post
Why do you want an alignment? The factory specs are pretty good - if you get aftermarket suspension and need an alignment then get one then
See above... the factory ranges are pretty huge, just getting the car to the middle of the range is a good start, for anyone regardless of how they're using the car.
To the OP, the biggest change you'll notice is that with less rear toe the car will be slightly less stable in a straight line. It's not going to want to spin, but it will follow contours of the road a bit more. Not scary, just something to be aware of.
flickr
The Following 3 Users Say Thank You to wparsons For This Useful Post:
8R6 (12-08-2015), LenA (12-08-2015), strat61caster (12-08-2015)
Old 12-08-2015, 06:54 PM   #21
2much
I wanna go fast
Drives: 2013 FR-S 6MT
Originally Posted by 8R6 View Post
if youre that close to WestEnd, then it doesnt hurt to just stop by and talk to darrin or chris. theyre both smart as hell and super nice. let them know what your plans are, and even if you dont know, they can help provide advice and direction for you to know and then decide what your plans would be.
to start off, you can get the camber bolts for the front and have westend align it for you to best suit your driving style/needs. you wont get a lot of adjustability with just that, but they can definitely still tidy the alignment up and recommend settings that will meet your needs.
there are a ton of places that have fanbois and hype, but westend is one of the VERY FEW places that honestly lives up to the hype and even beyond. and they dont rip you off.
+1 west end. if you go for a chat, they will earn your business
2much is offline   Reply With Quote
The Following User Says Thank You to 2much For This Useful Post:
LenA (12-08-2015)
Old 12-08-2015, 11:21 PM   #22
LenA
Drives: 2015 Silver BRZ
Thanks for the feedback. I'll see what West End recommends. I'm an engineer, so even if I don't go with camber bolts etc, I'd like to get a baseline and see where things are relative to the broad factory ranges and go from there. Most of my driving is DD, so I really only want to do mods that improve DD with some occasional HPDE in near future
Len
LenA is offline   Reply With Quote
Old 12-09-2015, 12:37 AM   #23
solidONE
solidONE's Avatar
We were talking about DD setups that sees the track. I suppose the amount of track miles vary, but I'd think most "DD" as in Daily drivers would see many highway miles.
Intent > Content
Old 12-09-2015, 01:00 AM   #24
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I'd just zero the toe and get crash bolts for the front. Excellent compromise. Cheap too. Don't overthink it. Also, a local speedshop may or may not know the platform well. Roger Krause Racing near my home does tons of racing and suspension work. They literally said to go online and find out what works then come to them to get it done.
Old 12-09-2015, 01:53 AM   #25
swarb
@LenA good deal. Ideally for this car, you want more camber in the front than the rear. About .5 or so. Good luck.
The Following User Says Thank You to swarb For This Useful Post:
wparsons (12-09-2015)
Old 03-21-2017, 03:12 AM   #26
Jonathan Le
Drives: Scion FR-S
Hey guys just recently got an alignment and was curious about something.
my front camber left is 1.5 and the right is 1.8 does should i be concern about .3 difference?
Jonathan Le is offline   Reply With Quote
Old 03-21-2017, 09:40 AM   #27
ZDan
ZDan's Avatar
Drives: '23 BRZ
I wouldn't worry about it, you'd never notice.
Old 03-21-2017, 10:48 AM   #28
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Originally Posted by LenA View Post
I have read a lot of posts on alignment and mods. I am curious what the real world impacts are for a daily driver. My 2015 BRZ has stock wheels/tires and suspension. I am thinking of Whiteline camber bolts and getting alignment with negative front camber, 0 toe front and slight rear toein. Will this alignment be noticable on street, or will it really only help when pushing car really hard? Will it be worse on highway?
I'm close to West End alignment, so would probably go to them for thrle alignment
Thanks
Len
I haven't tried those settings, but that's close to what I set my last car to. The car will seek out the camber of the road and want to wander on the highway. There will be more tire wear up front. But the car will feel so much better in every corner.
guybo is offline   Reply With Quote
How does AC impact power? scionfrs2014 Scion FR-S / Toyota 86 GT86 General Forum 48 05-13-2019 05:58 PM
Recommendation for Cordless Impact Wrench? iLaw Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 04-27-2017 10:51 PM
Way too loud. Best fix for minimal impact? transition Engine, Exhaust, Transmission 55 07-24-2014 11:02 AM
Air temps and impact on engine load brn12345 Software Tuning 0 04-30-2014 02:50 PM
shop in west Houston for performance wheel alignment hankster Southwest 0 08-21-2012 06:08 PM
