Drives: 2015 Silver BRZ
Performance Alignment impact on DD
I have read a lot of posts on alignment and mods. I am curious what the real world impacts are for a daily driver. My 2015 BRZ has stock wheels/tires and suspension. I am thinking of Whiteline camber bolts and getting alignment with negative front camber, 0 toe front and slight rear toein. Will this alignment be noticable on street, or will it really only help when pushing car really hard? Will it be worse on highway?
I'm close to West End alignment, so would probably go to them for thrle alignment Thanks Len |
#2 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
#3 |
That Guy
Drives: 2013 asphalt FRS MT
The amount of camber you can get with just camber bolts wont be anywhere near enough to cause increased tire wear. Having the toe set to zero might cause a slight increase in tire wear if there's sufficient deflection in the bushings. But I doubt it as the factory spec calls for sufficient toe in to cause it's own tire wear.
I'm presently running -2.5 degrees of camber front, -1.5 degrees of camber rear, 0 toe all around, and a little more caster from some whiteline control arm bushings. The car still tracks really well, and is beautifully predictable at all speeds. |
#4 |
toe is what really messes up your tire wear. you should be fine as long as you're not running some crazy negative camber like -5.
#5 |
Dismember
Drives: 2013 Red Scion FR-S
Like ryoma said, toe matters more, but a lot depends on driving habits, surfaces, and tire inflation. Generally, I find that my tires wear on the inside and outside edges much faster than they wear in the middle. My 550i wore the inside rears out faster than anything, but it had a bit of extra toe before I realigned it.
#6 |
You won't get that much camber from the camber bolts, maybe -1.3ish. You'll be fine with those settings, the front will feel more nimble and the car will be more responsive overall. Talk to (Darren?) at West End about how you drive and he will give you good advice on your specs for the alignment. I would go with whatever they suggest.
#7 |
1337
Drives: 2013 BRZ WRB S/C
Why do you want an alignment? The factory specs are pretty good - if you get aftermarket suspension and need an alignment then get one then
#8 | |
Drives: '13 FRS - STX
![]() Factory toe is pretty decent from what I've seen (and rear camber is acceptable but uneven on many cars), but factory front camber is non-existent, tons of grip is hidden away and the car understeers because of it. I started out the year with the exact same setup as OP and it was definitely an improvement on track and autox without any sacrifice to DD. IMO, camber plates and a good alignment made the car drive better than good tires (Z2 SS) and budget coilovers (B14) has so far, can't wait to get my rear LCA's on in a few weeks. ![]() The average owner doesn't need any of this, no argument. |
#9 |
Drives: 2014 GT86
djdnz: it's worth checking/doing alignment at least once even on completely stock car anyway. Simply because factory (and thus many dealership's) allowances are too broad, and alignment of completely new stock car can have alignment out of whack vs what is expected from performance car and still be within "factory" specs. You may be in luck and have it little out of shape .. but you can be aswell not as lucky.
#10 | |
If you track often, you will probably want a more aggressive setup/alignment. I'm still noticing a lot of outer edge tire wear so I probably could use another degree of camber in the front and half degree of camber in the rear.
2022 BRZ Build 2013 FR-S Build |
#11 | |
Dismember
#12 |
Drives: BRZ & Forester
Hi LenA,
I do not know if you have seen this, but this page/thread was very helpful to me when deciding about BRZ Alignment: http://www.ft86club.com/forums/showthread.php?t=25001 Although I am not sure that I fit into “real world impacts for a daily driver”...I have had a baseline alignment (without adjustments) done to get OEM alignment numbers, a quick adjustment alignment to pull my numbers (as close spec) after coilovers install, and will have a full/complete alignment, in a few weeks, after the suspension settles, and I have my LCAs installed. I personally believe alignment is very important. hth, cwpbrz-ji |
#13 |
Drives: FRS
if youre that close to WestEnd, then it doesnt hurt to just stop by and talk to darrin or chris. theyre both smart as hell and super nice. let them know what your plans are, and even if you dont know, they can help provide advice and direction for you to know and then decide what your plans would be.
to start off, you can get the camber bolts for the front and have westend align it for you to best suit your driving style/needs. you wont get a lot of adjustability with just that, but they can definitely still tidy the alignment up and recommend settings that will meet your needs. there are a ton of places that have fanbois and hype, but westend is one of the VERY FEW places that honestly lives up to the hype and even beyond. and they dont rip you off.
#14 |
Drives: FR-S Whiteout
There are guys claiming they're getting even tire wear in the front with more than -3* camber. Not sure how they are doing this, or if they're measuring the center tread depth.
Intent > Content
cowardice is the mother of cruelty. |
| How does AC impact power? | scionfrs2014 | Scion FR-S / Toyota 86 GT86 General Forum | 48 | 05-13-2019 05:58 PM |
| Recommendation for Cordless Impact Wrench? | iLaw | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 35 | 04-27-2017 10:51 PM |
| Way too loud. Best fix for minimal impact? | transition | Engine, Exhaust, Transmission | 55 | 07-24-2014 11:02 AM |
| Air temps and impact on engine load | brn12345 | Software Tuning | 0 | 04-30-2014 02:50 PM |
| shop in west Houston for performance wheel alignment | hankster | Southwest | 0 | 08-21-2012 06:08 PM |
