Old 12-07-2015, 02:48 AM   #463
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Originally Posted by Sojhinn View Post
I wait for the day you get e85 eagerly.
I only hope I can do for E85 what I've done for the 91 Octane tunes.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
Old 12-07-2015, 05:12 AM   #464
BRZ-y
Drives: Brz limited
Thanks @Sojhinn @DAEMANO @KoolBRZ
I'm in a manual
Cal ID ZA1JA700C
I'll put it all back in the car on Tuesday night.
BRZ-y is offline   Reply With Quote
Old 12-07-2015, 01:51 PM   #465
stevo585
Drives: White 2014 BRZ
So pretty much no one uses Ecutek with this kit? If I ever get a kit I will be tuned by my local James @ HRI tuning. Maybe I'll be the first to squeeze out a few extra horses vs. the OFT. I know NA runs better as I use to have an OFT.
stevo585 is offline   Reply With Quote
Old 12-07-2015, 02:10 PM   #466
DAEMANO
Time Traveller
No real point to going ECUTek other than to add a Flex fuel kit for e85. Still, I run e85 from concentrations of e50 to e90 on Shiv's OFT tune safely while making great power. The Phantom ESC runs about 5lbs of boost. At these low pressures OFT tuning with the MAF is just as effective as Speed Density tuning with ECUTek (another advantage of the near parasitic-free boost offered by Electric Supercharging, turbo/supercharging needs another couple of psi to make similar top end numbers). Squeezing out an extra couple of WHP may not be worth the extra $700 - $1k for an ECUTek setup and custom tune.
Old 12-07-2015, 02:44 PM   #467
stevo585
Well maybe true but I have Ecutek already and I got a great deal on it. I say again the Ecutek is noticeably better than the OFT especially on e85 where you can go to MBT exactly. My fuel trims are also less than 1%. You can't argue a custom tune isn't better. The OFT is good I used it for over a year. Using fuel trim corrections for e% at WOT isn't the best either. Safe...probably.
Old 12-07-2015, 04:00 PM   #468
DAEMANO
Time Traveller
Erm... Easy does it cowboy. No one is arguing that a custom tune isn't generally "better" than an OTS tune. My post is about how much a couple of extra WHP might cost. Great that you alrady have your ECUTek hardware. If you feel like paying for a custom tune, there's nothing wrong with that so more power to ya. To see how much more power a custom ECUTek tune will net all you gotta do is find Bob@DriftOffice's post about his ECUTek tuning session with the Phantom kit and compare it to Shiv's OTS OFT result for the same hardware. The difference is negligible and within margin of error.
Old 12-09-2015, 12:57 AM   #469
stevo585
No doubt. My custom tune was less than the oft so no brainer there...no extra cost. I'll have to check that out didn't know that anyone even was tuned with Ecutek that's why I originally asked. Thanks.
Old 12-09-2015, 12:58 AM   #470
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Yeah my buddy @nlowell did
Installed Mods:
Old 12-09-2015, 01:21 AM   #471
TM
TM's Avatar
Drives: DGM BRZ 6MT
Take a look at the owners config on the first or second post. There is (or was) at least 4 ecutek owners on the spreadsheet.
TM is offline   Reply With Quote
The Following User Says Thank You to TM For This Useful Post:
stevo585 (12-09-2015)
Old 12-09-2015, 02:20 AM   #472
KoolBRZ
KoolBRZ's Avatar
I'm not debating the possibility of getting more from an Ecutek tune. I have no doubt that's possible. You can't share an Ecutek tune though. It isn't Open Source, so you could be sued for sharing it. It is Intellectual Property, and really the possession of the tuner. OFT uses Open Source software to tune, so I can share without violating IP laws. OFT users are finding out more every day how to use unknown memory addresses to change more and more parameters on the FT86 ECU. I wish someone could crack the transmission controller as well. I'm learning how to tune with my OFT, and it's really a love/hate relationship. If it runs bad, it's nobody's fault but mine. But when it runs good...
Old 12-09-2015, 09:47 PM   #473
stevo585
Is that how it works the tune is IP. Isn't just the software license? Well anyways my tuner doesn't lock his tunes and I have access to it. But I leave that to the professionals not sure I even want to mess with it...your a braver man than me lol.
Old 12-10-2015, 08:05 AM   #474
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
In the grand scheme of things (since licensing and IP are being a bit misconstrued here), you are only licensing ECUtek's software to modify the tune and run the locked tune on your car. Think of ECUtek as Window's for your computer. You pay for a license and you have the rights to use the software.
The tuner's tune is like a program written to handle your car's specific hardware, like an application that you might contract a programmer to write to have your computer blink so lights and play music. This software's owner is a little trickier and depends on how the contract is setup with your tuner. Some tuners will sell you locked access to your tune; this would operate like the software license listed above. The more acceptable to handle this (from a software developer aspect) is that you are contracting the tuner to write your tune for you, and you are paying for the full IP. This isn't how all tuners handle it, and in fact, different courts in different jurisdictions would possibly rule differently should the sale of the tune not explicitly list who owns it (or possibly overturn who the real owner is).
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
stevo585 (12-11-2015)
Old 12-12-2015, 04:56 PM   #475
Lord09
Drives: 2015 BRZ
Apologies if this isn't the correct place for these questions, but I've seen some 1.5 kits on the for sale forums here lately and since new kits seem like they have a 2 year waiting list, I was hoping to get some input on the following questions:
1. Anyone mind going over the differences between the 1.5 and 2.0 kits?
2. Any reason to avoid the 1.5 kits?
3. Partial boost seems like a huge upgrade, is the Procede controller compatible?
I've done my best to search, but I haven't found any concrete info.
So if anyone could provide any input I'd appreciate it.
Lord09 is offline   Reply With Quote
Old 12-12-2015, 06:24 PM   #476
TM
TM's Avatar
Drives: DGM BRZ 6MT
Phantom FTS Electric Supercharger Owners Thread
1. The biggest differences are a lighter compressor wheel, better cooling on the controller, re-program spool up, new activation harness (2-step boost), voltmeter, and some other stuff.
2. No reason to avoid them. They still run great and the power difference is minimal to non-existent. You can also choose to send it back to rob to upgrade the internals to the v2.0/3.0 kits. But I wouldn't unless something needs to be repaired.
3. Yup, the procede is compatible with all current versions of the kit.
Lord09 (12-12-2015)
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 09:08 AM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 07:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 02:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 04:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 10:51 AM
