Old 12-02-2015, 06:38 PM   #981
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
After the next tune, there will be no flkc past 0.9. So why am I still dropping IAM?
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 12-02-2015, 10:13 PM   #982
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
If your battery completely dies, do you need to reflash the maps? Or just let it idle for a few mins to readjust before driving?
My car was running on E85 and has been sitting for a while.
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 12-02-2015, 10:24 PM   #983
phrosty
Unless your battery dies in the middle of flashing, it won't affect your tune.
phrosty is offline   Reply With Quote
Old 12-06-2015, 12:06 AM   #984
cookiesowns
Drives: WRB BRZ Series.Blue
FLKC is not directly timing correction. FLKC is fine learning KC. When the ECU detects knock enough to pull timing, it will drop the IAM, and as a result you will see FLKC be a negative number.
This means the ECU is pulling timing. The ECU will keep the timing pulled until a certain amount of time, then start slowing adding timing again in the troublesome areas, until it starts knocking again, or until it adds max timing.
Note that IAM won't immediately go back to 1, as it'll need to continue adding timing in troublesome areas until you reach max timing again.
You need to log at minimum IAM, and KC values. FLKC is useful when you are toying with rpm & load to try and trick the ECU to knock, or add back timing.
cookiesowns is offline   Reply With Quote
The Following User Says Thank You to cookiesowns For This Useful Post:
riboyster (12-06-2015)
Old 12-06-2015, 08:08 AM   #985
steve99
Drives: FT86
The ecu uses some calculation to look at fbkc and flkc to determine when it will drop iam or increase iam. It apoears to look at the magnitude of the knock and the frequency and duration of the events. You can get the odd spike of say -2 flkc and not drop iam but if you get repeated events of even -0.6 in quick sucession it may drop iam.
It then looks for knock free or minimal knock passes through the rpm load areas where its seen knock events previpously to determine if it will increase iam.
you can often get your iam back to 1 by doing a number of light steady throttle say 15% throttle runs in second or third from 2000 to 5500 or so. At light loadsecu wont see knock and will increment iam back towards one
Old 12-06-2015, 03:24 PM   #986
riboyster
riboyster's Avatar
Awesome, thanks for both responses. Exactly what I needed to know.
Old 12-07-2015, 01:31 PM   #987
sirsol66
Drives: 2013 FRS- Hot Lava
Some help necessary here. Setup:
Open Flash OFT300 package
Vortech supercharger (standard pulley)
Open Flash Header
Stock catback
Vortech Maxflow BOV
Logs: http://datazap.me/u/sirsol66hotmailc...data=1-2-10-11
Car is showing very very high fuel trims (25+) at idle and low RPM areas. Car is running completely fine but the trims are not settling. No knock at WOT pulls.
Exhaust has been leak checked and no issues. I will leak check the intake side this week.
One thing I noted is that the BOV is completely open at idle and moving A LOT of air. I never ran the normal vortech bypass valve so I am not sure how the maxflow compares with it. Can this be contributing to the high fuel trims?
sirsol66 is offline   Reply With Quote
Old 12-07-2015, 06:37 PM   #988
steve99
Drives: FT86
Open Flash Header
Stock catback
Vortech Maxflow BOV
Bov continuously open at idle does not sound correct, should only be venting overpressure like when you back off throttle after reving engine. I wold ring the oft guys
If its venting all
Old 12-07-2015, 07:09 PM   #989
sirsol66
If its venting all
Steve I had the same experience coming from Evo's but based on everything I've read about the vortech kit, this is normal. The sc makes positive pressure at idle so the bov stays open to vent it, similar to the bypass valve on an innovate.
I did notice that the car is only registering 9 inches of vacuum at idle...and that doesn't sound right. Anyone with the vortech kit that can chime in how much is normal vacuum at idle?
Old 12-08-2015, 05:25 PM   #990
Subie_Nubie
Subie_Nubie's Avatar
Drives: 2013 Subaru BRZ Limted
Just recently got on this OFT gravy train. Installed stage 1 93 tune and I already understand the hype. Car feels a lot smoother from 1.5k - 4.5k and then whooosh. I can definitely tell the difference, and no stutter from the gas pedal in low speed 1st or 2nd. Thanks @Shiv@Openflash
Subie_Nubie is offline   Reply With Quote
The Following User Says Thank You to Subie_Nubie For This Useful Post:
B-R-Z (12-09-2015)
Old 12-11-2015, 11:44 PM   #991
riboyster
riboyster's Avatar
Finally nailed the 89 octane ethanol free tune. Thanks for the help guys. Peak hp is the same, didn't have to pull timing up there.
If anyone wants improved throttle response, better low end torque, and gasoline that doesn't decompose oil and fuel lines, let me know.
Also the noisy cricket is gone.
Old 12-12-2015, 11:21 AM   #992
crackcaffeine
crackcaffeine's Avatar
Drives: Subaru BRZ 2015 Sport Tech
OpenFlash Manager link is down again....... 404 error
Also OTS v2.0 Beta downloads fine but when unzipping it shows "OTS v2.0 Beta USDM only.zip: The archive is either in unknown format or damaged"
Does anyone have a mirror?
crackcaffeine is offline   Reply With Quote
Old 12-12-2015, 12:10 PM   #993
steve99
Drives: FT86
looks like you getting old page data ,clear you browser cache it will probably be ok
current tunes are 2.07
or try here
http://openflashtablet.com/Automotiv...S%20v2.070.zip
http://openflashtablet.com/Automotiv...ads/index.html
Old 12-12-2015, 03:11 PM   #994
crackcaffeine
or try here
Oh awesome thanks a lot. I was using the link in the OP
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 01:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 11:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 05:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
