Old 12-01-2013, 09:13 PM   #1
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
DIY Trailer Wiring
Hey guys, this isn't going to be a super detailed DIY but I have been getting a lot of questions about wiring trailer lights. Hopefully this will help clear up a lot of those questions and give people a good start to wiring trailer lights.
To wire trailer lights on an FRS/BRZ you will need to purchase a powered converter like this one: https://www.etrailer.com/Custom-Fit-...urt/56146.html
A basic overview of the wiring that needs to be done:
The converter uses an external source for power and does not put an extra draw on the tail lights. The power to this converter can be taken from almost any fused power source that is on with the ignition. I decided to use the glove compartment cigarette plug since its easy and I don't use it for anything else. So in that case you will need a universal outlet plug.
Wiring of left tail in progress:
Completed wiring on left tail:
Wiring on right tail:
Mounting location of Curt adapter near left tail:
Semi-completed wiring on left tail showing a better view of the mounting location of the Curt adapter (right)
Power adapter installed in glove box:
I know this DIY is pretty vague so feel free to ask any questions you have.
kask2_6.0 is offline   Reply With Quote
Old 12-01-2013, 09:23 PM   #2
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
Bought this same kit from jegs.com. Payed U haul half hour labor (35$) and they did a fantastic job. Your smarter than me figuring it out.
* they connected my power straight to the battery
Ryaquinn is offline   Reply With Quote
Old 12-04-2013, 06:37 PM   #3
leon78
leon78's Avatar
Drives: 13 Whiteout
Subbed.
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 12-07-2013, 09:18 PM   #4
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
nice...
Bill
Scooby South is offline   Reply With Quote
Old 02-10-2014, 04:17 PM   #5
BadPanda
Drives: 2013 Limited BRZ
Curt Adapter
Found this today while looking for wiring for my newly installed Kask Hitch: http://www.etrailer.com/Custom-Fit-V...leid=201322578
Ordering.
Bad Panda Motorsports
SCCA STX Build Thread
Driver Blog
Racecomp Engineering - Kartboy
Fast -n- Fluffy
BadPanda is offline   Reply With Quote
Old 02-10-2014, 04:37 PM   #6
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Hell yea! That's new. Would have made my life a little easier if they had this a year ago lol
Old 02-10-2014, 08:35 PM   #7
leon78
leon78's Avatar
Drives: 13 Whiteout
Ya...now that my wires are cut and sliced...they release a PnP kit.
Sent from my LG-LS970 using Tapatalk
Old 02-11-2014, 11:22 AM   #8
swift996
swift996's Avatar
FWIW - I used the same harness but just ran power from the tail light. I actually just spliced and wrapped with electrical tape. I haven't had any issues. There isn't a ton of slack in the OEM wiring, so just take your time.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 03-15-2014, 12:15 PM   #9
Nm86
Drives: Ultramarine
Where did you guys run the wiring to the exterior, on most vehicles with trailer hitches the wiring sticks out right by the hitch. I've got the plug and play everything just need to know where to pop it out?
Nm86 is offline   Reply With Quote
Old 03-15-2014, 06:51 PM   #10
leon78
leon78's Avatar
Drives: 13 Whiteout
Through a rubber plug under the spare. Then between the body and exhaust heat shield.
Old 12-05-2015, 01:14 PM   #11
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Bumping an old thread. Looking to build an autocross trailer for next year, so wiring is a concern of mine. My question:
I see that all of these kits use a "powered connector" so that the added draw from the trailer doesn't overstrain the existing wiring. However, I've converted my vehicle to 100% LEDs, and I intend to replace all the trailer bulbs with LEDs as well. I'm not an electrical engineer, but I'm wondering if I still need to bother with the powered adapter, since LEDs use a fraction of the power of a normal bulb. Even with the added length of wire, which I'm sure adds resistance, I'm wondering if it's necessary. I don't want to have to run wires if they aren't necessary - especially all the way to the front of the car.
Stang70Fastback is offline   Reply With Quote
Old 12-10-2015, 01:33 PM   #12
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Don't be lazy and risk an electrical fire. It took me all of 15 minutes to run the wire. Out interiors are cheap pop together plastic. There is literally one 10MM bolt in the rear seat, everything else comes out without using a single tool. You can't beat plug & play for $45. I didn't have to cut anything, plus I run them in front of my Diode Dynamics turn-as-tail mods, so there is no added load on the circuit.
https://www.etrailer.com/t1-2015_Subaru_BRZ.htm
Hyper4mance2k is offline   Reply With Quote
Old 12-10-2015, 03:31 PM   #13
Stang70Fastback
A.K.A. Starlord
It has nothing to do with being lazy, and everything to do with me being OCD and not wanting to run wires across the car for no reason. I'm just hoping someone might know for a fact whether it's the bulbs or the wiring that causes the added strain, because I'm fairly confident that a few extra LEDs on their own won't really do much to the load.
Trailer Hitch Jack Black Tracking / Autocross / HPDE / Drifting 31 12-22-2015 08:26 PM
Brz pulling trailer? subiesteve Southwest 7 11-20-2013 09:04 PM
Issues with trailer wiring qoncept Cosmetic Modification (Interior/Exterior/Lighting) 10 08-27-2013 10:42 AM
Iron Man 3 Trailer kanundrum Off-Topic Lounge [WARNING: NO POLITICS] 6 03-15-2013 10:17 AM
BRZ fan trailer by me-Please check it out baadshah BRZ Photos, Videos, Wallpapers, Gallery Forum 9 07-23-2012 11:30 PM
