Old 11-30-2015, 07:35 PM   #99
freerunner
freerunner's Avatar
Drives: GT86
I will try to plug my tactrix into someones car with stock header on petrol and see what the temps are
http://datazap.me/u/freerunner
Cat temp has been logged in the more recent entries. Stock header, stock front pipe.
freerunner is offline   Reply With Quote
The Following User Says Thank You to freerunner For This Useful Post:
steve99 (11-30-2015)
Old 12-01-2015, 02:04 AM   #100
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by freerunner View Post
http://dataset.me/u/freerunner
the link is no good...
Intent > Content
Old 12-01-2015, 05:48 AM   #101
freerunner
freerunner's Avatar
Drives: GT86
Typed it on my phone. Damn auto-correction.
s:set/zap/g
Old 12-01-2015, 07:59 AM   #102
thambu19
Drives: Scion FRS
You know, I'm really not sure why in the log the intake cam stays that much advanced 37.5~40* to 6000rpm. On the intake advance table it's set to 40* from 2400~4600rpm, and from 4800~6000rpm it's set to 35* advance. Very strange... I'll need to log the cam timing some more just to double check.
The exhaust cam retard table is actually not hugely different than the stage 1 OTS tables designed for use with factory headers. Although the OTS stage 2 tables actually run even more exhaust retard than the stage 1. I'll have to see if I can find the stock rom see what they look like.
Difference compared to OTS STG1:
Difference to OTS STG2 EL:
Thanks again for all the pointers, BTW.
Edit: Yup the intake cam is staying advanced further than designated by the cam tables.
4th gear pull just now:
http://datazap.me/u/solidone/af-lear...zoom=2699-3008
3rd gear pull in the same log where it drops down to 37.5* at 4800 rpm. Still not at 35* when it was set to on the table:
http://datazap.me/u/solidone/af-lear...zoom=1595-1732
There's got to be something else effecting the cam timing that we don't yet know about.
Cams usually have a lockpin or end stop and if the commanded positions are close they snap into those positions. I don't know what the end lock pin numbers are for FA20. I would assume they will be retarded intake and advanced exh though to be safe
thambu19 is offline   Reply With Quote
Old 12-01-2015, 10:07 AM   #103
solidONE
solidONE's Avatar
I suppose I can change the table to 35* degrees advance max and see if it will stick, or if it shifts up or down. From the logs, though, it seems to change at 2.5* increments. The exhaust cam seems to change smoothly through the range instead of increments of 2.5* from the looks of it.
Intent > Content
Old 12-01-2015, 10:08 AM   #104
solidONE
solidONE's Avatar
s:set/zap/g
eh... lol
Intent > Content
Old 12-01-2015, 11:54 PM   #105
arghx7
Drives: car
cross posting from the other thread:
The AVCS intake side has the negative values @thambu19 and others were talking about because it is a mid lockpin AVCS. That means the intake side can retard, not just advance. The retard is a fuel economy thing. It's the same type of AVCS that's on the FA20DIT. In fact, it's the BorgWarner phaser technology that Ford uses on the 5.0 Mustangs. On those FA20DIT engines when you delete the tumble generator valves you need to advance the AVCS or it runs like crap without all that tumble motion in the combustion chamber.
more details (mostly relevant to FA20DIT) here http://forums.nasioc.com/forums/show....php?t=2687550
The Following 3 Users Say Thank You to arghx7 For This Useful Post:
Kodename47 (12-02-2015), KoolBRZ (12-02-2015), solidONE (12-02-2015)
Old 12-02-2015, 03:11 AM   #106
solidONE
solidONE's Avatar
@arghx7 Y U so Awesome!? lol
So I went ahead and changed my cam tables to be at 35* advance max.
4th gear pull:
http://datazap.me/u/solidone/af-lear...zoom=7716-8003
3rd gear pull:
http://datazap.me/u/solidone/af-lear...zoom=5197-5341
It seems even with the intake cam advance targeted at 35* from 2200~6000rpm it will fluctuate between 35~37.5 degrees. Is this due to the "tumble generator" effect you are talking about? It seems to be advancing by 2.5 and not retarding here. And in the previous logs where I have the intake advance targeted at 40* 2200~4600rpm then 35* 4800~6000rpm it would be as much as 5* more advanced than the targeted 35* from 4800rpm.
4th gear pull:
Intent > Content
Old 12-02-2015, 03:32 AM   #107
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Are you changing both Safe, and Normal tables. They both have to be the same or you'll get inconsistent results.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
Old 12-02-2015, 03:34 AM   #108
Kodename47
Kodename47's Avatar
Drives: UK GT86
4th gear pull:
3rd gear pull:
4th gear pull:
We don't have the TGVs, they're also in the intake manifold and nothing to do with the cams.
I guess what you log will vary what you see, the cams will never be perfect and follow the map due to the way they operate. There will also be variances between the banks too due to this. On ECUtek I have 2 sets of logging parameters, one shows "From Rest" values which are close enough to the values in the table, the others are cam angle which are a little different.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-02-2015, 03:46 AM   #109
solidONE
solidONE's Avatar
Yes, I know this.
It seems to error on the + advance side and not the other way around. I guess I can set it 2.5~5* under the amount I want to target depending on what I'm trying to do.
Intent > Content
Old 12-02-2015, 04:19 AM   #110
Kodename47
Kodename47's Avatar
Drives: UK GT86
Just had a look at your log now I'm on a laptop, it seems that the logging parameter for the Intake AVCS is just to the nearest 2.5 degrees. That does not mean that it's actually operating like that.
As for the exhaust, it may well be a parameter that doesn't directly relate to the values in the table, and it could be that only one bank is suffering if that is an issue. I would't go changing tabular values to get the logs to read what you want as it may well be that the OFT is logging a different cam angle value.
Just so you can see some of the full AVCS parameters:
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-02-2015, 04:59 AM   #111
Kodename47
Kodename47's Avatar
Drives: UK GT86
Resurrected this old spreadsheet of mine:
AVCS Viewing/Comparison Tool
Paste in your own AVCS tables, it will show you overlap (based on suggested 0 positions of cams) and allows you to compare 2 different AVCS maps. It also has a tab to allow you to adjust axis scales if you desire and also one to convert normal/safe tables to a base table.
The charts are taken from the max load column as these all usually set the same for WOT load areas.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 8 Users Say Thank You to Kodename47 For This Useful Post:
aagun (12-10-2016), D-VO (12-06-2015), freerunner (12-02-2015), KoolBRZ (12-14-2015), makinen (12-02-2015), solidONE (12-02-2015), thambu19 (12-02-2015), Yobiwan (12-02-2015)
Old 12-05-2015, 02:41 PM   #112
piaoyi
piaoyi's Avatar
Drives: Sakura Miku
Does anyone know if this is an interference type engine and can make contact with the valves?
Niknej-jenkiN
piaoyi is offline   Reply With Quote
Timing chain issue? Hardpack Issues | Warranty | Recalls / TSB 14 01-11-2016 12:25 AM
AVCS failures? hmong337 Forced Induction 26 02-12-2015 04:01 PM
Stock Rom: Timing + Learn Value sw20kosh Software Tuning 7 12-11-2013 08:09 PM
E85, Boost and Ignition Timing jamesm Software Tuning 23 12-11-2013 03:19 PM
Timing belt shredded..?! drei CANADA 5 12-06-2013 06:54 PM
