Old 11-29-2015, 06:02 PM   #29
steve99
Drives: FT86
Originally Posted by diBreezy View Post
I don't think you're being a **** at all. I'll take whatever help I can get we are checking fuses with digital multimeter now.
There are only two fuseboxes right? Driver side and hood.
you should have power on pin 16 of obd
Old 11-29-2015, 06:07 PM   #30
diBreezy
diBreezy's Avatar
Drives: 2013 Raven FRS
Intermittent power to pin 16
Also, all the fuses are fine.
EDIT: And just for clarification. Battery is fine.
diBreezy is offline   Reply With Quote
Old 11-29-2015, 06:14 PM   #31
steve99
Drives: FT86
its probably the obd socket , you might have to try to remove pin 16 and crimp it a bit or get a replacement pin.
diBreezy (11-29-2015)
Old 11-29-2015, 06:17 PM   #32
steve99
Drives: FT86
or just put some forwards or backwards pressure on oft plug in obd port to maintain good connection maybe rubberband or tape ect just to get you reflashed then fix problem when you get home
The Following 2 Users Say Thank You to steve99 For This Useful Post:
DannyQ86 (11-29-2015), diBreezy (11-29-2015)
Old 11-29-2015, 06:19 PM   #33
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
If I remember correctly there were issues with 2013 FR-S having fragile pins on the obd II port at some point correct?
Old 11-29-2015, 06:23 PM   #34
diBreezy
diBreezy's Avatar
IT WORKED!
Flashed Stage 1. Had to hold it in there by hand the whole time. Car is currently running. Whooooo!!!
Thank you everyone for your input and consideration. Double, triple, quadruple thanks to /u/steve99.
The Following 11 Users Say Thank You to diBreezy For This Useful Post:
aegisdrgn (11-30-2015), Apoc (11-29-2015), Chrisgalactic (11-30-2015), DannyQ86 (11-29-2015), DustinS (11-30-2015), EastBayCanuck (12-01-2015), LOLS2K (11-29-2015), Thobjo (11-30-2015), TM (12-01-2015), Ultramaroon (11-29-2015), VMRamos (11-29-2015)
Old 11-29-2015, 06:25 PM   #35
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
This forum rocks...
LOLS2K is offline   Reply With Quote
The Following 2 Users Say Thank You to LOLS2K For This Useful Post:
Chrisgalactic (11-30-2015), Ultramaroon (11-29-2015)
Old 11-29-2015, 06:31 PM   #36
diBreezy
diBreezy's Avatar
Originally Posted by LOLS2K View Post
This forum rocks...
For real.
Old 11-29-2015, 08:23 PM   #37
churchx
churchx's Avatar
Drives: 2014 GT86
djBreezy: so you fixed it, congrats. But take note what caused issue (weak connector) and think something for future to workaround/fix it to not have that happen again. For example i probably would buy some adapter cable and connect OFT rather to it, then connecting many times to/from original weak connector. Even better if said adapter OBD cable would come with some power switch so that one can connect when needed OFT to it (for eg. logging @track), and easily switch off to not drain battery without replugging anything.
JB86'd (11-30-2015)
Old 11-29-2015, 08:27 PM   #38
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Good work team
Shiv@Openflash is offline   Reply With Quote
Old 11-29-2015, 11:04 PM   #39
kravi
Drives: Subaru BRZ
This forum rocks...
Yes indeed, I'm most impressed!
--kravi
kravi is offline   Reply With Quote
Pushed start.. didnt start im_topher Engine, Exhaust, Transmission 86 11-29-2015 09:57 AM
Where did you start with your FR-S/BRZ jeepmor Scion FR-S / Toyota 86 GT86 General Forum 43 04-10-2014 01:39 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
