Old 11-29-2015, 05:15 PM   #15
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by diBreezy View Post
The first one. Road trip>Attempt>Car doesn't crank
Does it make a click when you try to start it? Also you checked fuses incase it is something stupid like a starter fuse?
Old 11-29-2015, 05:15 PM   #16
steve99
Drives: FT86
Yes. Now it says Original.
EDIT: And the car won't start. Also, the OFT does not turn on when I turn the key to ACC
I think you battery has died, check battery
will headlights turn on ? are they full brightness
Old 11-29-2015, 05:18 PM   #17
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Check the pins on the cable going into the OBDII connector carefully. I've seen other posts where the pins got pushed in a bit and were not making contact.
BirdTRD is offline   Reply With Quote
Old 11-29-2015, 05:19 PM   #18
steve99
Drives: FT86
I'm in a full blown panic. I do not know why this happened. I tried resetting the battery. Nothing. The OFT says the Stage 1 tune is in my ECU.
I road tripped down to North Carolina. Now I can't leave!
I attempted to contact Open Flash via email. They have not yet responded.
Suspect battry in car has failed, dont flash cars with weak or dying batterys as it can fail mid flash. ecu needs stable volts to flash correctly
Old 11-29-2015, 05:20 PM   #19
diBreezy
diBreezy's Avatar
Drives: 2013 Raven FRS
Originally Posted by murdoc View Post
Where did you get this OFT and why did you first try using it so far from home?
Alright since there must not be an immediate and obvious answer I will give you more information.
I bought it 2nd hand from a fellow forum user. It was unmarried when he mailed it to me. I married it to the car. Flashed Stage 1 successfully. Enjoyed it. Flashed the e85 tune successfully. Enjoyed it. Flashed back and forth a few more times. Successfully. Finally, I flashed it back to stock and took it to the dealer for an oil change.
A few weeks later I pull up to the e85 pumps and attempt to flash to e85. Got an error message that said "An error occurred while communicating with the ECU. Please try again."
Tried a bunch of times. It didn't work. Emailed the guys at Open Flash. They responded, then my life got busy. Threw it in the glovebox and forgot about it.
I went on this road trip. Visiting a car buddy for the holiday weekend. Figured I would try it. I assumed worst case scenario was it would not work again. I assumed catastrophic failure would not happen. This may have been my mistake.
diBreezy is offline   Reply With Quote
Old 11-29-2015, 05:28 PM   #20
diBreezy
diBreezy's Avatar
It makes no noises. Checked fuses, they look fine Do you know which ones specifically?
Headlights seem fine.
Tried with a second OBDII cable. No problems. Went to Autozone a few weeks ago because of a CEL. Had no problems.
There isn't anything wrong with the battery.
Old 11-29-2015, 05:31 PM   #21
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
I don't I haven't look to much into the fuses. Im out of ideas, hopefully someone can think of something you haven't tried yet.
Old 11-29-2015, 05:35 PM   #22
churchx
churchx's Avatar
Drives: 2014 GT86
Experienced prior that Error occurred while communicating .. ?
Hmm, my bet is on bad contact/cable. Could it somehow fail in mid of flashing?
Old 11-29-2015, 05:35 PM   #23
steve99
Drives: FT86
Ok after this info its looking bad.
I think the oft or the connection to oft or the battery volts is to low for flashing to complete.
One on those senarios has resulted in a partial or failed flash. During The reflashing process the ecu is first erased then the new rom is flashed.
I think your rom is erased or only partially flashed this will result in car not even cranking
If you have any other car arround with an obd port plug oft into that and see if it powers up this will check oft and cable.
If that works check the your cars obd poert pins and the fuse for obd port.
Old 11-29-2015, 05:45 PM   #24
diBreezy
diBreezy's Avatar
That's exactly what I think happened.
I think it was a partial or failed flash problem.
Now, just so I understand, when I plug the OFT into another car. Should it immediately power on, or do I have to key to ACC? Or even Key to ON?
Old 11-29-2015, 05:47 PM   #25
_gt86_user
Inactive
Drives: .
It should immediately power on, I've had this happen to me but I just unplugged the oft and plugged it back in after 20sec, I should also add I've never tried flashing the ecu anywhere but home since I use an on board charger just in case something like this happens.
_gt86_user is offline   Reply With Quote
Old 11-29-2015, 05:49 PM   #26
diBreezy
diBreezy's Avatar
Lesson learned. Flashing away from home is dangerous.
So if the keys are out of it and I plug it in the OFT should power on?
Old 11-29-2015, 05:50 PM   #27
steve99
Drives: FT86
Depending on vehicle oft may imediatly ppwer up of it may require key to acc or on position. some vehicles switch power to obd poert with ignition some dont.
Not trying to be a d1ck but with your own car make sure your switching ignition to full on position (do not try to start) when you flash ACC position will not allow flash process.
OFT should power up on a brz\86 straight away on plug in though
Old 11-29-2015, 05:56 PM   #28
diBreezy
diBreezy's Avatar
I don't think you're being a **** at all. I'll take whatever help I can get we are checking fuses with digital multimeter now.
There are only two fuseboxes right? Driver side and hood.
Pushed start.. didnt start im_topher Engine, Exhaust, Transmission 86 11-29-2015 09:57 AM
Where did you start with your FR-S/BRZ jeepmor Scion FR-S / Toyota 86 GT86 General Forum 43 04-10-2014 01:39 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
