Old 11-27-2015, 12:14 PM   #1
FR-Slide
Drives: 13 Whiteout 6MT
Quick questions about OFT
Hi all,
Sorry, I know that these are rudimentary questions, but there is a ton of data to sift through and I wanted to hopefully get some quick answers since there is a time-sensitive deal going on now with OFTs.
I want to pick one up, and the price from Vishnu is $450+ shipping, but there are a handful in the classifieds going for $400 shipped right now as well. Is there any benefit to getting a new tablet over a used one? Are there any versions of the software/hardware that have changed? Since it's all open source, I assumed that they're all the same, but I don't want to buy a used one and get stuck with an outdated version or miss out on new maps/updates. Likewise, I don't want to overpay.
Also, I see that stage 1 is generic, and stage 2 is more specific. For a DD car, is stage 2 too aggressive? My only mods are a drop in, inlet tube, and UEL right now. Maybe an axelback/catback in the future.
Thanks for any quick help or guidance!
FR-Slide is offline   Reply With Quote
Old 11-27-2015, 01:42 PM   #2
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Functionally, a used OFT is identical to a new OFT assuming it is unmarried from the previous owner's car. Beyond that, the benefit of buying a new one from us is getting $500 worth of OFT dollar discounts that you can apply to other parts (header, exhaust, power blocks, FI kits, etc,.) This may or may not be useful depending on if you plan to add additional mods in the future.
Cheers
shiv
Shiv@Openflash is offline   Reply With Quote
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
FR-Slide (11-27-2015), thambu19 (11-27-2015)
Old 11-27-2015, 03:18 PM   #3
golfyankee2121
Always Moving Forward
golfyankee2121's Avatar
Drives: 2013 Argento Scion FR-S
Originally Posted by FR-Slide View Post
Hi all,
I picked up a second-hand OFT from a member here in the member classifieds and haven't had any issues. As far as I know, the tablet itself has not had any new versions, but Shiv has released many different versions (revisions) of the tunes, all of which are free to download from their website.
With your mods, definitely run the UEL Stage 2 tune (assuming your UEL header is catless). You will feel an improvement in performance for sure.
Shiv is going to be releasing a new revision of UEL Stage 2 tunes here pretty soon too and the dyno's he posted show some nice gains over the current off-the-shelf UEL Stage 2 tunes.
http://www.ft86club.com/forums/showthread.php?t=98151
Hope this helps,
-J.B.
golfyankee2121 is offline   Reply With Quote
The Following 2 Users Say Thank You to golfyankee2121 For This Useful Post:
FR-Slide (11-27-2015), Shiv@Openflash (11-27-2015)
Old 11-27-2015, 03:32 PM   #4
thambu19
Drives: Scion FRS
Cheers
shiv
Still trying to convince my wife about buying one. She tells me "You do calibration for a job so why do you want to mess around with your car" She has a point but where is the fun in that?
Sent from my HTC One_M8 using Tapatalk
thambu19 is offline   Reply With Quote
Old 11-27-2015, 03:33 PM   #5
FR-Slide
Thanks guys, that helps clarify pretty much everything I needed to know. Not sure which route I'll go yet, but I look forward to joining the OFT army soon.
Old 11-27-2015, 03:52 PM   #6
Shiv@Openflash
Drives: 2013 FRS
Hope this helps,
-J.B.
+1
However there has recently been a hardware update (HW100 -> HW200) which is not relavent in this application (for the foreseeable future).
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
golfyankee2121 (11-27-2015)
Old 11-27-2015, 04:51 PM   #7
thambu19
Drives: Scion FRS
+1
I hope that is for live/dynamic calibration like ETAS INCA. There is nothing like you making a change and seeing the effect immediately Not sure if this can be done without using some blend of piggyback + OFT with the piggyback used to do stuff such as cam delta, spark delta, fueling delta etc. You can do if. If you guys cannot then no one can!
@Shiv@Openflash I hope you guys are excited about the Fiat 124. Seems like you can build on the Abarth OFT
Old 11-27-2015, 05:41 PM   #8
steve99
Drives: FT86
you get a 1 year warantee with a new one :-)
The Following 3 Users Say Thank You to steve99 For This Useful Post:
LOLS2K (11-27-2015), Shiv@Openflash (11-27-2015), thambu19 (11-27-2015)
Old 11-27-2015, 06:12 PM   #9
CTO79
Drives: GT86
Will there be an update on stage 2 EL in the nearterm?
CTO79 is offline   Reply With Quote
Old 11-27-2015, 06:39 PM   #10
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
OFT uses Open Source which others don't use
Since OFT uses open source software, tunes can be shared readily without the fear of being sued for sharing without permission. This means there are less restrictions to the sharing of knowledge, like PFI_DI thresholds. These tables weren't in the current RomRaider definitions, but the memory addresses and code was shared with anyone who wished to add it to their definition, and now we can edit those thresholds. There was no patent or copyright violation in sharing RomRaider code, since it is open source. Open source leads to faster freer development, since it isn't limited by old-fashioned patent or copyright laws as much as commercial software is.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
Old 11-27-2015, 06:49 PM   #11
thambu19
Drives: Scion FRS
I wish everything was open source
The Following User Says Thank You to thambu19 For This Useful Post:
KoolBRZ (11-27-2015)
Old 11-28-2015, 12:09 AM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
Many users might wish same. But most tuner shops wish for their works/tunes to not be shareable, so that every customer pays (and maybe not even once in case of retuning with extra mods). This is not ideal world and won't be one ever, due each side having own interests contradicting/conflicting with those of others.
Old 11-28-2015, 09:08 AM   #13
thambu19
Drives: Scion FRS
Got to say the oft guys are the best. I love their business model. They will need to expand to more models for long term success but that means less time to give updated cams to us. So we need to start picking up some of the work and start contributing to the community. Be self sufficient.
bfrank1972 (11-28-2015)
Old 11-28-2015, 09:09 AM   #14
thambu19
Drives: Scion FRS
Cals not cams lol
About to buy, quick questions DigitalVeil92 Scion FR-S / Toyota 86 GT86 General Forum 22 08-10-2015 12:10 AM
A few quick subwoofer questions qoncept Electronics | Audio | NAV | Infotainment 10 11-17-2014 04:48 PM
Buying FR-S. Quick Questions. maverpl Scion FR-S / Toyota 86 GT86 General Forum 28 03-28-2014 11:25 PM
Few quick BeSpoke questions NOMNOM Electronics | Audio | NAV | Infotainment 0 04-17-2013 01:39 AM
Few quick set up questions Im_SPEED Tracking / Autocross / HPDE / Drifting 14 08-23-2012 03:28 PM
