Old 11-12-2015, 09:59 AM   #1
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
ABS / Traction light on and Dimming interior lights
So... I pulled my car out of the garage. Started up, unlocked, everything normal.
The lights turn on (auto mode) and the ABS and traction system lights come on in the dash. When I hit my brakes the center stack lights dim and the clock fades out. When I release the brakes the clock comes back (correct time) and the lights come back to normal brightness.
Never seen anything like this, WTF.
Made an appointment to go to Subaru on the 24th as I will be out of town for a while but this has me pretty upset. Car has 20K on it. I have had it in the garage parked and not driven so much recently, but I take it out every other weekend or an occasional day of work just to keep it moving and enjoy it before winter. Once winter sets it will be in the garage with a trickle charger.
Old 11-12-2015, 10:26 AM   #2
jvincent
jvincent's Avatar
Stating the obvious, looks like an electrical issue of some kind.
Did you look to see if any critters had chewed on the wiring?
Old 11-12-2015, 10:33 AM   #3
Summerwolf
Panda Trueno
Summerwolf's Avatar
Yes I checked but the garage is clean and I'm in there frequently. I can't rule that out but I have no evidence of that. I have read of other Subarus having battery or alternator issues with similar symptoms but my car had nothing indicating any of that.
Old 11-12-2015, 11:21 AM   #4
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Did you pull any codes?
jawn is offline   Reply With Quote
Old 11-12-2015, 11:41 AM   #5
Summerwolf
Panda Trueno
Summerwolf's Avatar
No CEL. Just the ABS and traction light on. I didn't hook up an OBD II scanner.
If the headlights are off and you start the car no ABS / Traction lights but the center stack lights dim with the brake. If you turn the headlights on manually or automatically, the dash lights come on. If the headlights are turned on the interior lights don't dim with the brake usage.
Old 11-12-2015, 12:44 PM   #6
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Do you have a 4th brake light wired in? This was the EXACT same problem i had, as soon as the lights came on it tripped it..OBD scanner wouldn't pick up the code, hooked up the Genesis to it and it showed a brake light switch code..disconnected 4th brake light issue is gone.
797Performance.com
nickmerronesucks is offline   Reply With Quote
The Following 2 Users Say Thank You to nickmerronesucks For This Useful Post:
Sportsguy83 (11-12-2015), Summerwolf (11-12-2015)
Old 11-12-2015, 01:10 PM   #7
Summerwolf
Panda Trueno
Summerwolf's Avatar
I do have my third brake light deleted and a 4th brake light wired in. That has been on for over a year though without issue. I guess I'll have to look in to that.
Literally nothing has changed except letting the car sit for somewhat extended periods of time.
Old 11-12-2015, 04:05 PM   #8
nickmerronesucks
Ned flanders
Same thing for me..car was fine with the 4th brake light wired in for about 6 months..car sat while i was replacing the clutch then started to drive it again and had this issue.
797Performance.com
The Following User Says Thank You to nickmerronesucks For This Useful Post:
Old 11-12-2015, 04:15 PM   #9
Summerwolf
Panda Trueno
Summerwolf's Avatar
Well, huh. I won't have time to look at it before I leave town, but I will let you know what happens when the dealer looks at it.
Was there a fix or did you just remove the brake light? That's not an option for me since I deleted the window one and had my deck reupholstered.
Old 11-12-2015, 05:07 PM   #10
nickmerronesucks
Ned flanders
I just did away with it until I have time to mess with it.
797Performance.com
Old 11-25-2015, 09:37 AM   #11
Summerwolf
Panda Trueno
Summerwolf's Avatar
It wound up being a wire that had come undone (ground) and they repaired the connection.
Somehow I guess when I had my taillights candied they messed up part of the harness. Something really stupid caused a lot of weird issues, but its fixed and no biggie in the long run.
The Following User Says Thank You to Summerwolf For This Useful Post:
nickmerronesucks (11-25-2015)
Old 11-25-2015, 10:08 AM   #12
nickmerronesucks
Ned flanders
Maybe after winter ill give it another shot
Sent from my SPH-L720T using Tapatalk
797Performance.com
Old 11-25-2015, 10:09 AM   #13
nickmerronesucks
Ned flanders
Thanks for updating your thread for future reference
797Performance.com
traction light, engine light = cam sprocket , ecu nivek111070 Issues | Warranty | Recalls / TSB 27 03-13-2016 10:28 AM
Traction and CEL Light WhiteChocolate Engine, Exhaust, Transmission 25 09-23-2015 10:21 AM
Traction light came on for a sec. Josh Ehlert Issues | Warranty | Recalls / TSB 10 06-25-2015 04:47 AM
no AC lights or HVAC dimming help lbroskee Electronics | Audio | NAV | Infotainment 0 11-17-2013 07:18 PM
Head unit not dimming with lights BRZ raptor87 Electronics | Audio | NAV | Infotainment 5 08-05-2013 01:27 PM
