Old 08-03-2013, 03:04 PM   #1
raptor87
Drives: 2013 DGM BRZ Ltd
Head unit not dimming with lights BRZ
I had my battery disconnected while I was wiring up my dash cam and after hooking everything back up my head unit does not dim the display when I turn the lights on.
After I re connected the battery I had to redo all the navigation settings but my xm presets and stored favorites remained in the radio.
I went though all the map settings and it is set to dim with the lights. I am not sure if the dash cam install caused this or I am missing something on the radio. I wired the cam using an add a fuse in the unused slot under the OBD fuse. I looked around to see if I could do a factory reset on the head unit but I have not seen an option or been able to find instructions in the service manual or the internet.
any ideas?
raptor87 is offline   Reply With Quote
Old 08-03-2013, 03:30 PM   #2
raptor87
I tried unplugging the camera and it caused no change in the radio behavior. Here are some pictures of my settings.
Old 08-04-2013, 11:28 AM   #3
wparsons
wparsons's Avatar
Most HU's have a 12v input to let it know when the lights are turned on, I'd check to make sure there isn't a connection missing since you had the dash apart.
flickr
Old 08-04-2013, 10:08 PM   #4
raptor87
I didn't really take the dash apart just the cover under the steering wheel to get to the fuse box
Old 08-05-2013, 09:18 AM   #5
wparsons
wparsons's Avatar
How did you plug in the dash cam without the HU out? I would still make sure nothing is disconnected, the dimming will be driven off a signal, not by time of day.
flickr
Old 08-05-2013, 12:27 PM   #6
raptor87
The camera does not connect to the head unit at all I just needed to run a line to the fuse box for power. I ran it down the a pillar down to the fuse box under the steering wheel.
BRZ head lights -> JDM 86 head light conversion BRZPDX Cosmetic Modification (Interior/Exterior/Lighting) 6 08-02-2013 10:47 AM
Head unit depth bluenoserforever Electronics | Audio | NAV | Infotainment 0 07-25-2013 09:50 PM
BRZ Head Unit RedRocket Audio/Visual, Electronics, Infotainment, NAV 2 06-25-2013 10:21 PM
looking for a head unit for Fr-s like the Brz. enjoi23 Electronics | Audio | NAV | Infotainment 5 08-08-2012 02:51 PM
head unit in GTA excited86 Electronics | Audio | NAV | Infotainment 1 06-18-2012 07:42 PM
