Old 11-23-2015, 05:45 PM   #1
Astroboy
Astroboy's Avatar
Drives: None
Anybody bent their jack points?
The other day while I was lifting my car with a floor jack, my jack point bent! I bent it back with a vice grip, but I'm still afraid it naught fail again. Has anybody else had this issue?
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 11-23-2015, 05:50 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I am sure someone on here had that happen and everyone said it was not a big deal. Try searching pinch welds or somthing?
Old 11-23-2015, 08:55 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Zero worries, just bend it back.
If you change your tires a lot why not jack it up from the front/rear jack points?
A low profile jack is worth the investment, or wheel ramp jack helpers.
The Following User Says Thank You to Mr.ac For This Useful Post:
Astroboy (11-23-2015)
Old 11-23-2015, 09:06 PM   #4
Astroboy
Astroboy's Avatar
Drives: None
I rotate my tires every oil change
Old 11-23-2015, 09:19 PM   #5
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Ah I see, your jacking it up four times? One on each wheel?
Using the front/rear method you only jack it up twice.
Thanks for the reminder too need to rotate mine.
Old 11-23-2015, 09:25 PM   #6
Astroboy
Astroboy's Avatar
Drives: None
I guess I do need a low floor jack.
Old 11-23-2015, 11:33 PM   #7
And jack stands. Never trust the jack.
Then cut up a couple hockey pucks or tell me if you figure out something better on the cheap.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
Astroboy (11-24-2015), GhostOp86 (11-24-2015), Premium 615 (11-30-2015), RobertPaulson (02-22-2016)
Old 11-24-2015, 12:00 AM   #8
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Oh snap, don't tell me you're using the OEM jack? Say it isn't so.
The Harbor Fright one for $70 is perfect. Lots of autoX guys have it. It's light and good enough for tire changes. Though it doesn't raise it high enough to do repair work.
I saw some new cheap jack stands for $20 that had a notch already cut in. I forget the brand it was in autozone or some other place.
The Following 2 Users Say Thank You to Mr.ac For This Useful Post:
seant2h (12-06-2015), Ultramaroon (11-24-2015)
Old 11-24-2015, 04:37 PM   #9
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
If you have a high lift jack, when you jack from the front the rear will come off the ground too so you still only have to jack twice. My jack is pneumatic, it makes it even easier.
Scenic Driver is offline   Reply With Quote
Old 11-24-2015, 04:47 PM   #10
8R6
8R6's Avatar
Drives: FRS
even with a low profile jack, i still need to drive onto a small piece of wood to barely get the jack under the jack point :/
the front/rear center jack points pretty much became non-existant as soon as i lowered the car lol
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
zc06_kisstherain (02-05-2016)
Old 11-24-2015, 05:57 PM   #11
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
It's fine.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 11-24-2015, 11:46 PM   #12
Euro7R
Drives: 2013 Subaru BRZ
First time I jacked up my car, the paint chipped off the jack points on the side. I jack from front and rear now.
Euro7R is offline   Reply With Quote
Old 12-05-2015, 12:22 PM   #13
dnieves
Drives: FR-S 10 Series
After bending it back, look for cracks/chips in the paint then scrape them clean (primer or metal). Touch up the area with printer then paint (maybe want to put in a bit of undercoating) -if it's cold hit it a little with a heat gun to speed up the curing process.
dnieves is offline   Reply With Quote
Old 02-01-2016, 03:42 AM   #14
Nessal
Drives: Exige, Miata, Ghia
Even with jack stands, I play it safe and slide my wheels under the side of the car. Better a new wheel than my skull if it fails. If I'm not taking the wheels off, I leave the jack in place just barely contacting where I jacked it up as a fail safe. There is a guy on our forum that had his jack stands fail and it wasn't pretty. I personally use the cross pin jack stands as they are generally stronger.
Nessal is offline   Reply With Quote
The Following 3 Users Say Thank You to Nessal For This Useful Post:
Hamza (04-03-2021), Ultramaroon (02-01-2016), zc06_kisstherain (02-05-2016)
Similar drill points for lip? Kerune Cosmetic Modification (Interior/Exterior/Lighting) 0 08-22-2015 08:44 PM
Bent jack points afishl1 Cosmetic Modification (Interior/Exterior/Lighting) 6 06-02-2015 02:24 PM
points reduction course jarviz Off-Topic Lounge [WARNING: NO POLITICS] 18 03-20-2014 05:12 PM
Jack stand points xxscaxx Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 09-12-2013 09:01 PM
Car Jacking up Points? J-Money Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 01-21-2013 02:55 PM
