Old 06-02-2015, 05:00 AM   #1
afishl1
Drives: Raven FRS MT
Bent jack points
Body shop warped them, can they be straightened out? Will they then still have enough integrity for their purpose?
afishl1 is offline   Reply With Quote
Old 06-02-2015, 09:21 AM   #2
meeskee2
meeskee2's Avatar
Drives: World Rally Blue BRZ Limited, MT
I think so. Mine are slightly bent and every car I have owned they've been bent in some way.
- World Rally Blue BRZ | Limited | Manual -
"Some guys think that having a better car makes them better than other guys, and those guys are right." -Top Gear
meeskee2 is offline   Reply With Quote
Old 06-02-2015, 11:45 AM   #3
8R6
8R6's Avatar
Drives: FRS
i hate pinch weld jack points. my driver-side front is also bent. the other three are still straight tho
8R6 is offline   Reply With Quote
Old 06-02-2015, 12:50 PM   #4
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
I noticed mine was a little bent too, like the reinforced part. So found some pucks and sawed a wedge into the puck for it to sit on. http://i.imgur.com/VfBooOD.jpg
Myv is offline   Reply With Quote
Old 06-02-2015, 01:15 PM   #5
8R6
8R6's Avatar
Drives: FRS
i did that too... twice. both times after a couple uses, the pinch weld cut right thru the puck and split it in half.
but for the record, until the pucks split in half, they worked awesome! lol
Old 06-02-2015, 01:38 PM   #6
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
yes they still have integrity. Mine's are completely bent. The bent point is not the integrity, you're fine.
Old 06-02-2015, 02:24 PM   #7
afishl1
Ok, it's just annoying fitting them in my jack stands now and was wondering whether I should bother complaining to the shop or not.
Harness Mounting Points Shakkazombie Scion FR-S / Toyota 86 GT86 General Forum 0 04-15-2015 01:36 AM
points reduction course jarviz Off-Topic Lounge [WARNING: NO POLITICS] 18 03-20-2014 05:12 PM
Jack stand points xxscaxx Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 09-12-2013 09:01 PM
Bent Rim Sir Alex Mid-Atlantic 5 08-09-2013 03:34 PM
Car Jacking up Points? J-Money Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 01-21-2013 02:55 PM
